Får ikke installert SP3 pga services.exe er i bruk
emva
Hei.
SP3 vil ikke installeres på en XP Home maskin.
Feil meldingen den gir er:
"The file C:windowssystem32services.exe is open or in use by another application.
Close all other applications and then click retry"
Har kjørt SAS, SpyBot S&D en del ganger (normal og sikkerhetsmodus)
AVG vil heller ikke inn. det ligger der, men servicen starer ikke
Combofix
ComboFix 08-08-14.03 - navn 2008-08-21 12:44:36.5 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1044.18.250 [GMT 2:00]
Running from: C:\Documents and Settings\navn\Skrivebord\ComboFix.exe
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((( Files Created from 2008-07-21 to 2008-08-21 )))))))))))))))))))))))))))))))
2008-08-21 00:17 . 2008-08-21 00:17 d-------- C:\Documents and Settings\Administrator
2008-08-20 15:10 . 2008-08-21 00:34 d-------- C:\WINDOWS\system32\CatRoot_bak
2008-08-19 00:42 . 2008-08-21 12:42 dr-h----- C:\Documents and Settings\navn\Siste
2008-08-19 00:32 . 2008-08-19 00:32 d-------- C:\Programfiler\CCleaner
2008-08-18 21:22 . 2008-08-18 21:22 d-------- C:\WINDOWS\system32\drivers\Avg
2008-08-18 21:22 . 2008-08-18 21:22 96,520 --a------ C:\WINDOWS\system32\drivers\avgldx86.sys
2008-08-18 21:22 . 2008-08-18 21:22 76,040 --a------ C:\WINDOWS\system32\drivers\avgtdix.sys
2008-08-18 21:21 . 2008-08-18 21:21 d-------- C:\Programfiler\AVG
2008-08-18 21:21 . 2008-08-18 22:12 d-------- C:\Documents and Settings\All Users\Programdata\avg8
2008-08-18 18:22 . 2008-08-18 20:55 363 --a------ C:\WINDOWS\wininit.ini
2008-08-18 17:44 . 2008-08-18 18:29 d-------- C:\Programfiler\SUPERAntiSpyware
2008-08-18 17:44 . 2008-08-18 17:44 d-------- C:\Documents and Settings\navn\Programdata\SUPERAntiSpyware.com
2008-08-18 17:44 . 2008-08-18 17:44 d-------- C:\Documents and Settings\All Users\Programdata\SUPERAntiSpyware.com
2008-08-18 17:43 . 2008-08-18 17:43 d-------- C:\Programfiler\Fellesfiler\Wise Installation Wizard
2008-08-18 17:37 . 2008-08-18 17:37 d-------- C:\Programfiler\Spybot - Search & Destroy
2008-08-18 17:37 . 2008-08-19 16:44 d-------- C:\Documents and Settings\All Users\Programdata\Spybot - Search & Destroy
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-08-21 10:41 --------- d-----w C:\Documents and Settings\navn\Programdata\OpenOffice.org2
2008-06-14 18:00 272,256 ------w C:\WINDOWS\system32\dllcache\bthport.sys
------- Sigcheck -------
md5deep: C:\WINDOWS\system32\svchost.exe: error at offset 0: Permission denied
2004-08-04 14:00 502272 1640872f408745717b054512a7e44b87 C:\WINDOWS\system32\winlogon.exe
md5deep: C:\WINDOWS\explorer.exe: error at offset 0: Permission denied
md5deep: C:\WINDOWS\system32\services.exe: error at offset 0: Permission denied
md5deep: C:\WINDOWS\system32\lsass.exe: error at offset 0: Permission denied
2005-06-11 02:17 57856 ad3d9d191aea7b5445fe1d82ffbb4788 C:\WINDOWS\$hf_mig$\KB896423\SP2QFE\spoolsv.exe
md5deep: C:\WINDOWS\system32\spoolsv.exe: error at offset 0: Permission denied
((((((((((((((((((((((((((((( snapshot@2008-08-19_15.27.26.89 )))))))))))))))))))))))))))))))))))))))))
- 2008-08-19 00:59:10 16,384 -c--a-w C:\WINDOWS\system32\config\systemprofile\Cookies\index.dat
+ 2008-08-20 22:39:50 16,384 -c--a-w C:\WINDOWS\system32\config\systemprofile\Cookies\index.dat
- 2008-08-19 00:59:10 32,768 -c--a-w C:\WINDOWS\system32\config\systemprofile\Lokale innstillinger\Logg\History.IE5\index.dat
+ 2008-08-20 22:39:50 32,768 -c--a-w C:\WINDOWS\system32\config\systemprofile\Lokale innstillinger\Logg\History.IE5\index.dat
- 2008-08-19 00:59:10 32,768 -c--a-w C:\WINDOWS\system32\config\systemprofile\Lokale innstillinger\Temporary Internet Files\Content.IE5\index.dat
+ 2008-08-20 22:39:50 32,768 -c--a-w C:\WINDOWS\system32\config\systemprofile\Lokale innstillinger\Temporary Internet Files\Content.IE5\index.dat
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-04 14:00 15360]
"MsnMsgr"="C:\Programfiler\Windows Live\Messenger\MsnMsgr.Exe" [2007-10-18 12:34 5724184]
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="C:\Programfiler\Fellesfiler\Ahead\lib\NMBgMonitor.exe" [2006-03-01 19:43 90112]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"NeroFilterCheck"="C:\Programfiler\Fellesfiler\Ahead\Lib\NeroCheck.exe" [2006-01-12 15:40 155648]
"LogitechCommunicationsManager"="C:\Programfiler\Fellesfiler\LogiShrd\LComMgr\Communications_Helper.exe" [2007-07-25 16:02 563984]
"LogitechQuickCamRibbon"="C:\Programfiler\Logitech\QuickCam\Quickcam.exe" [2007-07-25 16:06 2027792]
"SoundMan"="SOUNDMAN.EXE" [2006-06-21 06:42 577536 C:\WINDOWS\SOUNDMAN.EXE]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="C:\WINDOWS\system32\CTFMON.EXE" [2004-08-04 14:00 15360]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"WUAppSetup"="C:\Programfiler\Fellesfiler\logishrd\WUApp32.exe" [2007-07-19 02:45 439568]
C:\Documents and Settings\navn\Start-meny\Programmer\Oppstart\
OpenOffice.org 2.1.lnk - C:\Programfiler\OpenOffice.org 2.1\program\quickstart.exe [2006-12-02 00:32:46 393216]
C:\Documents and Settings\All Users\Start-meny\Programmer\Oppstart\
Hurtigstart for Adobe Reader.lnk - C:\Programfiler\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2000-03-05 16:57:42 29696]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "C:\Programfiler\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 10:13 77824]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
"NqNLSHNsWkfx"= {3CDB81B2-9671-2B18-635F-C8046803C3AB} - C:\WINDOWS\system32\fhfx.dll [2007-04-16 17:54 32768]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
2007-04-19 13:41 294912 C:\Programfiler\SUPERAntiSpyware\SASWINLO.dll
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"C:\\Programfiler\\Messenger\\Msmsgs.exe"=
"C:\\Programfiler\\Windows Live\\Messenger\\msnmsgr.exe"=
"C:\\Programfiler\\Windows Live\\Messenger\\livecall.exe"=
R1 AvgLdx86;AVG Free AVI Loader Driver x86;C:\WINDOWS\system32\Drivers\avgldx86.sys [2008-08-18 21:22]
R2 avg8wd;AVG Free8 WatchDog;C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2008-08-18 21:21]
R2 AvgTdiX;AVG Free8 Network Redirector;C:\WINDOWS\system32\Drivers\avgtdix.sys [2008-08-18 21:22]
R2 EAPPkt;Realtek EAPPkt Protocol;C:\WINDOWS\system32\DRIVERS\EAPPkt.sys [2005-04-01 10:42]
S3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;C:\WINDOWS\system32\DRIVERS\wg111v2.sys []
S3 SjyPkt;SjyPkt;C:\WINDOWS\System32\Drivers\SjyPkt.sys []
------- Supplementary Scan -------
R1 -: HKCU-Internet Connection Wizard,ShellNext = iexplore
O8 -: &Search - http://kn.bar.need2find.com/KN/menusearch.html?p=KN
O9 -: {d9288080-1baa-4bc4-9cf8-a92d743db949} - C:\Documents and Settings\navn\Start-meny\Programmer\IMVU\Run IMVU.lnk
O16 -: {745395C8-D0E1-4227-8586-624CA9A10A8D} - hxxp://159.171.96.58/activex/AMC.cab
C:\WINDOWS\Downloaded Program Files\setup.inf
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-08-21 12:47:15
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
Completion time: 2008-08-21 12:48:30
ComboFix-quarantined-files.txt 2008-08-21 10:48:27
Pre-Run: 13,679,603,712 byte ledig
Post-Run: 13,669,924,864 byte ledig
110 --- E O F --- 2008-08-18 15:26:57
høytadette
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 11:50:28, on 21.08.2008
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\System32\svchost.exe
c:\programfiler\fellesfiler\logishrd\lvmvfm\LVPrcSrv.exe
C:\Programfiler\Fellesfiler\LightScribe\LSSrvc.exe
C:\Programfiler\Fellesfiler\LogiShrd\LVCOMSER\LVComSer.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\wuauclt.exe
C:\Programfiler\OpenOffice.org 2.1\program\soffice.exe
C:\Programfiler\OpenOffice.org 2.1\program\soffice.BIN
C:\Programfiler\Fellesfiler\Logishrd\LQCVFX\COCIManager.exe
C:\Documents and Settings\navn\Skrivebord\HiJackThis.exe
C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Programfiler\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Påloggingshjelp for Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Programfiler\Fellesfiler\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O4 - HKLM\..\Run: [soundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Programfiler\Fellesfiler\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [LogitechCommunicationsManager] "C:\Programfiler\Fellesfiler\LogiShrd\LComMgr\Communications_Helper.exe"
O4 - HKLM\..\Run: [LogitechQuickCamRibbon] "C:\Programfiler\Logitech\QuickCam\Quickcam.exe" /hide
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Programfiler\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [bgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Programfiler\Fellesfiler\Ahead\lib\NMBgMonitor.exe"
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETTVERKSTJENESTE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [WUAppSetup] C:\Programfiler\Fellesfiler\logishrd\WUApp32.exe -v 0x046d -p 0x092e -f video -m logitech -d 11.1.0.2016 (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [WUAppSetup] C:\Programfiler\Fellesfiler\logishrd\WUApp32.exe -v 0x046d -p 0x092e -f video -m logitech -d 11.1.0.2016 (User 'Default user')
O4 - Startup: OpenOffice.org 2.1.lnk = C:\Programfiler\OpenOffice.org 2.1\program\quickstart.exe
O4 - Global Startup: Hurtigstart for Adobe Reader.lnk = C:\Programfiler\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O8 - Extra context menu item: &Search - http://kn.bar.need2find.com/KN/menusearch.html?p=KN
O9 - Extra button: Run IMVU - {d9288080-1baa-4bc4-9cf8-a92d743db949} - C:\Documents and Settings\navn\Start-meny\Programmer\IMVU\Run IMVU.lnk (file missing)
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra button: @c:\Programfiler\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\Programfiler\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: @c:\Programfiler\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\Programfiler\Messenger\msmsgs.exe
O16 - DPF: {05D44720-58E3-49E6-BDF6-D00330E511D3} (StagingUI Object) - http://zone.msn.com/binFrameWork/v10/StagingUI.cab55579.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?LinkID=39204
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
O16 - DPF: {3BB54395-5982-4788-8AF4-B5388FFDD0D8} (MSN Games – Buddy Invite) - http://zone.msn.com/BinFrameWork/v10/ZBuddy.cab55579.cab
O16 - DPF: {5736C456-EA94-4AAC-BB08-917ABDD035B3} (ZonePAChat Object) - http://zone.msn.com/binframework/v10/ZPAChat.cab55579.cab
O16 - DPF: {5C051655-FCD5-4969-9182-770EA5AA5565} (Solitaire Showdown Class) - http://messenger.zone.msn.com/binary/Solit...wn.cab56986.cab
O16 - DPF: {745395C8-D0E1-4227-8586-624CA9A10A8D} - http://159.171.96.58/activex/AMC.cab
O16 - DPF: {9BDF4724-10AA-43D5-BD15-AEA0D2287303} (ZPA_TexasHoldem Object) - http://zone.msn.com/bingame/zpagames/zpa_txhe.cab55579.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - http://cdn2.zone.msn.com/binFramework/v10/...ro.cab56649.cab
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/Messe...nt.cab56907.cab
O16 - DPF: {DA2AA6CF-5C7A-4B71-BC3B-C771BB369937} (MSN Games – Game Communicator) - http://zone.msn.com/binframework/v10/StProxy.cab55579.cab
O16 - DPF: {F5A7706B-B9C0-4C89-A715-7A0C6B05DD48} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineS...er.cab56986.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - (no file)
O20 - Winlogon Notify: !SASWinLogon - C:\Programfiler\SUPERAntiSpyware\SASWINLO.dll
O21 - SSODL: NqNLSHNsWkfx - {3CDB81B2-9671-2B18-635F-C8046803C3AB} - C:\WINDOWS\system32\fhfx.dll
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: iPod-tjeneste (iPod Service) - Unknown owner - C:\Programfiler\iPod\bin\iPodService.exe (file missing)
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Programfiler\Fellesfiler\LightScribe\LSSrvc.exe
O23 - Service: LVCOMSer - Logitech Inc. - C:\Programfiler\Fellesfiler\LogiShrd\LVCOMSER\LVComSer.exe
O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - c:\programfiler\fellesfiler\logishrd\lvmvfm\LVPrcSrv.exe
O23 - Service: LVSrvLauncher - Logitech Inc. - C:\Programfiler\Fellesfiler\LogiShrd\SrvLnch\SrvLnch.exe
End of file - 7256 bytes
og 2 SAS logger for å vise hva  som var på maskinen
første:
SUPERAntiSpyware Scan Log
http://www.superantispyware.com
Generated 08/18/2008 at 07:40 PM
Application Version : 4.15.1000
Core Rules Database Version : 3469
Trace Rules Database Version: 1460
Scan type : Complete Scan
Total Scan Time : 00:58:44
Memory items scanned : 171
Memory threats detected : 1
Registry items scanned : 4512
Registry threats detected : 13
File items scanned : 22253
File threats detected : 146
Trojan.Vundo-Variant/Small-GEN
C:\WINDOWS\SYSTEM32\MLJCSLIA.DLL
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{455ECFBC-91CB-4689-A6AF-4C78031FAA72}
HKCR\CLSID\{455ECFBC-91CB-4689-A6AF-4C78031FAA72}
HKCR\CLSID\{455ECFBC-91CB-4689-A6AF-4C78031FAA72}\InprocServer32
HKCR\CLSID\{455ECFBC-91CB-4689-A6AF-4C78031FAA72}\InprocServer32#ThreadingModel
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks#{455ECFBC-91CB-4689-A6AF-4C78031FAA72}
Software\Microsoft\Windows NT\CurrentVersion\WinLogon\Notify\mlJCSlIA
Rootkit.SysRest-A
HKLM\System\ControlSet001\Services\sysrest.sys
C:\WINDOWS\SYSTEM32\SYSREST.SYS
HKLM\System\ControlSet001\Enum\Root\LEGACY_sysrest.sys
HKLM\System\ControlSet003\Services\sysrest.sys
HKLM\System\ControlSet003\Enum\Root\LEGACY_sysrest.sys
HKLM\System\CurrentControlSet\Services\sysrest.sys
HKLM\System\CurrentControlSet\Enum\Root\LEGACY_sysrest.sys
Adware.Tracking Cookie
C:\Documents and Settings\navn\Cookies\navn@questionmarket[1].txt
C:\Documents and Settings\navn\Cookies\[email protected][1].txt
C:\Documents and Settings\navn\Cookies\[email protected][2].txt
C:\Documents and Settings\navn\Cookies\navn@pro-market[2].txt
C:\Documents and Settings\navn\Cookies\navn@advertising[3].txt
C:\Documents and Settings\navn\Cookies\navn@findwhat[1].txt
C:\Documents and Settings\navn\Cookies\navn@insightexpressai[2].txt
C:\Documents and Settings\navn\Cookies\navn@rambler[1].txt
C:\Documents and Settings\navn\Cookies\navn@revsci[1].txt
C:\Documents and Settings\navn\Cookies\navn@jh[2].txt
C:\Documents and Settings\navn\Cookies\navn@cassava[1].txt
C:\Documents and Settings\navn\Cookies\navn@adultfriendfinder[1].txt
C:\Documents and Settings\navn\Cookies\navn@loadsex[1].txt
C:\Documents and Settings\navn\Cookies\navn@tacoda[1].txt
C:\Documents and Settings\navn\Cookies\navn@crackle[1].txt
C:\Documents and Settings\navn\Cookies\navn@1072471539[1].txt
C:\Documents and Settings\navn\Cookies\navn@adbrite[2].txt
C:\Documents and Settings\navn\Cookies\navn@list[2].txt
C:\Documents and Settings\navn\Cookies\navn@realmedia[2].txt
C:\Documents and Settings\navn\Cookies\navn@atwola[2].txt
C:\Documents and Settings\navn\Cookies\navn@adtech[1].txt
C:\Documents and Settings\navn\Cookies\navn@2o7[1].txt
C:\Documents and Settings\navn\Cookies\navn@myroitracking[1].txt
C:\Documents and Settings\navn\Cookies\navn@sexsearchcom[1].txt
C:\Documents and Settings\navn\Cookies\navn@partypoker[2].txt
C:\Documents and Settings\navn\Cookies\navn@sexynatalie[1].txt
C:\Documents and Settings\navn\Cookies\navn@cgi-bin[2].txt
C:\Documents and Settings\navn\Cookies\navn@interclick[2].txt
C:\Documents and Settings\navn\Cookies\navn@spylog[1].txt
C:\Documents and Settings\navn\Cookies\navn@toplist[1].txt
C:\Documents and Settings\navn\Cookies\navn@need2find[2].txt
C:\Documents and Settings\navn\Cookies\navn@specificclick[2].txt
C:\Documents and Settings\navn\Cookies\navn@azjmp[2].txt
C:\Documents and Settings\navn\Cookies\navn@adrevolver[4].txt
C:\Documents and Settings\navn\Cookies\navn@yadro[1].txt
C:\Documents and Settings\navn\Cookies\navn@247realmedia[1].txt
C:\Documents and Settings\navn\Cookies\navn@adecn[1].txt
C:\Documents and Settings\navn\Cookies\navn@cgi-bin[4].txt
C:\Documents and Settings\navn\Cookies\navn@serving-sys[4].txt
C:\Documents and Settings\navn\Cookies\navn@countomat[1].txt
C:\Documents and Settings\navn\Cookies\navn@votasexyono[1].txt
C:\Documents and Settings\navn\Cookies\navn@youporn[2].txt
C:\Documents and Settings\navn\Cookies\navn@xiti[1].txt
C:\Documents and Settings\navn\Cookies\navn@atdmt[2].txt
C:\Documents and Settings\navn\Cookies\navn@indextools[1].txt
C:\Documents and Settings\navn\Cookies\navn@cgi-bin[1].txt
C:\Documents and Settings\navn\Cookies\navn@tribalfusion[2].txt
C:\Documents and Settings\navn\Cookies\navn@ad[2].txt
C:\Documents and Settings\navn\Cookies\navn@winanonymous[1].txt
C:\Documents and Settings\navn\Cookies\navn@hornyoyster[1].txt
C:\Documents and Settings\navn\Cookies\navn@1055731211[1].txt
C:\Documents and Settings\navn\Cookies\navn@trafficmp[1].txt
C:\Documents and Settings\navn\Cookies\navn@kontera[1].txt
C:\Documents and Settings\navn\Cookies\navn@optimost[1].txt
C:\Documents and Settings\navn\Cookies\navn@systemerrorfixer[1].txt
C:\Documents and Settings\navn\Cookies\navn@1040057370[1].txt
C:\Documents and Settings\navn\Cookies\navn@searchfeed[1].txt
C:\Documents and Settings\navn\Cookies\navn@sexysms[1].txt
C:\Documents and Settings\navn\Cookies\navn@adnetserver[2].txt
C:\Documents and Settings\navn\Cookies\navn@overture[2].txt
C:\Documents and Settings\navn\Cookies\navn@888[1].txt
C:\Documents and Settings\navn\Cookies\navn@tns-counter[1].txt
C:\Documents and Settings\navn\Cookies\navn@1071789980[1].txt
C:\Documents and Settings\navn\Cookies\navn@adserver[1].txt
C:\Documents and Settings\navn\Cookies\navn@gadget[2].txt
C:\Documents and Settings\navn\Cookies\navn@advertising[1].txt
C:\Documents and Settings\navn\Cookies\navn@advertising[2].txt
C:\Documents and Settings\navn\Cookies\navn@adnetserver[1].txt
C:\Documents and Settings\navn\Cookies\navn@serving-sys[1].txt
C:\Documents and Settings\navn\Cookies\navn@serving-sys[2].txt
Adware.Vundo Variant/Rel
HKLM\SOFTWARE\Microsoft\RemoveRP
Rogue.SpyShredder-Installer
C:\A
Trojan.Dropper/SVCHost-Fake
C:\WINDOWS\SVCHOST.EXE
Trojan.XpUpdate/Fake Alert
C:\WINDOWS\XPUPDATE.EXE
siste:
Generated 08/21/2008 at 11:03 AM
Scan type : Quick Scan
Total Scan Time : 00:51:00
Memory items scanned : 404
Memory threats detected : 0
Registry items scanned : 348
Registry threats detected : 0
File items scanned : 48653
File threats detected : 0
Start HijackThis "scan" finn disse linjene merk dem,så trykk fix checked.
Start->kjør->cmd
Skriv inn fet tekst
sc stop iPod Service
sc delete iPod Service
Kjør CClenaner som dette.
Last ned kjør CCleaner
'Valg'->'Avansert'. Fjern avkryssingen framfor: "bare slett midlertidige filer som er eldere enn 48 t.
Kjør og register-renser"svar ja til og reparere"-->backup svar ja når du blir spørt.
Kjør register-renser et par ganger til alle feil er borte.
md5deep er dette noe du har innstalert og kjører?
http://md5deep.sourceforge.net/
Utifra loggen.
Dette kan mulig lage noe krøll som gjør at du får denne meldingen.
Endret av SNIPPSAT
har fjernet de 3 med hijackthis, sc stop iPod Service nektet den å ta i mot men den er i listen over Tjenester enda, oppdaget at filen som den pekte til ikke eksisterte. Det er ikke noe spor av md5deep på datamaskinen, så vidt jeg kan se.
Hent DrWeb
Kjør drweb-cureit.exe (si ja til å kjøre en express scan)
Når dette er ferdig klikker du på Option -> Change settings.
Under fanearket Scan, fjerner du haken ved Heuristic analysis.
Under fanearket Actions, skal alle punkt under Malware settes til Rename.
Velg partisjon du vil scanne og klikk deretter på den grønne pilen for
å starte scanningen. Velg "yes to all" når det finner noe for første gang.
Når scanningen er ferdig, velg file – Trykk på- 'Save Report list'. Lagre på skrivebordet.
Det vil da ligge en fil som heter "drweb.csv" på skrivebordet. Den poster du.
noen viktige filer som var infisert også ja...
explorer.exe;c:\windows;Trojan.Starter.384;Renset.;
psexesvc.exe;c:\windows;Program.PsExec.170;Urensbar.Slettet.;
fhfx.dll;c:\windows\system32;Trojan.Proxy.3350;Slettet.;
lsass.exe;c:\windows\system32;Trojan.Starter.384;Renset.;
services.exe;c:\windows\system32;Trojan.Starter.384;Renset.;
spoolsv.exe;c:\windows\system32;Trojan.Starter.384;Renset.;
svchost.exe;c:\windows\system32;Trojan.Starter.384;Renset.;
winlogon.exe;c:\windows\system32;Trojan.Starter.384;Renset.;
psexec.cfexe;C:\ComboFix;Program.PsExec.171;Renamed.;
vacation simple plane.mp3;C:\Documents and Settings\navn\Mine dokumenter;Trojan.Click.18899;Incurable.Moved.;
ComboFix.exe\327882R2FWJFW\psexec.cfexe;C:\Documents and Settings\navn\Skrivebord\ComboFix.exe;Program.PsExec.171;;
ComboFix.exe;C:\Documents and Settings\navn\Skrivebord;Archive contains infected objects;Moved.;
BookMark Us.reg;C:\Documents and Settings\navn\Skrivebord\Musikk\Andreas musikk\MP3\My Music;Trojan.StartPage.1505;Deleted.;
data045\data006;C:\programmer\BearShareV6.exe\data045;Adware.Softomate;;
data045;C:\programmer\BearShareV6.exe;Archive contains infected objects;;
BearShareV6.exe;C:\programmer;Archive contains infected objects;Moved.;
data045\data006;C:\programmer\BearShareV6int.exe\data045;Adware.Softomate;;
data045;C:\programmer\BearShareV6int.exe;Archive contains infected objects;;
BearShareV6int.exe;C:\programmer;Archive contains infected objects;Moved.;
BSINSTALL.exe\data021;C:\programmer\BSINSTALL.exe;Adware.SearchAid.40;;
data027\clientax.dll;C:\programmer\BSINSTALL.exe\data027;Adware.Zango;;
data027;C:\programmer\BSINSTALL.exe;Archive contains infected objects;;
data030\data005;C:\programmer\BSINSTALL.exe\data030;Adware.Msearch;;
data030;C:\programmer\BSINSTALL.exe;Archive contains infected objects;;
BSINSTALL.exe;C:\programmer;Archive contains infected objects;Moved.;
cyfhqtml.exe.vir;C:\QooBox\Quarantine\C\WINDOWS\system32;Trojan.Starter.561;Deleted.;
lphc1s1j0endv.exe.vir;C:\QooBox\Quarantine\C\WINDOWS\system32;Trojan.Packed.566;Deleted.;
qavvgjsw.exe.vir;C:\QooBox\Quarantine\C\WINDOWS\system32;Trojan.Starter.561;Deleted.;
sysrest32.exe.vir;C:\QooBox\Quarantine\C\WINDOWS\system32;Trojan.Packed.557;Deleted.;
vaordunh.exe.vir;C:\QooBox\Quarantine\C\WINDOWS\system32;Trojan.Starter.561;Deleted.;
A0000005.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP2;Trojan.Packed.557;Deleted.;
A0002044.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP2;Trojan.Packed.566;Deleted.;
A0002049.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP2;Trojan.Starter.561;Deleted.;
A0002071.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP2;Trojan.Starter.561;Deleted.;
A0002074.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP2;Trojan.Starter.561;Deleted.;
A0006205.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006206.dll;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Proxy.3350;Deleted.;
A0006207.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006208.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006209.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006210.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006211.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Starter.384;Cured.;
A0006212.EXE;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Program.PsExec.170;Renamed.;
A0006213.exe\327882R2FWJFW\psexec.cfexe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006213.exe;Program.PsExec.171;;
A0006213.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7;Archive contains infected objects;Moved.;
A0006214.reg;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7;Trojan.StartPage.1505;Deleted.;
data045\data006;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006215.exe\data045;Adware.Softomate;;
data045;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006215.exe;Archive contains infected objects;;
A0006215.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7;Archive contains infected objects;Moved.;
data045\data006;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006216.exe\data045;Adware.Softomate;;
data045;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006216.exe;Archive contains infected objects;;
A0006216.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7;Archive contains infected objects;Moved.;
A0006217.exe\data021;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006217.exe;Adware.SearchAid.40;;
data027\clientax.dll;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006217.exe\data027;Adware.Zango;;
data027;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006217.exe;Archive contains infected objects;;
data030\data005;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006217.exe\data030;Adware.Msearch;;
data030;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7\A0006217.exe;Archive contains infected objects;;
A0006217.exe;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP7;Archive contains infected objects;Moved.;
psexec.#fexe;C:\ComboFix;Program.PsExec.171;;
A0006206.dll;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Trojan.Proxy.3350;Slettet.;
A0006212.#XE;C:\System Volume Information\_restore{4F3B614A-E164-4A3C-9497-97A7602927CA}\RP6;Program.PsExec.170;;
Endret av emva
Punkt 1:
Last ned Malwarebytes Anti-Malware til skrivebordet.
Kjør og installer programmet. Velg Norsk-språk
La programmet oppdatere seg og velg å kjør en 'hurtig systemscan', klikk Skann.
Det kommer en meldingsboks om at scannen er ferdig, klikk Ok
Klikk på 'Vis resultat'-knappen.Hvis det er funnet malware, vil du nå se hva som er funnet.
Klikk så på Fjern valgte -knappen for å fjerne malwaren som evt. ble funnet.
Det vil deretter åpnes en logg i notisblokk. Den kopiere du og poster senere.
Punkt 2:
Hent Combofix, og legg det på skrivebordet (Hent ny versjon som erstatter den du har fra før.)
Kjør combofix.exe, og følg veiledningen.
Du må ikke klikke på vinduet mens programmet kjører.
Post loggfilen fra combofix (c:\combofix.txt) + loggen fra MBAM
