Gambler FEX online Skrevet 11. juli 2008 Del Skrevet 11. juli 2008 Hei! Noen andre som synes hjemmesiden til Netshop.no er treg? Kikket på kilden og den var stor, 370KB for en side. i Opera rendrer den heller ikke ferdig all PC6400 minne. ER det virkelig nødvendig med så komplisert html kode eller har de bare hatt en dårlig webmaster. http://www.netshop.no/aspx/produkter.aspx?...C6xxx&a=vis Og hva med å lage sider som skalerer i bredden, det er så irriterende med sidescrollende hjemmesider. Opera har en "fit to width" funksjon men den virker ikke alltid. 5.5. For what screen size should I write? HTML does not depend on screen size. Normally, the text will be wrapped by the browser when the end of its display area is encountered. (Note that graphical browsers are often used with windows that are smaller than the full area of the screen.) Preformatted lines (text within <PRE> elements) should only ever exceed 70 characters if the nature of the content makes it unavoidable. Longer lines will cause ugly line breaks on text-mode browsers, and will force horizontal scrolling on graphical browsers. Readers strongly dislike horizontal scrolling, except where they can realise that the nature of the content made it inevitable. Images cannot be wrapped, so you have to be careful with them. It seems that 400 or 500 pixels is a reasonable width; anything above 600 will mean a certain percentage of users will have to scroll to see the rightmost bit. This percentage increases with your image width. Keep in mind that not everyone runs his browser at full screen! (WebTV users have no ability to scroll horizontally, so anything beyond 544 pixels will be compressed by their browser. Some other devices may be even more limited.) The use of tables for layout, especially when fixed-width cells are used, is the most usual single factor that prevents pages from adapting to various window widths. http://www.htmlhelp.com/faq/html/design.html#screen-size Lenke til kommentar
LoooK Skrevet 11. juli 2008 Del Skrevet 11. juli 2008 regner med at du har sendt en epost til netshop og ikke bare lagt et innlegg her? Lenke til kommentar
