Trenger hjelp til å oppgradere dataen
Wanisher
hei jeg trenger hjelp til å otimalisere(oppgradere) dataen min for spill
til de som vill hjelpe, her er en liste om de tingene jeg har nå
det som jeg trenger er skjemkort og ny CPU(prossessor)
CPU INFORMATION
Number of CPU ------------------ 1
Manufacturer ------------------- GenuineIntel
Processor ---------------------- Intel Pentium III
Code Name ---------------------- Katmaï
Package ------------------------ Slot 1 SECC2
Family ------------------------- 6
Model -------------------------- 7
Stepping ----------------------- 2
Core Revision ------------------ kB0
Extended Family/Model ---------- 0/0
Technology --------------------- 0.25µ
Microcode Revision ------------- 10
Specification ------------------ Intel Pentium III 500MHz
Instructions ------------------- MMX, SSE
CPU Speed ---------------------- 501.2MHz
Clock Multiplier --------------- 5.0x
Front Side Bus ----------------- 100.2MHz
Bus Speed ---------------------- 100.2MHz
L1 Data cache ------------------ 16Kb
L1 Code cache ------------------ 16Kb
L2 cache ----------------------- 512Kb
MAINBOARD INFORMATION
Manufacturer ------------------- http://www.abit.com.tw
Model (revision) --------------- i440BX-W977(BX6 Rev2.0) ( )
Chipset (revision)-------------- Intel i440BX/ZX (C1)
Southbridge -------------------- Intel 82371 (PIIX4)
BIOS Brand ---------------------
BIOS Version ------------------- Award Software International, Inc.
BIOS Date ---------------------- 04/07/1999
AGP Revision ------------------- 1.0
AGP Transfer Rate -------------- 2x
AGP Aperture Size -------------- 64Mb
AGP Side Band Addressing ------- enabled
Display adapter Manufacturer --- ATI
Model (revision) --------------- Rage 128 GL (0)
MEMORY INFORMATION
Type --------------------------- SDRAM
Size --------------------------- 320Mb
# of memory modules ------------ 3
Module 0 ----------------------- SDRAM PC100 - 128 Mb
Module 1 ----------------------- SDRAM PC100
Module 2 ----------------------- SDRAM PC125 - 128 Mb
Frequency ---------------------- 100.2MHz
CAS# Latency ------------------- 3.0 clocks
RAS# to CAS# Delay ------------- 3 clocks
RAS# Precharge Time ------------ 3 clocks
DRAM Idle Timer ---------------- 32 clocks
SYSTEM INFORMATION
Operating System --------------- Microsoft Windows XP (Build 2600)
Siden du har AGP port som støtter AGP 2X, så skulle de aller fleste nye grafikkort passe. Selv om grafikkortet har maks APG på 8X, så virker de fleste på 2X overføringshastighet også. Det er ikke så veldig mye du taper. Et Radeon 9100 kort skulle kanskje være en god ide?
Når det gjelder CPU, så er den 100% avhengig av hovedkortet og typen minne. I dag finnes det vel neppe mange slot1 CPUer å få kjøpt nye :-(
Jeg ville da anbefale deg å finne en på bruktmarkedet hvis du vil beholde hovedkortet. Jeg tipper at hovedkoretet støtter alle Penitum III som ha Front Side Bus (FSP) på 1000MHz,. Tror de raskeste av den type ligger omkring 850MHz, men er ikek sikker. Etterhvert kom PIII med 133MHz FSB, de passer ikke i ditt hovedkort.
Hvis du velger å bytte hovedkort, så er hele sirkuset igang: Nytt hovedkort, CPU, minne, CPU kjøler, muligens strømforsyning...
du trenger nytt hk hvis du skal ha ny cpu. Hvis du gjør dette må du også kjøpe nytt minne siden sdram blir for treigt for nye cpuer
Kort sagt kjøp
kabinett (ikke aopen hadde et og det kokte nesten pcn min, cpu 75 grader det er litt på kanten)
cpu+kjøler (skulle kjøpes som nevnt)
ram
hk
cdrom (ca 500 for dvdrom)
skjermkort (skulle kjøpes som nevnt)
Så har du en ny maskin med lyd og nettverk, kjøp et nytt nettverkskort så har du to maskiner i nettverk med internett
