Hva gjør jeg når bilen krever blyfri 91?
Espp
ROZ var en ny forkortelse for meg. Trodde vi brukte RON og amerikanerne brukte gjennomsnittet av RON (research octane number) og MON (motor octane number)
Ingen anelse selv, vil bare vite om en Acura Tsx kan kjøre på 95, istedenfor 91?
Ettersom jeg forstår det så er ROZ og RON det samme, bare at ROZ er tyskernes forkortelse
Bah.. ble bare tull dette,
En gang til:
Octane Rating Calculation Methods
There are various calculation methods, RON, MON, and PON or AKI.
RON: (Research Octane Number). Most common fuel used in Europe, Australia and some other Countries. It is determined with measurements of fuel behavior in a variable compression engine. Results are compared with other iso-octane fuels, wich means, compared with other fuel types with equal number of similar octane molecules present, but not the of the same organic compound.
MON: (Motor Octane Number). Determined also with a variable compression engine, but with the fuel already preheated, variable ignition timing and higher RPMs than the RON method. This method is more precise on determining fuel behavior on an loaded engine.
PON or AKI: (Pump Octane Rating or Anti-Knock Index): This is the method used in USA and Canada, expressed as [R+M]/2, wich means RON number plus MON number, divided by 2. In other words, it is the average between both methods above.
So, due to the fact that RON is always from 4 to 5 points higher of its equivalent to PON or AKI, the number conversion between USA and Europe octane ratings will approximately be as follows:
USA (PON) Europe (RON)
87 = 91
89 = 93
91 = 95
93 = 98
Endret av Rebel-Rider
Du har sikkert lest wikipediasiden som omhandler oktantall, der står følgende:
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-92 in Europe
Det kan sikkert diskuteres hvor troverdig wikipedia er, men jeg velger altså å tro på det som står der.
Edit: Nå svarte jeg før du forandret posten, så vi er sikkert enige om at vi her i norge bruker RON standarden og at de i statene bruker snittet av ron og mon målemetodene.
Endret av Erik Braseth
