hjelp med partisjonering til ext3 ?
daniel@daniel-desktop:~$ sudo mount -l
[sudo] password for daniel:
/dev/sda1 on / type ext3 (rw,relatime,errors=remount-ro) []
proc on /proc type proc (rw,noexec,nosuid,nodev)
/sys on /sys type sysfs (rw,noexec,nosuid,nodev)
varrun on /var/run type tmpfs (rw,noexec,nosuid,nodev,mode=0755)
varlock on /var/lock type tmpfs (rw,noexec,nosuid,nodev,mode=1777)
udev on /dev type tmpfs (rw,mode=0755)
devshm on /dev/shm type tmpfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
lrm on /lib/modules/2.6.24-19-generic/volatile type tmpfs (rw)
securityfs on /sys/kernel/security type securityfs (rw)
gvfs-fuse-daemon on /home/daniel/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=daniel)
har btw fått til å partisjonere den ene disken. så den ene funker. trenger bare å få jort det med den andre. fikk det ikke til
daniel@daniel-desktop:~$ sudo fdisk -l
Disk /dev/sda: 150.0 GB, 150039945216 bytes
255 heads, 63 sectors/track, 18241 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x54487d16
Device Boot Start End Blocks Id System
/dev/sda1 * 1 17495 140528556 83 Linux
/dev/sda2 17496 18241 5992245 5 Extended
/dev/sda5 17496 18241 5992213+ 82 Linux swap / Solaris
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x54487d15
/dev/sdb1 1 60801 488384001 83 Linux
Disk /dev/sdc: 500.1 GB, 500107862016 bytes
Disk identifier: 0x016f016f
/dev/sdc1 2 60801 488376000 83 Linux
daniel@daniel-desktop:~$ sudo cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
UUID=221645a0-e662-4bb0-93e6-d71c521bed41 / ext3 relatime,errors=remount-ro 0 1
# /dev/sda5
UUID=15711414-ca22-4bc5-a4d7-8af107d8bb05 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
er dette eksterne harddisker eller interne?
Virker som begge diskene med 500GB har linux filformat.
for at de skal komme opp automatisk ved oppstart må du vel legge til noe lignende dette i /etc/fstab;
/dev/sdb1 /media/disk1 ext3 relatime 0 2
/dev/sdc1 /media/disk2 ext3 relatime 0 2
husk å åpne med root rettigheter:
sudo gedit /etc/fstab i terminal
derretter kan du prøve:
sudo mount -a for å utføre endringer i fstab
Endret av mariunae
