BjornK Skrevet 3. juli 2008 Del Skrevet 3. juli 2008 (endret) Hei. Har en HP Compaq nc8000 med Ubuntu 8.04 Det meste virker men ikke trådløst nettverk. Har et AP som virker greit med den samme maskinen i XP men den dukker ikke opp i nettverkslisten i nm-editor. Har lest om og installert madwifi uten at det hjalp. dmesg gir: [ 23.565978] ath_hal: module license 'Proprietary' taints kernel. [ 23.645271] ath_hal: 0.9.18.0 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413) [ 24.205196] ath_pci: 0.9.4 [ 27.806022] ath_rate_sample: 1.2 (0.9.4) [ 27.885690] wifi0: Atheros 5212: mem=0x90080000, irq=11 [ 27.806511] wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps [ 27.806517] wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps [ 27.806526] wifi0: H/W encryption support: WEP AES AES_CCM TKIP [ 27.806530] wifi0: mac 5.6 phy 4.1 radio 1.7 [ 27.806535] wifi0: Use hw queue 1 for WME_AC_BE traffic [ 27.806537] wifi0: Use hw queue 0 for WME_AC_BK traffic [ 27.806539] wifi0: Use hw queue 2 for WME_AC_VI traffic [ 27.806541] wifi0: Use hw queue 3 for WME_AC_VO traffic [ 27.806543] wifi0: Use hw queue 8 for CAB traffic [ 27.806545] wifi0: Use hw queue 9 for beacons [ 27.885690] wifi0: Atheros 5212: mem=0x90080000, irq=11 iwlist gir: lo no wireless extensions. eth0 no wireless extensions. irda0 no wireless extensions. wifi0 no wireless extensions. ath0 IEEE 802.11g ESSID:"" Nickname:"" Mode:Managed Frequency:2.437 GHz Access Point: Not-Associated Bit Rate:0 kb/s Tx-Power:15 dBm Sensitivity=1/1 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=0/70 Signal level=-96 dBm Noise level=-96 dBm Rx invalid nwid:1214 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 Har også prøvd å legge inn SSID og krypteringsnøkkel uten at det gjorde noe forskjell Endret 4. juli 2008 av BjornK Lenke til kommentar
t_k Skrevet 3. juli 2008 Del Skrevet 3. juli 2008 (endret) Ser ut som det kan være litt knot å få denne til å fungere. http://www.waldner.priv.at/stuff/nc8k/ http://fobie.net/nc8000/#wireless Edit: Leif. Endret 3. juli 2008 av t_k Lenke til kommentar
BjornK Skrevet 3. juli 2008 Forfatter Del Skrevet 3. juli 2008 Ser ut som det kan være litt knot å få denne til å fungere. http://www.waldner.priv.at/stuff/nc8k/ http://fobie.net/nc8000/#wireless Edit: Leif. Har vært inne på de 2 linkene uten å bli så mye klokere, er ganske grønn på linux. Siden Atheros brikken kanskje ikke er så lett å ha med å gjøre så klemte jeg inn et Orinoco PCMCIA-kort i håp om å få en trådløs forbindelse men da dukket det opp et annet problem. dmesg: [ 40.521279] eth1: Hardware identity 0001:0004:0005:0000 [ 40.521403] eth1: Station identity 001f:0001:0008:0048 [ 40.521406] eth1: Firmware determined as Lucent/Agere 8.72 [ 40.521408] eth1: Ad-hoc demo mode supported [ 40.521410] eth1: IEEE standard IBSS ad-hoc mode supported [ 40.521412] eth1: WEP supported, 104-bit key [ 40.521496] eth1: MAC address 00:02:2d:aa:a5:c2 [ 40.521598] eth1: Station name "HERMES I" [ 40.522171] eth1: ready [ 40.522639] eth1: orinoco_cs at 1.0, irq 3, io 0x0180-0x01bf [ 48.181600] ADDRCONF(NETDEV_UP): eth1: link is not ready Har blitt vant til dette etter å ha vært innom ulike linux distribusjoner i løpet av de siste 10 årene, det er ALLTID noe som ikke virker og til slutt går jeg tilbake til Windows og fortsetter livet :-) Bjørn Lenke til kommentar
t_k Skrevet 3. juli 2008 Del Skrevet 3. juli 2008 Desverre så støtter ikke alle produsenter Linux like godt. Noen har nok småavtaler under bordet for ikke å lage drivere til Linux, eller åpne driverne. Det eneste jeg kan råde deg til å gjøre, er å kjøpe hardware du vet støtter Linux. Synd at det må være slik, men etter at selskaper nå taper masse penger siden de ikke har Linux drivere, eller har åpnet driverne sine så ser det ut til at ting bedrer seg. Noen av disse selskapene har tapt millioner på millioner da de har tapt annbud til små PC'er som EEE og lignende, da de MÅ ha velfungerende drivere i disse til Linux. God gammeldags smekk til egen bak. Du kan nok få dette til å fungere ved å finne brukere av denne Laptoppen, og lære en del i prosessen, men jeg kan skjønne at du ikke orker det også. Lenke til kommentar
BjornK Skrevet 4. juli 2008 Forfatter Del Skrevet 4. juli 2008 Etter en søvnløs natt virker endelig det trådløse kortet i laptopen. Deaktiverte driverne som ble lastet ved innstalasjonen, fjernet network manager og innstallerte MadWifi http://madwifi.org/wiki/UserDocs/FirstTimeHowTo Å kople til ubeskyttet AP gikk greit. Har nettverk med WEP og delt autentisering og det var ikke så lett å få til men etter mye Googling og forsøk var forbindelsen i boks. Her er oppsettet i /etc/network/interfaces, vet ikke om det er optimalt men det virker. auto lo iface lo inet loopback iface ath0 inet static address 192.168.1.81 network 192.168.1.0 netmask 255.255.255.0 broadcast 192.168.1.255 wireless-key xxxxxxxxxxxxxxxxxxxxxxxxxx wireless-essid xxxxxxx pre-up iwpriv ath0 authmode 2 post-up route add default gw 192.168.1.1 auto ath0 auto eth0 iface eth0 inet static address 192.168.1.80 network 192.168.1.0 netmask 255.255.255.0 broadcast 192.168.1.255 gateway 192.168.1.1 Litt høy i hatten over å ha fått det til kastet jeg meg like godt over en annen laptop med XP/Ubuntu dualboot. Det er en Toshiba Satellite Pro A200 med Atheros AR5BXB63 wifi-brikke. Prøvde samme kur på den men uten hell. Var i ferd med å starte innstallasjon av ndiswrapper og Windowsdriver da jeg snublet over denne siden: http://brunoabinader.blogspot.com/2008/05/...ardy-heron.html Prøvde først med madwifi-ng-r2756+ar5007 men fikk feilmelding så jeg avinnstallerte den og prøvde madwifi-nr-r3366+ar5007 istedenfor og da ble det BINGO ! KWiFIManager gir en grei status på oppkoplingen og var nyttig under forsøkene. Bjørn Lenke til kommentar
