Mala Skrevet 1. november 2008 Del Skrevet 1. november 2008 På den dashboard, er det noe som lagres på pcen? er ikke på min pc, så vil ikke laste noe ned på den Alt går via xbox 360 uten om registreringen da. Lenke til kommentar
Joananas Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) Tror ikke man blir bannet for å ha updaten.. Fant ihvertfall dette (som virker troverdig) på en ikke-så-ukjent torrent side: The Xbox 360 Fall Flash update will be available to you by 8pm PST on October 30th (11pm EST on October 30th, 3am GMT on October 31st). While exploring the New Xbox Experience (NXE), you may come across bugs or have some suggestions. Please share those with us by going to Microsoft Connect and clicking on the Feedback link. If you would like to post comments regarding your experiences with the New Xbox Experience, or interact with other preview participants please use the Newsgroups link on the connect site. Although we are monitoring the newsgroups, all bugs and suggestions should be filed using the Feedback link. If you need technical assistance with the Xbox 360 Fall Flash and you're in the US or Canada and speak English; you can call 877-783-1507. Phone lines will be open between the hours of 8am and 6pm CST. Please do not publish or share this phone number with people that are not participating in the Preview Program ============================ In participation with this program, you should not move your storage device (hard drive, or memory unit if you do not have a hard drive) to any other console as it will also update that console. If an unregistered console is updated with the NXE update, that console will not be able to connect to Xbox LIVE until the NXE has been officially released on November 19th. ============================ Please remember that your participation in the Public Preview Program is subject to the Xbox LIVE Terms of Use. We thank you for your participation and hope that you enjoy the New Xbox Experience. See you online, The Xbox 360 team Endret 1. november 2008 av joananas Lenke til kommentar
Gjest Bruker-127711 Skrevet 1. november 2008 Del Skrevet 1. november 2008 jeg gir opp jeg.. forstår ingenting.. begynner å bli irritert fordi jeg ikke for det til Lenke til kommentar
kewell79 Skrevet 1. november 2008 Del Skrevet 1. november 2008 jeg gir opp jeg.. forstår ingenting.. begynner å bli irritert fordi jeg ikke for det til Listen carefully, i will only say this wens (Allo Allo humor) du har vel ikke registrert deg første gangen, og da er det ingenting du kan gjøre nå! Lenke til kommentar
tc47 Skrevet 1. november 2008 Del Skrevet 1. november 2008 jeg gir opp jeg.. forstår ingenting.. begynner å bli irritert fordi jeg ikke for det til Listen carefully, i will only say this wens (Allo Allo humor) du har vel ikke registrert deg første gangen, og da er det ingenting du kan gjøre nå! Det er vel noe, men det blir vel ikke lovlig. Lenke til kommentar
Gjest Bruker-127711 Skrevet 1. november 2008 Del Skrevet 1. november 2008 Da venter jeg til den 19.. må ha online:P Lenke til kommentar
Atald Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) ... Endret 1. november 2008 av Atald Lenke til kommentar
kewell79 Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) "smarting" du Atald.... kanskje du burde hatt en titt på serien jeg nevner Endret 1. november 2008 av kewell79 Lenke til kommentar
kewell79 Skrevet 1. november 2008 Del Skrevet 1. november 2008 jeg gir opp jeg.. forstår ingenting.. begynner å bli irritert fordi jeg ikke for det til vist du tenker på den filen, så er det lett, sjekk bildet, så ser du hvor MAPPEN skal legges, så skrur du på 360 og da setter du inn minnepennen/CD og får beskjed om å oppdatere have fun without xbox LIVE Lenke til kommentar
Joananas Skrevet 1. november 2008 Del Skrevet 1. november 2008 Blir jo "I will say this only once / I will only say this once og ikke "I will only say this only once" uansett.. Rettingfail. Lenke til kommentar
tc47 Skrevet 1. november 2008 Del Skrevet 1. november 2008 Men er det noen som kan bekrefte/vet at man faktisk får tilbake Live 19.nov da? Eller er det bare det man tror? Lenke til kommentar
TheGizmo Skrevet 1. november 2008 Del Skrevet 1. november 2008 http://digiex.net/homebrew/594-xbox-360-nx...y-download.html Litt mer om hva og hvordan med video Lenke til kommentar
tc47 Skrevet 1. november 2008 Del Skrevet 1. november 2008 "You cannot create an avatar until the 19th, this requires another download after you install the NXE dashboard" Tror jeg venter til 19. Pluss at hvis jeg gjør det så får jeg jo ikke spilt Gears 2 coop med en venn over Live Lenke til kommentar
Joananas Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) Men er det noen som kan bekrefte/vet at man faktisk får tilbake Live 19.nov da? Eller er det bare det man tror? Det som er blitt sagt er at man ikke får logge på fordi man ikke er på VIP-lista til Microsoft hvis man har skaffet seg updaten et annet sted.. Men 19. november blir jo "alle" VIP-listet derfor burde det gå glatt. Laster den ikke ned selv fordi jeg vil glede meg edit: leif Endret 1. november 2008 av joananas Lenke til kommentar
head_hunter Skrevet 1. november 2008 Del Skrevet 1. november 2008 Viss du laster ned NXE på linken til TheGizmo kan du ikke lage avatar, og heller ikke spille live til 19nov. THIS UPDATE WILL DISABLE YOUR CONSOLES XBOX LIVE ACCESS UNTIL NOVEMBER 19TH! You cannot create an avatar until the 19th, this requires another download after you install the NXE dashboard Går det an og slette updaten etter du har lastet den ned? Lenke til kommentar
tc47 Skrevet 1. november 2008 Del Skrevet 1. november 2008 Jepp skjønte det jonanas Jeg venter jeg og, må ha Live uansett! Lenke til kommentar
Atald Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) "smarting" du Atald.... kanskje du burde hatt en titt på serien jeg nevner Ikke helt våken der, beklager det. Har sett serien, men det første jeg kom på var Michelle fra le resistance som sa det, og da var det jeg skrev riktig. Skjønner ikke at jeg ikke tenkte på René. Om man laster den ned uoffisielt, vil man få igjen Live-tilgangen 19. november eller er dette bare antagelser? Endret 1. november 2008 av Atald Lenke til kommentar
tc47 Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) Les hva joananas sa, det er vel det mest logiske. Endret 1. november 2008 av tc47 Lenke til kommentar
kewell79 Skrevet 1. november 2008 Del Skrevet 1. november 2008 (endret) Blir jo "I will say this only once / I will only say this once og ikke "I will only say this only once" uansett.. Rettingfail. Les hva joananas sa, det er vel det mest logiske. jasså.... Rettingfail? Endret 1. november 2008 av kewell79 Lenke til kommentar
