Er det noen forskjell på DVD+RW og -RW ?
DVD+RW kan du skrive til så ofte du vil, men på DVD-RW må innholdet slettes før bruk.
DVD+RW supports random write access, which means that data can be added and removed without erasing the whole disc and starting over (up to about 1000 times). With suitable support from the operating system, DVD+RW media can thus be treated like a large floppy disk, in contrast to DVD-RW which must be erased before re-writing can take place.
