RHEL 5 nedlasting og lovlighet
Etter hva jeg forstår så er Redhat Enterprise 5 et opensource prosjekt og man betaler for oppdateringer og support og ikke selve os'et.
Stemmer dette ?
Kan jeg laste ned denne distroen og installere den hvor som helst uten følger ?
Hvis ja, hvorfor finnes ikke denne distroen da på RH sine sider for nedlasting uten å måtte betale ?
Takk for svar folkens
Er litt forvirret for jeg tenker normalt på Linux som gratis.
Og når de i tilegg overalt omtaler at du betaler for subscriptions og support så blir jeg enda mere forvirret.
Så tanken på om jeg kunne da en distro fra en venn eller laste den ned fra internett fikk jeg aldri svar på via rh nettsidene.
Fra rh sine faq sider.
When you buy proprietary software, you pay an upfront license fee and then pay for maintenance every year. When you purchase a Red Hat subscription, you are buying open source software and therefore not paying a license fee, but you pay for the total subscription—including updates, services and support you need for the year
6. If I don't renew, can I continue to use the software?
Yes, under the General Public License (GP), you may use the software and maintain your own custom version of Linux. However, you will not have access to:
Technical support from Red Hat.
Security or software updates via Red Hat Network. You will have to find updates from alternative resources that provide reliable, secure downloads.
Support from certified hardware suppliers or software vendors like Oracle for applications running on an expired Red Hat Enterprise Linux subscription.
Coverage from the Red Hat Open Source Assurance program, featuring an Intellectual Property Warranty for Red Hat Enterprise Linux customers. Red Hat designed the program to protect customers using open source solutions.
Please note that when your subscription expires you will still be bound by the terms and conditions of the End User License Agreement and will have to remove all copies of Red Hat Network Code.
Stemmer dette ?
Du kan fritt laste ned kildekoden til RHEL5, men du må betale vist du vil ha binærpakkane. Dette er fult lovleg ifølge gpl, og det er fleire andre som gjør det samme. T.d. så er binærpakken(fra utviklaren) for xchat på windows "tryware" menst kildekoden er gratis. Det gjør også butikker som linuxbutikken i stand til å selge cd/dvder med linux distrubisjoner som i utgangspunktet er gratis.
Edit: RH trenger ikkje å ha ein link til kildekoden på sida si, det er nokk at dei gir den ut ved forespørsel.
Endret av Mr.Elendig
Sakens kjerne er vel merkevarenavn med logoer etc? Selv om programvaren er GPL-lisensiert, er allikevel Red Hat-navnet en beskyttet merkevare som ikke kan brukes uten Red Hat sin tillatelse, derimot står man fritt til å fjerne Red Hat navnet/logoer for deretter å videredistribuere produktet i tråd med GPL-lisensen, og det er jo nettopp det Cent OS gjør.
EDIT: @Mr.Elendig: Meg bekjent gjør ikke GPL noen forskjell på binær-filer og kildekode, utover kravet om at enhver innehaver av en gyldig lisens skal ha tilgang til kildekode for eventuelle binærfiler.
Altså har det ingenting å si om det er kildekoden eller binærfilene man laster ned, begge deler er en del av produktet og krever gyldig lisens.
Endret av PHPdude
Takk for alle svar folkens.
Greia var egentlig at jeg ville sette opp et system med RHEL og eventuel begynne å betale for for support og tilgang til Redhat nettverket når den tid kom.
Jeg har tidligere benytter RHEL distroer fra arbeidsgiver og viste at man da kunne installere de og selv velge om man ville ha tilgan til support etc.
Så jeg trodde man kunne finne imager for nedlasting og så velge å betale, men den gang ei.
Når jeg begynte å lese meg til det så ble jeg ytterligere forvirret.
Jeg tok turen innom Linuxguiden etter tips fra Perulv her og fant ut at CentOS var omtrent eksakt lik som REHL, så nå forsøker jeg det i første omgang så får jeg heller gjøre jobben omigjen senere hvis jeg har behov for RHEL.
Cheers :)
RHEL er open source, men Red Hat tar seg betalt for merkevaren, branding, logoer osv. Det har de full rett til å gjøre.
CentOS er et prosjekt som tar kildekoden til RHEL, og stripper bort alt av branding. Ellers er de 100% binærkompatible.
Når du normalt sett tenker på linux som gratis, så er dette egentlig feil. På engelsk heter det "free", og det kan bety fri, eller gratis. Linux er alltid fritt, og som følge av det, som regel gratis også, men ikke alltid.
Lisensen tillater kommersiell bruk, og hvis du ser etter litt, oppdager du fort at linux (og fri programvare forøvrig) har blitt big business.
Kan legge til at CentOS er velkjent som RHEL-erstatter, og også brukes av firmaer etc som sådan. Eksempelvis setter vi opp CentOS når vi bedriver utvikling av RH-kompatible løsningen på jobb (mange kunder kjører jo gjerne RHEL), og jeg har selv satt opp utviklingsmiljøer for kunder basert på CentOS der den endelige løsningen baseres på RHEL (selv om det ser ut til at vi etter hvert kommer til å sette opp maskinene vi idriftssetter løsningen på under første testfase med RHEL i stedet for CentOS, slik at vi evt. kan identifisere forskjeller og er sikre på at alt er likt - kostnaden er uansett ikke noe å snakke om i denne sammenheng).
