Audigy advanced mb driver
Hei, jeg har nylig reformatert pcen min og kom da over et problem. Jeg kan ikke installere lydkortet mitt, og jeg finner ikke drivere som jeg trenger. Lydkortet(eller det som står på cden) heter Sound Blaster Audigy advanced mb. Merket er Creative.
Kan noen hjelpe meg?
Har xp så trenger drivere til windows xp.
Fant dette, kanskje det hjelper..
Re: Problems downgrading Vista to Xp - Sound Blaster Audigy Advanced MB not recognized
Options Options
jimco
Gold
Message 2 of 4
Viewed 748 times
After you have performed an Operating System re-installation, install the audio driver following this order of installation:
a. Install Dell Notebook System Software (click the + sign next to System Utilities). Restart.
b. Next install the Intel Mobile Chipset driver (click the + sign next to Chipset). Restart.
c. Finally re-install the Sigmatel audio driver (click the + sign next to Audio).
Get these from 1520 XP drivers page
Jim
PS a failed attempt to install the Creative Audigy software can result in the failure of Windows Audio Service, so make sure that service is still running. Go to Start/Run and type "services.msc" then hit the 'Enter' key (or click 'ok'). The Services window will appear. Scroll down until you find "Windows Audio" towards the bottom of the list. Check that it is enabled, set to automatic, and running.
1520 xp driver side
dell forum
Endret av Dr.Gonzo
