BCCode: d1, osv. Bluescreen i Vista. Trenger hjelp.
Hei,
Kjørt vista 64 ultimate i 2-3 måneder problemfritt. Forleden dag satte jeg inn
to raptor disker i raid 0. Lastet ned alle oppdaterte driverne til IP 35 Pro (hovedkortet), 8800GTS (skjermkortet) og X-fi. Installerte systemet og driverne, alt fungerer fint.
E8400
IP 35 Pro
4gb Muskin
X-Fi Fatal1ty
2x Raptor 36,7gb
1x Maxtor 160gb
1x Maxtor 250gb
1x Seagate 200gb
1x WD 500gb
Thermaltake 400w PSU
Fikk opp blåskjerm med følgende feilkode 1-2 ganger under surfing på nettet, aldri mere fått den opp. Men når jeg spiller f.eks en gammel slager som Age of Empires 2, går det ca. 5-10 min før bluescreen på nytt kommer opp og restarter maskinen, slår aldri feil. Legger ved informasjon om feilen.
Noen kloke hoder som kan tolke noe ut av denne beskrivelsen?
Problemsignatur
Problemhendelsesnavn: BlueScreen
OS-versjon: 6.0.6001.2.1.0.256.1
ID for nasjonal innstilling: 1044
Filer som beskriver problemet (enkelte filer er kanskje ikke tilgjengelige lenger)
Mini081008-01.dmp
sysdata.xml
Version.txt
BCCode: d1
BCP1: 0000000000000010
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFFA6000E4CC5E
OS Version: 6_0_6001
Service Pack: 1_0
Feil som er registrert i vista: (Selv om jeg har installert driverne vista maser etter.
Download and install the driver for Intel ICH9
This problem was caused by Intel ICH9, which was created by Intel Corporation.
Solution
Download and install the driver for Intel ICH9 from the manufacturer's website:
Intel Corporation
Follow the directions on the manufacturer's website to install the driver for Intel ICH9.
Download and install the driver for your sound card
This problem was caused by your sound card, which was created by Creative Technology Ltd.
Solution
The model name of your sound card is SB X-Fi.
To download and install the driver for your sound card, go online and follow the instructions on the manufacturer's website:
This problem was caused by Abit Uguru Hardware monitoring chip, which was created by Universal ABIT Co. Ltd..
Solution
Download and install the driver for Abit Uguru Hardware monitoring chip from the manufacturer's website:
Follow the directions on the manufacturer's website to install the driver for Abit Uguru Hardware monitoring chip.
Svært takknemmelig for svar som kan hjelpe meg på vei.
Heisann igjen,
Har muligens funnet problemet, trodde først at dette var litt over mitt kunnskapsnivå men den knallgode analyserings guiden hjalp utrolig mye på. Posten er for øvrig sticky og jeg må ærlig innrømme at jeg ikke så den. Men søkte litt rundt så dukket den opp. (Link under)
https://www.diskusjon.no/index.php?showtopic=919442&st=0
Lastet ned analyseringsprogrammet og satte igang.
Rtlh64.sys - ser ut til å være synderen her. Og det kan stemme iogmed at det er under bruk av nettverket denne bluescreen oppstår.
Skal nå prøve å legge inn nye drivere for så å se om feilen forsvinner.
Tusen takk "fenderebest" for en flott guide. Anbefaler alle som får opp bluescreen å prøve dette.
