Hvordan streame fra WHS til DM?
Haha, En av dei postene som virkeligen får meg til å dra på smilebåndet :)
Nå har jeg ikke satt opp video streaming til min db, kun musikk filer, opptak funger også.
Du kan jo stikke over til digsat sine nettsider, er nok enklere å få hjelp der. Her har du noe å starte med som jeg sakset derfra.
<?xml version="1.0" encoding="iso-8859-1"?>
<?xml-stylesheet type="text/xsl" href="/XSLMPSettings.xsl"?>
<vlc>
<server ip="192.168.1.10" webif-port="8080" stream-port="9090" user="admin" pass="admin" />
<config startdir="c:/movies" cddrive="d:" />
<codec mpeg1="mpgv" mpeg2="mp2v" audio="mpga" />
<setup name="SVCD" ext="NONE" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mpeg2" Videosize="352x576" Audiorate="192" Audiotranscode="0" />
<setup name="VCD" ext="NONE" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mpeg1" Videosize="352x576" Audiorate="192" Audiotranscode="0" />
<setup name="DVD" ext="NONE" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mp2v" Videosize="704x576" Audiorate="192" Audiotranscode="1" />
<setup name="File" ext="MPG" Videorate="1000" fps="25" Videotranscode="1" Videocodec="mp2v" Videosize="704x576" Audiorate="192" Audiotranscode="1" />
<setup name="File" ext="MPEG" Videorate="1000" fps="25" Videotranscode="1" Videocodec="mp2v" Videosize="704x576" Audiorate="192" Audiotranscode="1" />
<setup name="File" ext="M2P" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mpgv" Videosize="704x576" Audiorate="192" Audiotranscode="0" />
<setup name="File" ext="MPV" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mpgv" Videosize="704x576" Audiorate="192" Audiotranscode="0" />
<setup name="File" ext="DAT" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mpgv" Videosize="704x576" Audiorate="192" Audiotranscode="0" />
<setup name="File" ext="AVI" Videorate="2048" fps="25" Videotranscode="1" Videocodec="mp2v" Videosize="704x576" Audiorate="192" Audiotranscode="1" />
<setup name="File" ext="ASF" Videorate="1000" fps="25" Videotranscode="1" Videocodec="mpgv" Videosize="704x576" Audiorate="192" Audiotranscode="1" />
<setup name="File" ext="TS" Videorate="1000" fps="25" Videotranscode="0" Videocodec="mp2v" Videosize="704x576" Audiorate="192" Audiotranscode="0" />
</vlc>
Kopier inneholdet over til en file som du kaller: movieplayer_My_Server.xml
(Husk å bruke en *nix kompatibel editor)
Endre verdiene (linje 4) for Server IP Adressen (til IP på PC du vil streame fra), StartDir (Hvor ligger filene du vil streame på PCen) og CDDrive (CD/DVD på PCen).
Så FTPer du denne filen over DBen i katalogen /var/etc
Nå starter du VLC på PCen og velger:
- File
- Open Network Stream
Ned i dette vinduet finner du Advanced options
- Velg Stream/Save
- Velg Settings
- Velg HTTP
- Sett port 9090 for HTTP
- Velg MPEG TS
- Velg Video Codec > mp2v
- Velg Audio Codec > mpga
Så lagrer du instillingene ved å velge OK + OK
Til slutt aktiviserer du WEBIF i VLC, ved å velge Settings + Add Interface + WEB Interface.
OK, nå er dere klar for streaming til DB!
På DB trenger man VLC Frontend (Ligger i PP + kan hentes fra Download i Image)
Etter at denne VLC Frontend Plugin er startet, velg Settings.
Her velger man hvilken file man vil bruke med innstillinger..
- Velg movieplayer_My_Server.xml
- Velg Switch
Du får nå beskjed om å restarte VLC Frontend, gjør dette ved å trykke Exit til du er ute i Plugin menyen igjen.
Så starter du VLC Frontend igjen. Nå velger du File (Rød knapp).
Du skal nå kunne se DivX filene som du har i katalogen på PCen. (Ref. STARTDIR i filen man har laget over)
Velg filen man vil se, vent litt mens den "cache'r" dataen... Så kommer bildet etter noen sekunder.
PS! Man bør ha en "nyere" PC for at dette skal funke "smertefritt"!
<vlc>
</vlc>
- File
- Velg Stream/Save
- Velg Settings
- Velg HTTP
- Velg MPEG TS
- Velg Switch
Takker for den....
Vært innom, men venter enda på hvordan dette eksakt gjøres. Hørt på at det kan og ikke kan gjøres.
Skal se litt nærmere på oppsettet.
Gjelder samme oppsettet for musikk og opptakk og - som du kun har vært innom?
Trodde han mente fra video spiller :)Sorry for den :) Da er det ikke noe prob Fra pc eller dvd/cd :)alt ligger forklart på digsat sine sider ,,,lykke til :)
Her også kan du se litt Guider :) om det.http://dreambox.ingmar.dk/Eguide.asp Endret av Whiskas
