Gaute91 Skrevet 1. august 2008 Del Skrevet 1. august 2008 Hei! Jeg prøver å installere et webinterface (drqueueonrails) på min renderfarm (drqueue)... det er bassert på en ruby on rails kjerne... Jeg har installert alt og lagt alle filene i var/www og chown et det til www-data. Har også opprettet en virutal host og ruta routern til serveren min... likevell får jeg en 403 feil...Kan noen hjelpe meg? http://www.drqueue.org/ http://www.drqueue.org/project/wiki/DrQueueOnRails Gaute Lenke til kommentar
comicz Skrevet 1. august 2008 Del Skrevet 1. august 2008 ...og du har satt opp ruby on rails, da? Hva sier mongrel-loggen? Lenke til kommentar
Gaute91 Skrevet 1. august 2008 Forfatter Del Skrevet 1. august 2008 ruby on rails er satt opp... fulgte denne tutorialen her: http://www.urbanpuddle.com/articles/2008/0...-apache-version Mongrel loggene (vet ikke hvilken du trenger poster alle): Klikk for å se/fjerne innholdet nedenfor ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info.** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* Rails Error: Unable to access log file. Please ensure that /var/www/drqueueonrails/drqueueonrails/log/development.log exists and is chmod 0666. The log level has been raised to WARN and the output directed to STDERR until the problem is fixed. DEPRECATION WARNING: config.action_view.cache_template_extensions option has been deprecated and has no affect. Please remove it from your config files. See http://www.rubyonrails.org/deprecation for details. (called from send at /usr/lib/ruby/gems/1.8/gems/rails-2.1.0/lib/initializer.rb:455) ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `initialize': Permission denied - log/mongrel.pid (Errno::EACCES) from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `open' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `write_pid_file' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:132:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/command.rb:212:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:281 from /usr/bin/mongrel_rails:19:in `load' from /usr/bin/mongrel_rails:19 ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* Rails Error: Unable to access log file. Please ensure that /var/www/drqueueonrails/drqueueonrails/log/development.log exists and is chmod 0666. The log level has been raised to WARN and the output directed to STDERR until the problem is fixed. DEPRECATION WARNING: config.action_view.cache_template_extensions option has been deprecated and has no affect. Please remove it from your config files. See http://www.rubyonrails.org/deprecation for details. (called from send at /usr/lib/ruby/gems/1.8/gems/rails-2.1.0/lib/initializer.rb:455) ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `initialize': Permission denied - log/mongrel.pid (Errno::EACCES) from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `open' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:86:in `write_pid_file' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:132:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/command.rb:212:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:281 from /usr/bin/mongrel_rails:19:in `load' from /usr/bin/mongrel_rails:19 ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.pid and log/mongrel.log for info. ** Starting Mongrel listening at 0.0.0.0:3000 ** Starting Rails with development environment... ******************************************************************* * config.breakpoint_server has been deprecated and has no effect. * ******************************************************************* ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 0.0.0.0:3000 ** Writing PID file to log/mongrel.pid log/mongrel.pid = 5958 Klikk for å se/fjerne innholdet nedenfor ** Daemonized, any open files are closed. Look at log/mongrel.8000.pid and log/mongrel.8000.log for info.** Starting Mongrel listening at 127.0.0.1:8000 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `gem_original_require': no such file to load -- /var/www/drqueueonrails/config/environment (LoadError) from /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `require' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/rails.rb:147:in `rails' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:113:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `listener' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:99:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `initialize' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `new' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/command.rb:212:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:281 from /usr/bin/mongrel_rails:19:in `load' from /usr/bin/mongrel_rails:19 ** Daemonized, any open files are closed. Look at log/mongrel.8000.pid and log/mongrel.8000.log for info. ** Starting Mongrel listening at 127.0.0.1:8000 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8000 ** Writing PID file to log/mongrel.8000.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8000.pid and log/mongrel.8000.log for info. ** Starting Mongrel listening at 127.0.0.1:8000 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8000 ** Writing PID file to log/mongrel.8000.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8000.pid and log/mongrel.8000.log for info. ** Starting Mongrel listening at 127.0.0.1:8000 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8000 ** Writing PID file to log/mongrel.8000.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8000.pid and log/mongrel.8000.log for info. ** Starting Mongrel listening at 127.0.0.1:8000 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8000 ** Writing PID file to log/mongrel.8000.pid mongrel.8000.pid = 5992 Klikk for å se/fjerne innholdet nedenfor ** Daemonized, any open files are closed. Look at log/mongrel.8001.pid and log/mongrel.8001.log for info.** Starting Mongrel listening at 127.0.0.1:8001 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `gem_original_require': no such file to load -- /var/www/drqueueonrails/config/environment (LoadError) from /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `require' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/rails.rb:147:in `rails' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:113:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `listener' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:99:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `initialize' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `new' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/command.rb:212:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:281 from /usr/bin/mongrel_rails:19:in `load' from /usr/bin/mongrel_rails:19 ** Daemonized, any open files are closed. Look at log/mongrel.8001.pid and log/mongrel.8001.log for info. ** Starting Mongrel listening at 127.0.0.1:8001 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8001 ** Writing PID file to log/mongrel.8001.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8001.pid and log/mongrel.8001.log for info. ** Starting Mongrel listening at 127.0.0.1:8001 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8001 ** Writing PID file to log/mongrel.8001.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8001.pid and log/mongrel.8001.log for info. ** Starting Mongrel listening at 127.0.0.1:8001 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8001 ** Writing PID file to log/mongrel.8001.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8001.pid and log/mongrel.8001.log for info. ** Starting Mongrel listening at 127.0.0.1:8001 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8001 ** Writing PID file to log/mongrel.8001.pid log/mongrel.8001.pid = 5996 Klikk for å se/fjerne innholdet nedenfor ** Daemonized' date=' any open files are closed. Look at log/mongrel.8002.pid and log/mongrel.8002.log for info.** Starting Mongrel listening at 127.0.0.1:8002 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `gem_original_require': no such file to load -- /var/www/drqueueonrails/config/environment (LoadError) from /usr/local/lib/site_ruby/1.8/rubygems/custom_require.rb:27:in `require' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/rails.rb:147:in `rails' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:113:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:149:in `listener' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:99:in `cloaker_' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `call' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/configurator.rb:50:in `initialize' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `new' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:84:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/../lib/mongrel/command.rb:212:in `run' from /usr/lib/ruby/gems/1.8/gems/mongrel-1.1.5/bin/mongrel_rails:281 from /usr/bin/mongrel_rails:19:in `load' from /usr/bin/mongrel_rails:19 ** Daemonized, any open files are closed. Look at log/mongrel.8002.pid and log/mongrel.8002.log for info. ** Starting Mongrel listening at 127.0.0.1:8002 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8002 ** Writing PID file to log/mongrel.8002.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8002.pid and log/mongrel.8002.log for info. ** Starting Mongrel listening at 127.0.0.1:8002 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8002 ** Writing PID file to log/mongrel.8002.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8002.pid and log/mongrel.8002.log for info. ** Starting Mongrel listening at 127.0.0.1:8002 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8002 ** Writing PID file to log/mongrel.8002.pid ** TERM signal received. ** Daemonized, any open files are closed. Look at log/mongrel.8002.pid and log/mongrel.8002.log for info. ** Starting Mongrel listening at 127.0.0.1:8002 ** Initiating groups for "www-data":"www-data". ** Changing group to "www-data". ** Changing user to "www-data". ** Starting Rails with production environment... ** Rails loaded. ** Loading any Rails specific GemPlugins ** Signals ready. TERM => stop. USR2 => restart. INT => stop (no restart). ** Rails signals registered. HUP => reload (without restart). It might not work well. ** Mongrel 1.1.5 available at 127.0.0.1:8002 ** Writing PID file to log/mongrel.8002.pid log/mongrel.8002.pid = 5999 Klikk for å se/fjerne innholdet nedenfor Lenke til kommentar
Gaute91 Skrevet 1. august 2008 Forfatter Del Skrevet 1. august 2008 Kjører foresten med apache som server... så den loggfila sier: ErrorLog Klikk for å se/fjerne innholdet nedenfor [Fri Aug 01 00:33:21 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/[Fri Aug 01 00:34:49 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:34:50 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:35:26 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:38:59 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:43:15 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:43:28 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:49:41 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/favicon.ico [Fri Aug 01 00:49:58 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:54:23 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 00:57:36 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 01:02:07 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 01:12:08 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 11:55:04 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/public/404.html [Fri Aug 01 11:55:07 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/favicon.ico [Fri Aug 01 11:56:23 2008] [error] [client 192.168.1.1] client denied by server configuration: proxy:http://127.0.0.1:3000/ [Fri Aug 01 14:53:51 2008] [error] [client 67.159.44.138] client denied by server configuration: proxy:http://127.0.0.1:3000/, referer: http://farmmysql.blender3d.no/index.php Lenke til kommentar
comicz Skrevet 2. august 2008 Del Skrevet 2. august 2008 ...får vi se apache-configen din? Lenke til kommentar
Gaute91 Skrevet 2. august 2008 Forfatter Del Skrevet 2. august 2008 /etc/apache2/apache2.conf: Klikk for å se/fjerne innholdet nedenfor ## Based upon the NCSA server configuration files originally by Rob McCool. # # This is the main Apache server configuration file. It contains the # configuration directives that give the server its instructions. # See http://httpd.apache.org/docs/2.2/ for detailed information about # the directives. # # Do NOT simply read the instructions in here without understanding # what they do. They're here only as hints or reminders. If you are unsure # consult the online docs. You have been warned. # # The configuration directives are grouped into three basic sections: # 1. Directives that control the operation of the Apache server process as a # whole (the 'global environment'). # 2. Directives that define the parameters of the 'main' or 'default' server, # which responds to requests that aren't handled by a virtual host. # These directives also provide default values for the settings # of all virtual hosts. # 3. Settings for virtual hosts, which allow Web requests to be sent to # different IP addresses or hostnames and have them handled by the # same Apache server process. # # Configuration and logfile names: If the filenames you specify for many # of the server's control files begin with "/" (or "drive:/" for Win32), the # server will use that explicit path. If the filenames do *not* begin # with "/", the value of ServerRoot is prepended -- so "/var/log/apache2/foo.log" # with ServerRoot set to "" will be interpreted by the # server as "//var/log/apache2/foo.log". # ### Section 1: Global Environment # # The directives in this section affect the overall operation of Apache, # such as the number of concurrent requests it can handle or where it # can find its configuration files. # # # ServerRoot: The top of the directory tree under which the server's # configuration, error, and log files are kept. # # NOTE! If you intend to place this on an NFS (or otherwise network) # mounted filesystem then please read the LockFile documentation (available # at <URL:http://httpd.apache.org/docs-2.1/mod/mpm_common.html#lockfile>); # you will save yourself a lot of trouble. # # Do NOT add a slash at the end of the directory path. # ServerRoot "/etc/apache2" # # The accept serialization lock file MUST BE STORED ON A LOCAL DISK. # #<IfModule !mpm_winnt.c> #<IfModule !mpm_netware.c> LockFile /var/lock/apache2/accept.lock #</IfModule> #</IfModule> # # PidFile: The file in which the server should record its process # identification number when it starts. # This needs to be set in /etc/apache2/envvars # PidFile ${APACHE_PID_FILE} # # Timeout: The number of seconds before receives and sends time out. # Timeout 300 # # KeepAlive: Whether or not to allow persistent connections (more than # one request per connection). Set to "Off" to deactivate. # KeepAlive On # # MaxKeepAliveRequests: The maximum number of requests to allow # during a persistent connection. Set to 0 to allow an unlimited amount. # We recommend you leave this number high, for maximum performance. # MaxKeepAliveRequests 100 # # KeepAliveTimeout: Number of seconds to wait for the next request from the # same client on the same connection. # KeepAliveTimeout 15 ## ## Server-Pool Size Regulation (MPM specific) ## # prefork MPM # StartServers: number of server processes to start # MinSpareServers: minimum number of server processes which are kept spare # MaxSpareServers: maximum number of server processes which are kept spare # MaxClients: maximum number of server processes allowed to start # MaxRequestsPerChild: maximum number of requests a server process serves <IfModule mpm_prefork_module> StartServers 5 MinSpareServers 5 MaxSpareServers 10 MaxClients 150 MaxRequestsPerChild 0 </IfModule> # worker MPM # StartServers: initial number of server processes to start # MaxClients: maximum number of simultaneous client connections # MinSpareThreads: minimum number of worker threads which are kept spare # MaxSpareThreads: maximum number of worker threads which are kept spare # ThreadsPerChild: constant number of worker threads in each server process # MaxRequestsPerChild: maximum number of requests a server process serves <IfModule mpm_worker_module> StartServers 2 MaxClients 150 MinSpareThreads 25 MaxSpareThreads 75 ThreadsPerChild 25 MaxRequestsPerChild 0 </IfModule> # These need to be set in /etc/apache2/envvars User ${APACHE_RUN_USER} Group ${APACHE_RUN_GROUP} # # AccessFileName: The name of the file to look for in each directory # for additional configuration directives. See also the AllowOverride # directive. # AccessFileName .htaccess # # The following lines prevent .htaccess and .htpasswd files from being # viewed by Web clients. # <Files ~ "^\.ht"> Order allow,deny Deny from all </Files> # # DefaultType is the default MIME type the server will use for a document # if it cannot otherwise determine one, such as from filename extensions. # If your server contains mostly text or HTML documents, "text/plain" is # a good value. If most of your content is binary, such as applications # or images, you may want to use "application/octet-stream" instead to # keep browsers from trying to display binary files as though they are # text. # DefaultType text/plain # # HostnameLookups: Log the names of clients or just their IP addresses # e.g., www.apache.org (on) or 204.62.129.132 (off). # The default is off because it'd be overall better for the net if people # had to knowingly turn this feature on, since enabling it means that # each client request will result in AT LEAST one lookup request to the # nameserver. # HostnameLookups Off # ErrorLog: The location of the error log file. # If you do not specify an ErrorLog directive within a <VirtualHost> # container, error messages relating to that virtual host will be # logged here. If you *do* define an error logfile for a <VirtualHost> # container, that host's errors will be logged there and not here. # ErrorLog /var/log/apache2/error.log # # LogLevel: Control the number of messages logged to the error_log. # Possible values include: debug, info, notice, warn, error, crit, # alert, emerg. # LogLevel warn # Include module configuration: Include /etc/apache2/mods-enabled/*.load Include /etc/apache2/mods-enabled/*.conf # Include all the user configurations: Include /etc/apache2/httpd.conf # Include ports listing Include /etc/apache2/ports.conf # # The following directives define some format nicknames for use with # a CustomLog directive (see below). # If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i # LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined LogFormat "%h %l %u %t \"%r\" %>s %b" common LogFormat "%{Referer}i -> %U" referer LogFormat "%{User-agent}i" agent # # ServerTokens # This directive configures what you return as the Server HTTP response # Header. The default is 'Full' which sends information about the OS-Type # and compiled in modules. # Set to one of: Full | OS | Minor | Minimal | Major | Prod # where Full conveys the most information, and Prod the least. # ServerTokens Full # # Optionally add a line containing the server version and virtual host # name to server-generated pages (internal error documents, FTP directory # listings, mod_status and mod_info output etc., but not CGI generated # documents or custom error documents). # Set to "EMail" to also include a mailto: link to the ServerAdmin. # Set to one of: On | Off | EMail # ServerSignature On # # Customizable error responses come in three flavors: # 1) plain text 2) local redirects 3) external redirects # # Some examples: #ErrorDocument 500 "The server made a boo boo." #ErrorDocument 404 /missing.html #ErrorDocument 404 "/cgi-bin/missing_handler.pl" #ErrorDocument 402 http://www.example.com/subscription_info.html # # # Putting this all together, we can internationalize error responses. # # We use Alias to redirect any /error/HTTP_<error>.html.var response to # our collection of by-error message multi-language collections. We use # includes to substitute the appropriate text. # # You can modify the messages' appearance without changing any of the # default HTTP_<error>.html.var files by adding the line: # # Alias /error/include/ "/your/include/path/" # # which allows you to create your own set of files by starting with the # /usr/share/apache2/error/include/ files and copying them to /your/include/path/, # even on a per-VirtualHost basis. The default include files will display # your Apache version number and your ServerAdmin email address regardless # of the setting of ServerSignature. # # The internationalized error documents require mod_alias, mod_include # and mod_negotiation. To activate them, uncomment the following 30 lines. # Alias /error/ "/usr/share/apache2/error/" # # <Directory "/usr/share/apache2/error"> # AllowOverride None # Options IncludesNoExec # AddOutputFilter Includes html # AddHandler type-map var # Order allow,deny # Allow from all # LanguagePriority en cs de es fr it nl sv pt-br ro # ForceLanguagePriority Prefer Fallback # </Directory> # # ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var # ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var # ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var # ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var # ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var # ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var # ErrorDocument 410 /error/HTTP_GONE.html.var # ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var # ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var # ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var # ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var # ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var # ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var # ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var # ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var # ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var # ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var # Include of directories ignores editors' and dpkg's backup files, # see README.Debian for details. # Include generic snippets of statements Include /etc/apache2/conf.d/ # Include the virtual host configurations: Include /etc/apache2/sites-enabled/ ServerName 'Gaute' NameVirtualHost *:80 <IfModule mod_ssl.c> NameVirtualHost *:443 </IfModule> virtual host: /etc/apache2/sites-avaible/drqueue: Klikk for å se/fjerne innholdet nedenfor <VirtualHost *:80> DocumentRoot /var/www/drqueueonrails ServerName renderfarm ServerAlias farm.blender3d.no Setenv VLOG /var/www/drqueueonrails ErrorLog /var/www/drqueueonrails/ErrorLog Timeout 1200 ProxyTimeout 1200 XSendFile on XSendFileAllowAbove on # SSLEngine on # SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL # SSLCertificateFile /etc/apache2/ssl/server.crt # SSLCertificateKeyFile /etc/apache2/ssl/server.key AddDefaultCharset utf-8 <Directory /var/www/drqueueonrails/drqueueonrails/public> Options +FollowSymLinks Options +SymLinksIfOwnerMatch AllowOverride All </Directory> RewriteEngine On ProxyPass /images ! ProxyPass /stylesheets ! ProxyPass /player ! ProxyPass /javascripts ! ProxyPass /upload ! Alias /images /var/www/drqueueonrails/DrQueueOnRails/public/images Alias /stylesheets /var/www/drqueueonrails/DrQueueOnRails/public/stylesheets Alias /player /var/www/drqueueonrails/DrQueueOnRails/public/player Alias /javascripts /var/www/drqueueonrails/DrQueueOnRails/public/javascripts Alias /upload /var/www/drqueueonrails/DrQueueOnRails/public/upload ProxyPass / http://127.0.0.1:3000/ ProxyPassReverse / http://127.0.0.1:3000/ ProxyPreserveHost on ProxyRequests Off # RequestHeader set X_FORWARDED_PROTO 'https' </VirtualHost> Egentlig er det oppsett for ssl innebygd, men jeg har deaktivert det og for å unngå feilmeldinger har jeg bare satt en # forann alle de tilhørende kommandoene... Lenke til kommentar
comicz Skrevet 2. august 2008 Del Skrevet 2. august 2008 ...får vi se din .htaccess-fil? "AllowOverride All" tilsier at du har en :--) Lenke til kommentar
Gaute91 Skrevet 2. august 2008 Forfatter Del Skrevet 2. august 2008 den har jeg ikke tenkt på... kanskje det er noe i den: /var/www/drqueueonrails/drqueueonrails/public/.htaccess: Klikk for å se/fjerne innholdet nedenfor # General Apache optionsAddHandler fastcgi-script .fcgi AddHandler cgi-script .cgi Options +FollowSymLinks +ExecCGI # If you don't want Rails to look in certain directories, # use the following rewrite rules so that Apache won't rewrite certain requests # # Example: # RewriteCond %{REQUEST_URI} ^/notrails.* # RewriteRule .* - [L] # Redirect all requests not available on the filesystem to Rails # By default the cgi dispatcher is used which is very slow # # For better performance replace the dispatcher with the fastcgi one # # Example: # RewriteRule ^(.*)$ dispatch.fcgi [QSA,L] RewriteEngine On # If your Rails application is accessed via an Alias directive, # then you MUST also set the RewriteBase in this htaccess file. # # Example: # Alias /myrailsapp /path/to/myrailsapp/public # RewriteBase /myrailsapp RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ dispatch.cgi [QSA,L] # In case Rails experiences terminal errors # Instead of displaying this message you can supply a file here which will be rendered instead # # Example: # ErrorDocument 500 /500.html ErrorDocument 500 "<h2>Application error</h2>Rails application failed to start properly" Lenke til kommentar
comicz Skrevet 2. august 2008 Del Skrevet 2. august 2008 Legg til order deny, allow deny from all allow from 192.168.1.0/24 127.0.0.1 i htaccess-filen din, tipper det går bedre da :-) Lenke til kommentar
Gaute91 Skrevet 2. august 2008 Forfatter Del Skrevet 2. august 2008 har lagt det til men virker fortsatt ikke... har prøvd å sette none på allowoverride, men virker fortsatt ikke.. Lenke til kommentar
Gaute91 Skrevet 3. august 2008 Forfatter Del Skrevet 3. august 2008 Har du noen idé om hva som kan være galt? Lenke til kommentar
comicz Skrevet 3. august 2008 Del Skrevet 3. august 2008 Sett AllowOverride None i apache-conf og legg til linjene jeg skrev over rett under det, altså inni Directory-direktivet/taggen. ...om ikke er jeg litt usikker. Lenke til kommentar
Gaute91 Skrevet 4. august 2008 Forfatter Del Skrevet 4. august 2008 Nå funker det... satt AllowOverride til none, men endret litt på koden din Order allow,deny allow from all Da funker det.. Håper ikke jeg har åpnet et sikkerhetshull nå? Så gjenstår det bare å reprodusere alt på den virkelige serveren :S Gaute Lenke til kommentar
comicz Skrevet 4. august 2008 Del Skrevet 4. august 2008 Hurra! Nei, det er greit, den hadde måttet endres uansett, og var jo bare gjetning fra min side. Lenke til kommentar
Gaute91 Skrevet 4. august 2008 Forfatter Del Skrevet 4. august 2008 takk for hjelpen Lenke til kommentar
comicz Skrevet 5. august 2008 Del Skrevet 5. august 2008 Bare hyggelig, godt å høre det gikk i orden :--) Lenke til kommentar
