Silenoz Skrevet 19. mars 2003 Rapporter Del Skrevet 19. mars 2003 Vet ikke om dette er rett gruppe, men likevel: Jeg har modda xbox'en min, og satt inn en 80gig harddisk. Jeg har nå en 10 gig harddisk til overs, den som stod i når jeg kjøpte boksen. Jeg har en IDE kontroller ledig i PC'en min, så hvorfor ikke sette den inn. Problemet er at det er umulig å formatere den! Noen som vet hvordan? Lenke til kommentar
Nichlas Skrevet 19. mars 2003 Rapporter Del Skrevet 19. mars 2003 Disken er kryptert, og du må ha nøkkelen for å "låse" den opp. Du finner det du trenger å vite på www.xbox-scene.com Lenke til kommentar
KriZZ Skrevet 19. mars 2003 Rapporter Del Skrevet 19. mars 2003 Først last HD Unnlocker: http://dwl.xbox-scene.net/~xbox/xbox-scene...e/hddunlock.zip Then connect your original hdd to your xbox, using Evox, get your hdd password. (in the evolutionx dash go 'system utils' then 'backup' , this will make a directory called "backup" on the C drive of your xbox. "hddinfo.txt" will contain the HD key) Once you have it, It looks like this: 01:23:45:67:89:AB:CD:EF 01:23:45:67:89:AB:CD:EF 01:23:45:67:00:00:00:00 00:00:00:00:00:00:00:00 rewrite it as followed: 0123456789ABCDEF0123456789ABCDEF01234567 Yeah delete the last zeroes, and print it out, ull need it. Now you have to boot DOS (Bootdisk). Once downloaded execute it, enter a Floppy disk in ur computer. it will make that disk a boot disk. Then add the files: hdunlock.exe, hdunlock.pas, hddisabl.exe, and hdddisabl.pas to the bootdisk just created. Now, turn off your computer, set your xbox hdd to SLAVE, install your xbox hdd in your computer. Turn on your computer with bootdisk inserted, and it will ask you to press a key, then press a key, and you are in A:> Type in hdunlock and press enter Select your xbox hdd, and enter your hdd password it should say DONE Type in hddisabl Select oyur xbox hdd, and enter your xbox hdd password it should say DONE. Congratulations you have unlocked your xbox hdd for formatting. En annen måte og låse opp: Bruk TeamAssembly sin Config Magic. Dette er et program du legger inn på xboxen for og forandre på forskjellige innstilinger, som feks Låse/Låse opp hd. Sett inn dem gammle disken og legg inn Config Magic så velger du unlock HD så er den klar for formatering i pcen www.team-assembly.com Trenger du mer hjelp besøk #Xboxstuff.no @ Efnet 8) Lenke til kommentar
