**AVSLUTTET**Finner ikke driver til lydkortet mitt - Realtek AC'97
Du får nok ikke pakket den ut i den mappen fordi du ikke har skriverettigheter der.
Du kan enten kopiere den til hjemmekatalogen først, eller så kan du manøvrere deg frem i terminal og lese den vha. zcat og less :
cd /usr/share/doc/alsa-base/driver
zcat ALSA-Configuration.txt.gz | less
Under "Module snd-intel8x0" (driveren du bruker, ref din lsmod tidligere) i filen står det følgende:
"ac97_quirk - AC'97 workaround for strange hardware
See "AC97 Quirk Option" section below. "
Og der står følgende:
AC97 Quirk Option
The ac97_quirk option is used to enable/override the workaround for
specific devices on drivers for on-board AC'97 controllers like
snd-intel8x0. Some hardware have swapped output pins between Master
and Headphone, or Surround (thanks to confusion of AC'97
specifications from version to version :-)
The driver provides the auto-detection of known problematic devices,
but some might be unknown or wrongly detected. In such a case, pass
the proper value with this option.
The following strings are accepted:
- default Don't override the default setting
- none Disable the quirk
- hp_only Bind Master and Headphone controls as a single control
- swap_hp Swap headphone and master controls
- swap_surround Swap master and surround controls
- ad_sharing For AD1985, turn on OMS bit and use headphone
- alc_jack For ALC65x, turn on the jack sense mode
- inv_eapd Inverted EAPD implementation
- mute_led Bind EAPD bit for turning on/off mute LED
For backward compatibility, the corresponding integer value -1, 0,
... are accepted, too.
For example, if "Master" volume control has no effect on your device
but only "Headphone" does, pass ac97_quirk=hp_only module option.
Her kan det sikkert være noe av interesse? :)
Endret av NorthWave
Skulle ønske jeg kunne svare ja, men ingenting hjelper...
Kan du forklare nærmere denne delen: "For example, if "Master" volume control has no effect on your device
but only "Headphone" does, pass ac97_quirk=hp_only module option."
Slik jeg forstår det er det bare å taste inn:
"ac97_quirk=hp_only" i kommandolinjen....
Nå er jeg ikke 100% sikker på hvordan ting gjøres i Ubuntu, men i Fedora som jeg bruker, ligger disse innstillingene i /etc/modprobe.conf
Min inneholder denne linja :
options snd_intel8x0 ac97_quirk=2
Er ikke 100% sikker på hva den gjør, men gir ihvertfall mye bedre lyd enn når den ikke er der.. (mye bedre lyd enn jeg fikk i Windows også)
Så, du legger dermed inn i samme fila (som root) :
options snd_intel8x0 ac97_quirk=hp_only
Edit: når man teller fra 0 på den listen NorthWave kom med, så tyder ting på at "2" faktisk er det samme som hp_only :p
Endret av Sokkalf^
min ligger i denne banen: /usr/share/man/man5
og min fil med det navnet har en litt annen ending:
modprobe.conf.5.gz, og igjen måtte jeg åpne den i terminalen, og der får jeg ikke redigert en drit, selv om jeg er root, får kun legge inn "log file"
Når jeg prøver å legge den direkte inn i terminalen får jeg beskjed om at "command not found"
Endret av Skogli
Den fila du prøver å redigere der er manualen til modprobe.conf. Du kan jo prøve å lese den (med kommandoen "man modprobe.conf")
Kanskje den gir en pekepinn på hvordan ting skal gjøres i Ubuntu. (Kanskje er det så lett at du bare trenger å lage fila /etc/modprobe.conf)
Vel, skulle gjerne ha gjort det, men med min kunnskap om Ubuntu så klarer jeg det rett og slett ikke...
jeg lager filen, men får ikke laste den inn til /etc/ fordi jeg har ikke tilgang... Hvor i helvete får jeg tilgang fra når jeg er adminkonto? hehe.
Det var da veldig så sta min data var i dag da...
"anders@indigo:~$ sudo nautilus
[sudo] password for anders:
Initializing nautilus-share extension
seahorse nautilus module initialized
Segmentation fault"
Fortsatt ingen tilgang på etc-mappen
Endret av Skogli
  • 3 uker senere...
