Overstrek i Word 2007?
Fant litt på Google: http://www.google.com/search?hl=no&cli...%C3%B8k&lr=
1. Navigate your cursor to where you want to insert your overlined character or word.
2. Press CTRL + F9, which will insert a set of braces (this is command+F9 on a Mac)
3. Type in "EQ \x \to(P)" if you want to insert an overlined character above a P, otherwise replace P with your character or word.
4. Press Shift+F9 to get your character (option+F9 on a Mac).
Funka på Word 2003 hos meg.
Denne funket jo simpelt helt perfekt!
Takker så mye Zeph
