strømforsyning med LANG 12v kabel og HK-kabel
Du får lese spesifikasjonene på PSU hos produsenten (de typene du evt tenker på) . Vanlig at det er opplyst lengde på kabler.
F.eks fant jeg for Corsair VX-450/VX-550 dette:
Extra long cables support full tower size chassis.
Corsair Cable Configuration
• 1 x 610mm (24”) 24-pin ATX power connector cable.
Note: The ATX power connector has a detachable 4-pin mechanism in
order to support either a 24-pin or a 20-pin socket on the motherboard.
• 1 x 610mm (24”) 8-pin EPS12V connector cable.
Note: The EPS12V power connector has a detachable 4-pin mechanism in
order to support either an 8-pin socket or a 4-pin “P4/12V” socket on
the motherboard.
• For VX550W: 2 x 610mm (24”) 6-pin PCI-E connector cable.
• For VX450W: 1 x 610mm (24”) 6-pin PCI-E connector cable.
• 2 x 710mm (28”) SATA connector cable with three SATA connector heads.
• 2 x 860mm (34”) 4-pin peripheral power connector cable with three
connector heads and one small 4-pin for floppy drive.
