Raid Kontroller SATA2 (PCI-E x1) ?
Gjest Slettet-t8fn5F
Det er vel vanlig PCI du trenger...
Liker denne på grunn av navnet. Aldri prøvd den. Bruker det som er på hovedkortet....
Dette er helt feil av meg. Beklager, men nå fant jeg ut av den....Ikke funnet kontoller enda,
Fant hastghetene her...
PCI Express Throughput
The Throughput Rates for the PCIe interface is for one direction only. PCI Express is a serial bus which embeds its clock unlike the other bus standards listed here. The throughput of a PCI Express interface is reduced by 20 percent due to the 8B/10B data encoding. The table accounts for the 8-bit/10-bit encoding loss: at a 2.5Gbps clock speed, the 1x transfer rate of should be 312.5MBps with 8 bits per clock [without 8B/10B], but at 10 bits per clock the transfer rate becomes 250MBps [with 8B/10B].
Actual Throughput Rates
Bus Spec Transfer Rate Throughput Rate
PCI; 33MHz, 32-bit 133MBps -
PCI-Express x1 250MBps -
AGP 2x 533MBps -
PCI-Express x4 1,000MBps -
AGP 4x 1,066MBps -
AGP 8x 2,133MBps -
PCI-Express x16 4,000MBps -
Endret av Slettet-t8fn5F
