Virus som slår ut en HD?
Vet ikke helt men jeg fikk denne mailen fra en venn.
READ IMMEDIATELY AND PASS ON TO EVERYONE YOU KN
Someone is sending out a very cute screensaver of the
Budweiser Frogs. If you download it, you will lose
everything! Your hard drive will crash
and someone from the Internet will get your screen
name and password! DO
NOT DOWNLOAD IT UNDER ANY CIRCUMSTANCES!
It just went into circulation yesterday. Please
distribute this
message.This is a new, very malicious virus and not
many people know about
it. This information was announced yesterday morning
from Microsoft.
Please share it with everyone that might access the
Internet. Once again, Pass This Along To EVERYONE in
your address book so that this
may be stopped. AOL has said that this is a very
dangerous virus and that
there is NO remedy for it at this time.
This is VERY important. If you receive a screen saver
from a friend or
anyone you may not know with the Budweiser Frogs in
it, DO NOT DOWNLOAD IT
OR OPEN THE FILE! Press the forward button on your
email program and send this notice to EVERYONE you
know. Let's keep our email safe for everyone.
Kanskje det stemmer likevel.
distribute this
from Microsoft.
from a friend or
Bare tull etter det jeg forstår.
http://www.breakthechain.org/exclusives/budfrogs.html
This warning is not true. In fact some of the text is identical to Win A Holiday and other virus hoaxes.
Hørt rykter om virus som slår ut hd'er, er dette riktig eller myte? Mistet en wd80 etter et virusangrep som tok mbr'ene mine, eller er det bare en fysisk feil på disken??
Ja det finnes viruser som kan ødelegge diskene og andre ting på systemet ditt, men det er skjelden du opplever det. Du må bare ha et antivirus software installer feks norton 2003.
Da er du neste garrantert at du aldri vil få virus på pc'en din? Selv har eg aldri hatt virus på mine hd'er.
En kollega satt og spilte Cm3 en kveld, slo av maskinen og gikk og la seg.
Neste dag når han skulle starte pc'en igjen, vips; så var allting borte. Partition Magic's boot-disketter viste en helt tom harddisk! Har ikke funnet ut hva det kan være, er det noen som vet hvordan dette kan skje? Er det sånn at et virus bare kan "formatere" hele disken når den skal boote?
distribute this
from Microsoft.
from a friend or
Det er dette som er et virus.
Tsjernobyl var vel et av de første store MBR virusene, men ikke noe problem å bli kvitt.
Nei, dette er ikke et virus. Bruk 4 sekunder på Google så finner du ut det:
Type
Virus hoax
Description
In 1997 the Budweiser beer company placed a screensaver on their website depicting the Budweiser frogs from their advertising campaign. Shortly afterwards an email began circulating warning people not to download the file:
DANGER!!!VIRUS ALERT!!! This is a new twist. Someone is sending out a very desirable screen-saver the Budweiser Frogs. But if you download it, you will lose everything!!! Your hard drive will crash!!! DON'T DOWNLOAD THIS UNDER ANY CIRCUMSTANCES!!! IT JUST WENT INTO CIRCULATION YESTERDAY, AS FAR AS WE KNOW....BE CAREFUL. PLEASE DISTRIBUTE THIS TO AS MANY PEOPLE AS POSSIBLE... This is WHAT THE SCREENSAVER OFFER WOULD LOOK LIKE! File: BUDSAVER.EXE (24643 bytes) DL Time (28800 bps):
At the time of writing, there is no known virus (or more correctly Trojan horse) which masquerades as a Budweiser Frogs screensaver. However, users should always be very cautious when downloading or using executables of unknown origin.
Fra http://www.sophos.com/virusinfo/hoaxes/bud...eiserfrogs.html
Vel, det vertste som et virus kan gjøre med en HD er å skrive over filene. Da er det ingen mulighet å få de tilbake. Det nest verste er nok at virus kan skrive over FAT'en eller bootsektoren. Da blir det litt vanskelig å få ut data men det går etter mye tidkrevende slit. Uansett hvilket av disse som skjer så er det alltid mulighet for å partisjonere og formatere disken på nytt.
Men det finnes faktisk noe farligere:
Det er de virusene (ala chernobyl) som flasher bios eller firmware med gale data. (hovedkort, skjermkort, CD-rom'er, harddisker osv) Da kan du i verste fall ikke få liv i komponenten igjen og rett og slett må kjøpe nytt.
Heldigvis er disse virusene skjeldne og det finnes "diehard-bioser" og flash-advarsler.
