AveMORphine Skrevet 20. mars 2003 Rapporter Del Skrevet 20. mars 2003 Asus A7N8X er ikke hovedkortet for deg som vil ha 200mhz FSB uten litt blod,svette, tårer og loddebolt Da anbefales heller EPOS 8RDA+/8RGA+ eller Abit NF7-S 1.2. Humm, kan du gi meg noen gode tips for hvordan jeg skal få mitt 8RDA+ over 190MHz uten volt mod? Vet at noen kommer over 200 uten modding men langt fra alle. http://8rda.com/ <-mange bra tips Lenke til kommentar
Petrvs Romanvs Skrevet 20. mars 2003 Rapporter Del Skrevet 20. mars 2003 Coolmods har et voltmoddesett for chipsettet på Asus, prisen er £27 (nkr 315). The cost of these special micro-grabbers are significantly higher than the normal type - and in attempt to try and keep the final kit cost as low as possible, we are making no extra profit on these kits than we do on the normal kits. Each kit contains : - Precision Micro Grabber - Miniature precision 22 turn variable resistor. - Metal tag ring. This connects around the nearest motherboard screw. - Adhesive pad to secure the variable resistor to the motherboard. - All connections are preassembled, and heat shrunk. No soldering is required. - Instructions for the appropriate Motherboard / Card. The micro grabber can easily be removed when ever you want, leaving no physical marks on the motherboard. Abit og Epox settene koster £10 Lenke til kommentar
