Jom-Jom Skrevet 9. august 2008 Del Skrevet 9. august 2008 Hei Bygde nettopp en ny pc som ser ut til å bli grei, men fikk plutselig problemer med at den slo seg av hver gang Win XP pro startet. Analyserte "krasjdumpen" med Win debugg og fikk dette svaret som jeg limer inn til slutt. Ærlig talt skjønner jeg veldig lite av det, så hvis noen kan se det med et lite blikk hadde det vært flott. Mvh Jom-Jom Could not read faulting driver name Probably caused by : EIO.sys ( EIO+1b6e ) Followup: MachineOwner --------- 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except, it must be protected by a Probe. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: a8270fee, memory referenced. Arg2: 00000000, value 0 = read operation, 1 = write operation. Arg3: 8052b8d0, If non-zero, the instruction address which referenced the bad memory address. Arg4: 00000000, (reserved) Debugging Details: ------------------ Could not read faulting driver name READ_ADDRESS: a8270fee FAULTING_IP: nt!READ_REGISTER_UCHAR+4 8052b8d0 8a02 mov al,byte ptr [edx] MM_INTERNAL_CODE: 0 CUSTOMER_CRASH_COUNT: 12 DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT BUGCHECK_STR: 0x50 PROCESS_NAME: ATKKBService.ex LAST_CONTROL_TRANSFER: from b6b93b6e to 8052b8d0 STACK_TEXT: b5da5bc4 b6b93b6e a8270fee b5da5bfc b6b93f49 nt!READ_REGISTER_UCHAR+0x4 WARNING: Stack unwind information not available. Following frames may be wrong. b5da5bd0 b6b93f49 8a178888 00000004 00000001 EIO+0x1b6e b5da5bfc b6b9325a 8a178888 830020ec 00000004 EIO+0x1f49 b5da5c40 804ef18f 8a2f1650 00000001 806e6410 EIO+0x125a b5da5c50 8057f982 8a2ecd60 897eaef8 8a2eccf0 nt!IopfCallDriver+0x31 b5da5c64 805807f7 8a1787d0 8a2eccf0 897eaef8 nt!IopSynchronousServiceTail+0x70 b5da5d00 80579274 000000a8 00000000 00000000 nt!IopXxxControlFile+0x5c5 b5da5d34 8054161c 000000a8 00000000 00000000 nt!NtDeviceIoControlFile+0x2a b5da5d34 7c90e4f4 000000a8 00000000 00000000 nt!KiFastCallEntry+0xfc 0087f3b8 00000000 00000000 00000000 00000000 0x7c90e4f4 STACK_COMMAND: kb FOLLOWUP_IP: EIO+1b6e b6b93b6e ?? ??? SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: EIO+1b6e FOLLOWUP_NAME: MachineOwner MODULE_NAME: EIO IMAGE_NAME: EIO.sys DEBUG_FLR_IMAGE_TIMESTAMP: 448fa23c FAILURE_BUCKET_ID: 0x50_EIO+1b6e BUCKET_ID: 0x50_EIO+1b6e Followup: MachineOwner Lenke til kommentar
