BjornK Skrevet 13. juli 2008 Del Skrevet 13. juli 2008 Hei, jeg har en Toshiba Satellite Pro A200 med Atheros AR5BXB63 wifi-brikke. Har deaktiver HAL-driverne i "Hardware Drivers" men alikevel har de status "I bruk" Har innstalert http://snapshots.madwifi.org/special/madwi...6+ar5007.tar.gz Når jeg starter opp Ubuntu kan jeg bruke eth0 (LAN) men ikke ath0 (WLAN). Men hvis jeg går til terminal og skriver "sudo /etc/init.d/networking restart" så er alt i orden. /etc/modules: fuse lp sbp2 ath_pci /etc/network/interfaces auto lo iface lo inet loopback iface ath0 inet static address 192.168.5.61 network 192.168.5.0 netmask 255.255.255.0 broadcast 192.168.5.255 wireless-key xxxxxxxxxxxxxxxxxxxxxxxxxx wireless-essid xxxx pre-up iwpriv ath0 authmode 2 post-up route add default gw 192.168.5.1 auto ath0 auto eth0 iface eth0 inet static address 192.168.5.60 network 192.168.5.0 netmask 255.255.255.0 broadcast 192.168.5.255 gateway 192.168.5. dmesg: [ 35.457213] ath_hal: module license 'Proprietary' taints kernel. [ 35.471734] ath_hal: 0.10.2.2-ATHEROS (AR5210, AR5211, AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2133, RF2425) [ 35.554744] wlan: trunk [ 35.591889] ath_pci: trunk [ 35.591968] ACPI: PCI Interrupt 0000:05:00.0[A] -> GSI 18 (level, low) -> IRQ 18 [ 35.591988] PCI: Setting latency timer of device 0000:05:00.0 to 64 [ 36.084523] MadWifi: ath_attach: Switching rfkill capability off [ 36.124370] ath_rate_sample: 1.2 (trunk) [ 36.124729] MadWifi: ath_attach: Switching per-packet transmit power control off [ 36.125273] wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps [ 36.125277] wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps [ 36.125284] wifi0: H/W encryption support: WEP AES AES_CCM TKIP [ 36.125291] wifi0: ath_announce: Use hw queue 1 for WME_AC_BE traffic [ 36.125293] wifi0: ath_announce: Use hw queue 0 for WME_AC_BK traffic [ 36.125295] wifi0: ath_announce: Use hw queue 2 for WME_AC_VI traffic [ 36.125296] wifi0: ath_announce: Use hw queue 3 for WME_AC_VO traffic [ 36.125298] wifi0: ath_announce: Use hw queue 8 for CAB traffic [ 36.125300] wifi0: ath_announce: Use hw queue 9 for beacons [ 36.137509] ath_pci: wifi0: Atheros 5424/2424: mem=0xf4000000, irq=18 [ 36.205224] Adding 2000052k swap on /dev/sda5. Priority:-1 extents:1 across:2000052k [ 36.761113] EXT3 FS on sda3, internal journal [ 37.959352] ip_tables: © 2000-2006 Netfilter Core Team [ 38.412557] No dock devices found. [ 39.431398] apm: BIOS not found. [ 39.572013] ppdev: user-space parallel port driver [ 39.741946] audit(1215937129.529:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=5180 profile="/usr/sbin/cupsd" namespace="default" [ 41.308972] Bluetooth: Core ver 2.11 [ 41.337577] NET: Registered protocol family 31 [ 41.337580] Bluetooth: HCI device and connection manager initialized [ 41.337584] Bluetooth: HCI socket layer initialized [ 41.361361] Bluetooth: L2CAP ver 2.9 [ 41.361365] Bluetooth: L2CAP socket layer initialized [ 41.455640] Bluetooth: RFCOMM socket layer initialized [ 41.455654] Bluetooth: RFCOMM TTY layer initialized [ 41.455656] Bluetooth: RFCOMM ver 1.8 [ 44.934034] [drm] Initialized drm 1.1.0 20060810 [ 44.936815] ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 17 [ 44.936825] PCI: Setting latency timer of device 0000:00:02.0 to 64 [ 44.936897] [drm] Initialized i915 1.6.0 20060119 on minor 0 [ 46.528207] ath0: no IPv6 routers present Network Manager rapporterer at det ikke er noen trådløse nettverk selv når jeg bruker det så jeg har avinnstallert pakken uten at det gjør noen forskjell. Har Googlet etter løsning og selv om det ser ut til at mange andre har samme problem så har jeg ikke funnet noen løsning. KWifiHåndterer viser nøyaktig samme informasjon både før og etter jeg starter nettverket på nytt, dvs signalstyrke,hastighet, SSID, AP-MAC, Lokal IP og kanal. Det er tungvindt å måtte åpne terminalvindu og taste ...restart HVER gang jeg starter maskina. Bjørn Lenke til kommentar
jonnor Skrevet 13. juli 2008 Del Skrevet 13. juli 2008 Mulig løsning: 1 - Gjør om kommandoen din til et shell script (lagre det som en tekstfil med endelsen .sh og inkluder linjen #!/bin/bash helt øverst i filen og så kommandoen din) 2 - Legg scriptet til slik at det kjøres automatisk i oppstarten ( http://ubuntu.wordpress.com/2005/09/07/add...-run-at-bootup/ ) Men ja, det er en hack, iom at det ikke løser det underliggende problemet. Men bør fungere finfint, og det er vel kanskje det viktigste? Lenke til kommentar
