PCI DVT-S mottaker i norge ?
Fannt denne på nettet til en rimelig penge :dribble:
Lurer bare på om noen her kanskje vet om denne kan brukes i norge ?
Manufacturer Specification
* Input terminal: F-type 75 Ohm
* Receiving frequency: 950~2150 MHz tuning range
* Input level: -65~-25dBm
* Support MCPC and SCPC
* QPSK & FEC
* Symbol rate: 2~45Msps
* QPSK filter: Root-raised cosine filter with roll-off 0.35
* Punctured codes: 1/2,2/3,3/4,5/6,7/8 and Auto
* LNB & Switch Control
* LNB supply voltage: 13V/18V with Short Circuit Protection
* DiSEqC: 1.2
* Support USALS
* Support Data Burst & Tone Burst
* Antenna and LNB control: 22 KHz Tone
* Max. LNB supply current: 400mA
* System Requirements:
- OS: Windows 98SE/ME/2000/XP
- CPU: 500 MHz or better
- Memory: 128MB or more
- VGA card with at least 8 MB Memory
- Windows Compatible Sound card
- Microsoft DirectX 8.1 or above
- Digital Satellite Dish & LNB
* Power Source: PCI
* Dimension: (LxWxD)125x100x16mm (Single Width Standard PCI Slot Required
* Manufacturer Ref.: S67FYHC38MBU
Other Features:
* Support DVB protocol
* Digital Satellite TV and Radio Program Receiving
* Real time Digital Video Recording and Schedule Recording
* Time-shifting
* Electronic Program Guide (EPG)
* Multi-Channel Preview (FTA Channels Only)
* Transponder, Satellite Auto Scan
* Viewing and Recording Different Channels simultaneously in the same transponder
* MPEG-II Software Decoding
* Still Frame Capture
* Favorite List
* Teletext
Accessories:
* Infrared remote Control with AAA batteries
* Infrared remote control receiver
* Driver CD (Multi-language Software and User's Manual
* Manufacturer and Origin: China
Fint med seriøse svar :thumbup:
Endret av dod2mat
