DDR, or DDR2?
Kravik
Chipset: nVidia nForce4 SLI Supported DRAM Types: DDR SDRAM only DDR SDRAM Frequencies: PC2100, PC2700, and PC3200 DIMM Banking 184-pin: 4 (2 banks of 2)DIMM Banking 240-pin: N.AModule Types Supported: Unbuffered only Max Unbuffered DDR SDRAM: 4096MB Error Detection Support: ECC and non-ECC Graphics Support: Dual PCI Express x16, SLI capable Firewire Support: YUSB Support: 2.x CompliantSerial ATA Support: YMax Component Density: 1024
Your Mobo supports DDR
So DDR2 is not possible?
Only supports DDR?
Endret av Gomp|
