[LØST] Virus i system32 mappen
Har du forsøkt å søke på nettet?
I Wikipedia kan du lese følgende:
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional can run the following command at the system prompt to get a breakdown ......
På google med PDM.exe:
The file "pdm.exe" is known to be created under the following filename:
%ProgramFiles%\pdm\pdm.exe
Note: %ProgramFiles% is a variable that refers to the Program Files folder. A typical path is C:\Program Files.
The following threats are known to be associated with the file "pdm.exe":
Threat Alias Number of Incidents
Application.Ardamax_Keylogger [PC Tools] 2
not-a-virus:Monitor.Win32.Ardamax.dp [Kaspersky Lab] 1
Spyware.Ardakey [symantec]
For SearchProtocolHost.exe:
The process SearchProtocolHost.exe or Microsoft Windows Search Protocol Host belongs to the software Microsoft® Windows® Operating System or SearchProtocolHost.exe by Microsoft Corporation (www.microsoft.com).
Description: File SearchProtocolHost.exe is located in the folder C:\Windows\System32 or sometimes in a subfolder of C:\Windows. Known file sizes on Windows XP are 182784 bytes (65% of all occurrence), 204288 bytes, 156160 bytes.
The program is not visible. It is a trustworthy file from Microsoft. It is not a Windows system file. Therefore the technical security rating is 14% dangerous.
Important: Some malware camouflage themselves as SearchProtocolHost.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the SearchProtocolHost.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
Edit: Noen tillegg.
Endret av PerB
Denne tråden er feilpostet. Vi har en egen kategori for "Antivirusprogrammer og datasikkerhet". Alle spørsmål om virus, spyware, rootkits, og hvordan man forebygger mot og blir kvitt disse kan postes der. For å finne kategorien kan du gå inn på:
Forum > Programvare > Antivirusprogrammer og datasikkerhet
Flytter tråden for deg nå, og lar det ligge en lenke igjen i denne kategorien.
Snorre :)
*Tråd flyttes*
Last ned HijackThis legg i egen mappe på skrivebordet.
Start programmet og velg "Trykk scan og save log"
Post HijackThis.txt
Her er loggen:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 12:38:27, on 26.06.2008
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18000)
Boot mode: Normal
Running processes:
C:\Windows\system32\taskeng.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Windows Defender\MSASCui.exe
C:\Program Files\DellTPad\Apoint.exe
C:\Windows\OEM02Mon.exe
C:\Program Files\Java\jre1.6.0\bin\jusched.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\IAAnotif.exe
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\Dell\MediaDirect\PCMService.exe
C:\Program Files\AVG\AVG8\avgtray.exe
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
C:\Program Files\CyberLink\PowerDVD8\PDVD8Serv.exe
C:\Program Files\CyberLink\Shared Files\brs.exe
C:\Program Files\Sigmatel\C-Major Audio\WDM\sttray.exe
C:\Windows\System32\rundll32.exe
C:\Program Files\Fingerprint Reader Suite\psqltray.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Windows\ehome\ehtray.exe
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
C:\Program Files\Dell\QuickSet\quickset.exe
C:\Program Files\DellTPad\ApMsgFwd.exe
C:\Windows\ehome\ehmsas.exe
C:\Program Files\DellTPad\HidFind.exe
C:\Program Files\DellTPad\Apntex.exe
C:\Program Files\Opera\opera.exe
C:\Program Files\iTunes\iTunes.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceHelper.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\distnoted.exe
C:\Windows\system32\SearchFilterHost.exe
C:\Users\Thomas\Desktop\f\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer levert av Dell
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O1 - Hosts: ::1 localhost
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: ProAct - {2FF811E6-8925-4084-A649-C159955E67E8} - C:\Windows\system32\ks94.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: BatBHO - {63F7460B-C831-4142-A4AA-5EC303EC4343} - (no file)
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - c:\Program Files\Java\jre1.6.0\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Påloggingshjelp for Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.0.301.7164\swg.dll
O2 - BHO: Windows Live Toolbar Helper - {BDBD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O3 - Toolbar: Windows Live Toolbar - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [ECenter] C:\Dell\E-Center\EULALauncher.exe
O4 - HKLM\..\Run: [Apoint] C:\Program Files\DellTPad\Apoint.exe
O4 - HKLM\..\Run: [OEM02Mon.exe] C:\Windows\OEM02Mon.exe
O4 - HKLM\..\Run: [sunJavaUpdateSched] "c:\Program Files\Java\jre1.6.0\bin\jusched.exe"
O4 - HKLM\..\Run: [PSQLLauncher] "C:\Program Files\Fingerprint Reader Suite\launcher.exe" /startup
O4 - HKLM\..\Run: [DELL Webcam Manager] "C:\Program Files\Dell\Dell Webcam Manager\DellWMgr.exe" /s
O4 - HKLM\..\Run: [iAAnotif] "C:\Program Files\Intel\Intel Matrix Storage Manager\Iaanotif.exe"
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Dell\MediaDirect\PCMService.exe"
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [RemoteControl8] "C:\Program Files\CyberLink\PowerDVD8\PDVD8Serv.exe"
O4 - HKLM\..\Run: [PDVD8LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD8\Language\Language.exe"
O4 - HKLM\..\Run: [bDRegion] C:\Program Files\Cyberlink\Shared Files\brs.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [sigmatelSysTrayApp] %ProgramFiles%\SigmaTel\C-Major Audio\WDM\sttray.exe
O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NVHotkey] rundll32.exe C:\Windows\system32\nvHotkey.dll,Start
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKUS\S-1-5-19\..\Run: [sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-20\..\Run: [sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETTVERKSTJENESTE')
O4 - Global Startup: BTTray.lnk = ?
O4 - Global Startup: QuickSet.lnk = C:\Program Files\Dell\QuickSet\quickset.exe
O8 - Extra context menu item: &Windows Live Search - res://C:\Program Files\Windows Live Toolbar\msntb.dll/search.htm
O8 - Extra context menu item: E&ksporter til Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Send image to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Send page to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - c:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - c:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O13 - Gopher Prefix:
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/Messe...nt.cab56907.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~2\GOEC62~1.DLL,avgrsstx.dll
O23 - Service: Andrea ST Filters Service (AESTFilters) - Andrea Electronics Corporation - C:\Windows\system32\aestsrv.exe
O23 - Service: Apache2.2 - Unknown owner - C:\Program Files\Apache Software Foundation\Apache2.2\bin\httpd.exe (file missing)
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Bonjour-tjeneste (Bonjour Service) - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Intel® PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: GoogleDesktopManager - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Intel® Matrix Storage Event Monitor (IAANTMON) - Intel Corporation - C:\Program Files\Intel\Intel Matrix Storage Manager\Iaantmon.exe
O23 - Service: iPod-tjeneste (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: PLFlash DeviceIoControl Service - Prolific Technology Inc. - C:\Windows\system32\IoctlSvc.exe
O23 - Service: Intel® PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - Unknown owner - C:\Program Files\WinPcap\rpcapd.exe
O23 - Service: SigmaTel Audio Service (STacSV) - IDT, Inc. - C:\Windows\system32\STacSV.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: wampapache - Apache Software Foundation - c:\WAMP\bin\apache\apache2.2.8\bin\httpd.exe
O23 - Service: wampmysqld - Unknown owner - c:\WAMP\bin\mysql\mysql5.0.51a\bin\mysqld-nt.exe
End of file - 12266 bytes
Last Combofix ned ,legg på skrivebordet.
Ikke klikk på vindu mens programet kjører.
post logg C:\combofix.txt
Logg:
ComboFix 08-06-20.4 - Thomas 2008-06-26 12:48:33.1 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.1.1044.18.1929 [GMT 2:00]
Running from: C:\Users\Thomas\Desktop\ComboFix.exe
* Created a new restore point
* Resident AV is active
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\ProgramData\Microsoft\Network\Downloader\qmgr0.dat
C:\ProgramData\Microsoft\Network\Downloader\qmgr1.dat
C:\Users\Thomas\AppData\Roaming\inst.exe
C:\Windows\system32\drivers\npf.sys
C:\Windows\system32\packet.dll
C:\Windows\system32\pthreadVC.dll
C:\Windows\system32\wpcap.dll
----- BITS: Possible infected sites -----
hxxp://theinstalls.com
((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
-------\Service_NPF
((((((((((((((((((((((((( Files Created from 2008-05-26 to 2008-06-26 )))))))))))))))))))))))))))))))
2008-06-25 23:23 . 2008-06-25 23:23 18,944 --a------ C:\Windows\System32\ks94.dll
2008-06-25 23:22 . 2008-06-25 23:22 18,944 --a------ C:\Windows\System32\ksisys.dll
2008-06-25 23:22 . 2008-06-25 23:22 18,944 --a------ C:\Windows\System32\dopadio.dll
2008-06-25 23:21 . 2008-06-25 23:24 <DIR> d-------- C:\Program Files\Deluxe Ski Jump 3
2008-06-25 22:45 . 2008-06-25 22:46 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\GetRightToGo
2008-06-25 22:45 . 2008-06-25 22:45 <DIR> d-------- C:\Downloads
2008-06-24 18:05 . 2008-06-24 18:24 <DIR> d-------- C:\Program Files\nusphere
2008-06-23 11:36 . 2008-06-23 11:36 <DIR> d-------- C:\Program Files\SoftByte Labs
2008-06-23 10:40 . 2008-06-23 10:40 <DIR> d-------- C:\Program Files\Rockstar Games
2008-06-21 09:43 . 2008-06-21 09:43 0 --ah----- C:\Windows\System32\drivers\Msft_User_WpdFs_01_00_00.Wdf
2008-06-20 22:54 . 2008-06-20 22:54 <DIR> d-------- C:\Program Files\SpeedFan
2008-06-20 22:54 . 2008-06-20 22:54 45 --a------ C:\Windows\System32\initdebug.nfo
2008-06-20 18:32 . 2008-06-20 18:32 <DIR> d-------- C:\Program Files\iTunes
2008-06-20 18:32 . 2008-06-20 18:32 <DIR> d-------- C:\Program Files\iPod
2008-06-20 18:26 . 2008-06-20 18:26 <DIR> d-------- C:\Program Files\Common Files\Apple
2008-06-20 17:33 . 2005-05-26 15:34 2,297,552 --a------ C:\Windows\System32\d3dx9_26.dll
2008-06-20 16:01 . 2008-06-20 16:01 0 --ah----- C:\Windows\System32\drivers\Msft_User_WpdMtpDr_01_00_00.Wdf
2008-06-20 14:58 . 2008-06-21 00:09 156 --a------ C:\Windows\Twunk001.MTX
2008-06-20 14:58 . 2008-06-21 00:09 2 --a------ C:\Windows\Twain001.Mtx
2008-06-20 14:58 . 2008-06-20 14:58 0 --a------ C:\Windows\Twunk002.MTX
2008-06-20 14:55 . 2008-06-20 14:55 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\Sony
2008-06-20 14:55 . 2008-06-20 14:55 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\Publish Providers
2008-06-20 14:50 . 2008-06-20 14:50 <DIR> d-------- C:\Users\All Users\Sony
2008-06-20 14:50 . 2008-06-20 14:50 <DIR> d-------- C:\ProgramData\Sony
2008-06-20 14:50 . 2008-06-20 14:50 <DIR> d-------- C:\Program Files\Sony
2008-06-20 14:49 . 2008-06-20 14:49 <DIR> d-------- C:\Program Files\Sony Setup
2008-06-16 23:33 . 2008-06-16 23:34 <DIR> d-------- C:\Program Files\Magic Video Converter
2008-06-16 23:33 . 2004-05-26 21:37 719,872 --a------ C:\Windows\System32\devil.dll
2008-06-16 23:33 . 2003-03-19 11:03 544,768 --a------ C:\Windows\System32\msvcr71d.dll
2008-06-16 23:33 . 2002-01-05 14:37 344,064 --a------ C:\Windows\System32\msvcr70.dll
2008-06-16 23:33 . 2006-09-16 19:44 314,368 --a------ C:\Windows\System32\avisynth.dll
2008-06-16 17:01 . 2004-08-18 03:34 442,368 --a------ C:\Windows\System32\vp6vfw.dll
2008-06-15 22:28 . 2008-06-16 18:01 <DIR> d-------- C:\Program Files\Tensons
2008-06-15 15:01 . 2008-06-15 15:01 <DIR> d-------- C:\Users\All Users\NFS Underground
2008-06-15 15:01 . 2008-06-15 15:01 <DIR> d-------- C:\ProgramData\NFS Underground
2008-06-15 00:18 . 2008-06-15 14:47 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\ImgBurn
2008-06-15 00:16 . 2008-06-15 00:16 <DIR> d-------- C:\Program Files\ImgBurn
2008-06-14 11:08 . 2008-04-23 06:42 428,544 --a------ C:\Windows\System32\EncDec.dll
2008-06-14 11:08 . 2008-04-23 06:42 293,376 --a------ C:\Windows\System32\psisdecd.dll
2008-06-14 11:08 . 2008-04-23 06:41 218,624 --a------ C:\Windows\System32\psisrndr.ax
2008-06-14 11:08 . 2008-04-23 06:41 57,856 --a------ C:\Windows\System32\MSDvbNP.ax
2008-06-13 16:15 . 2008-01-19 09:43 3,600,440 --a------ C:\Windows\System32\ntkrnlpa.exe
2008-06-13 16:15 . 2008-01-19 09:43 3,548,728 --a------ C:\Windows\System32\ntoskrnl.exe
2008-06-13 16:15 . 2008-01-19 09:33 2,623,488 --a------ C:\Windows\System32\SLsvc.exe
2008-06-13 16:15 . 2008-01-19 09:36 1,541,120 --a------ C:\Windows\System32\onex.dll
2008-06-13 16:15 . 2008-01-19 09:42 51,768 --a------ C:\Windows\System32\PSHED.DLL
2008-06-13 16:12 . 2008-01-19 09:35 9,847,296 --a------ C:\Windows\System32\NlsData000a.dll
2008-06-13 16:11 . 2008-01-19 09:33 8,139,264 --a------ C:\Windows\System32\ssBranded.scr
2008-06-13 16:10 . 2008-01-19 08:06 8,147,456 --a------ C:\Windows\System32\wmploc.DLL
2008-06-13 16:09 . 2008-01-19 09:33 599,552 --a------ C:\Windows\System32\vsp1cln.exe
2008-06-13 16:09 . 2008-01-05 13:31 145,455 --a------ C:\Windows\System32\perfmon.msc
2008-06-13 16:09 . 2008-01-05 13:22 144,909 --a------ C:\Windows\System32\fsmgmt.msc
2008-06-13 16:09 . 2008-01-05 13:31 3 --a------ C:\Windows\System32\drivers\MsftWdf_Kernel_01007_Inbox_Critical.Wdf
2008-06-13 16:08 . 2008-01-19 09:36 704,512 --a------ C:\Windows\System32\SmiEngine.dll
2008-06-13 16:08 . 2008-01-19 09:36 357,888 --a------ C:\Windows\System32\wbemcomn.dll
2008-06-13 16:08 . 2008-01-19 09:36 139,264 --a------ C:\Windows\System32\SmiInstaller.dll
2008-06-13 16:07 . 2008-01-19 09:36 218,624 --a------ C:\Windows\System32\wdscore.dll
2008-06-13 16:07 . 2008-01-19 09:33 130,560 --a------ C:\Windows\System32\PkgMgr.exe
2008-06-13 16:05 . 2008-01-19 09:34 305,152 --a------ C:\Windows\System32\msdelta.dll
2008-06-13 16:05 . 2008-01-19 09:34 258,560 --a------ C:\Windows\System32\dpx.dll
2008-06-13 16:05 . 2008-01-19 09:34 246,784 --a------ C:\Windows\System32\drvstore.dll
2008-06-13 16:05 . 2008-01-19 09:35 35,328 --a------ C:\Windows\System32\mspatcha.dll
2008-06-13 16:04 . 2008-01-19 07:53 19,456 --a------ C:\Windows\System32\drivers\bthenum.sys
2008-06-10 03:02 . 2008-06-10 03:02 <DIR> d-------- C:\Program Files\MSXML 4.0
2008-06-09 16:02 . 2008-06-15 01:36 <DIR> d-------- C:\perflogs
2008-06-09 15:41 . 2008-06-09 15:41 510,464 --a------ C:\Windows\System32\PDM.exe
2008-06-09 15:41 . 2005-11-13 00:08 180,224 --a------ C:\Windows\System32\RapidshareHacking.exe
2008-06-09 15:41 . 2008-04-22 13:14 8,192 --a------ C:\Windows\System32\PDM.006
2008-06-09 15:41 . 2008-06-09 05:15 2,712 --a------ C:\Windows\System32\PDM.001
2008-06-09 15:41 . 2008-06-08 17:41 358 --a------ C:\Windows\System32\akv.cfg
2008-06-09 15:41 . 2008-06-09 05:15 344 --a------ C:\Windows\System32\PDM.002
2008-06-09 15:41 . 2008-06-09 05:15 342 --a------ C:\Windows\System32\PDM.005
2008-06-09 15:41 . 2008-06-09 05:14 5 --a------ C:\Windows\System32\test
2008-06-08 20:00 . 2008-06-08 20:00 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\Nero
2008-06-08 19:56 . 2008-06-08 19:56 <DIR> d-------- C:\Users\All Users\Nero
2008-06-08 19:56 . 2008-06-08 19:56 <DIR> d-------- C:\ProgramData\Nero
2008-06-08 19:56 . 2008-06-08 19:56 <DIR> d-------- C:\Program Files\Nero
2008-06-08 19:56 . 2008-06-08 19:58 <DIR> d-------- C:\Program Files\Common Files\Nero
2008-06-07 13:36 . 2008-06-07 13:40 <DIR> d-------- C:\Program Files\FGP
2008-05-30 14:56 . 2008-05-30 14:56 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\Template
2008-05-30 14:55 . 2008-05-30 14:56 92 --a------ C:\Users\Thomas\AppData\Roaming\wklnhst.dat
2008-05-28 14:25 . 2008-03-08 04:08 4,240,384 --a------ C:\Windows\System32\GameUXLegacyGDFs.dll
2008-05-28 14:25 . 2008-03-08 06:21 1,695,744 --a------ C:\Windows\System32\gameux.dll
2008-05-27 10:50 . 2008-05-27 10:50 90,112 --a------ C:\Windows\System32\QuickTimeVR.qtx
2008-05-27 10:50 . 2008-05-27 10:50 57,344 --a------ C:\Windows\System32\QuickTime.qts
2008-05-26 19:00 . 2008-05-26 19:00 <DIR> d-------- C:\Program Files\Infogrames
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-06-25 21:30 --------- d-----w C:\Users\Thomas\AppData\Roaming\uTorrent
2008-06-25 21:24 27,430 ----a-w C:\Users\Thomas\AppData\Roaming\nvModes.dat
2008-06-24 16:24 --------- d-----w C:\Users\Thomas\AppData\Roaming\NuSphere
2008-06-23 09:36 --------- d--h--w C:\Program Files\InstallShield Installation Information
2008-06-23 09:36 --------- d-----w C:\Program Files\WinPcap
2008-06-22 17:13 --------- d-----w C:\Program Files\Image-Line
2008-06-20 22:15 --------- d---a-w C:\ProgramData\TEMP
2008-06-20 16:32 --------- d-----w C:\ProgramData\Apple Computer
2008-06-20 16:30 --------- d-----w C:\Program Files\QuickTime
2008-06-20 12:50 --------- d-----w C:\Program Files\VstPlugins
2008-06-20 06:37 96,520 ----a-w C:\Windows\system32\drivers\avgldx86.sys
2008-06-20 06:37 69,128 ----a-w C:\Windows\system32\drivers\avgwfpx.sys
2008-06-20 06:37 12,936 ----a-w C:\Windows\system32\drivers\avgrkx86.sys
2008-06-20 06:37 10,520 ----a-w C:\Windows\System32\avgrsstx.dll
2008-06-16 13:55 --------- d-----w C:\Program Files\Common Files\Adobe
2008-06-14 23:49 174 --sha-w C:\Program Files\desktop.ini
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Sidebar
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Photo Gallery
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Mail
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Journal
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Defender
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Collaboration
2008-06-14 23:40 --------- d-----w C:\Program Files\Windows Calendar
2008-06-14 23:34 --------- d-----w C:\ProgramData\NVIDIA
2008-06-14 23:22 82,432 ----a-w C:\Windows\System32\axaltocm.dll
2008-06-14 23:22 101,888 ----a-w C:\Windows\System32\ifxcardm.dll
2008-06-14 23:05 --------- d-----w C:\Program Files\Opera
2008-06-14 22:43 --------- d-----w C:\Program Files\MagicISO
2008-05-30 12:33 --------- d-----w C:\ProgramData\avg8
2008-05-28 18:11 --------- d-----w C:\ProgramData\Microsoft Help
2008-05-23 21:33 --------- d-----w C:\Users\Thomas\AppData\Roaming\FileZilla
2008-05-18 14:53 --------- d-----w C:\Users\Thomas\AppData\Roaming\Apple Computer
2008-05-18 14:50 --------- d-----w C:\Program Files\Apple Software Update
2008-05-12 12:53 --------- d-----w C:\Users\Thomas\AppData\Roaming\Download Manager
2008-05-10 01:33 113,664 ----a-w C:\Windows\system32\drivers\rmcast.sys
2008-05-09 12:40 --------- d-----w C:\Program Files\Google
2008-05-02 11:12 --------- d-----w C:\Users\Thomas\AppData\Roaming\Vso
2008-05-02 11:11 47,360 ----a-w C:\Windows\system32\drivers\pcouffin.sys
2008-05-02 11:11 47,360 ----a-w C:\Users\Thomas\AppData\Roaming\pcouffin.sys
2008-05-02 11:00 --------- d-----w C:\Users\Thomas\AppData\Roaming\CyberLink
2008-05-02 11:00 --------- d-----w C:\ProgramData\CyberLink
2008-05-02 10:59 --------- d-----w C:\Program Files\Common Files\CyberLink
2008-05-02 10:56 --------- d-----w C:\Program Files\CyberLink
2008-05-02 10:55 505,128 ----a-w C:\Windows\System32\msvcp71.dll
2008-05-02 10:55 353,576 ----a-w C:\Windows\System32\msvcr71.dll
2008-05-02 10:55 29,480 ----a-w C:\Windows\System32\msxml3a.dll
2008-05-02 09:04 --------- d-----w C:\Program Files\Microsoft Works
2008-05-02 09:03 --------- d-----w C:\Program Files\MSBuild
2008-05-02 09:00 --------- d-----w C:\Program Files\Microsoft.NET
2008-05-02 08:50 --------- d-----w C:\Program Files\Microsoft Visual Studio 8
2008-04-29 03:54 181,760 ----a-w C:\Windows\System32\fsquirt.exe
2008-04-29 01:42 29,184 ----a-w C:\Windows\system32\drivers\BTHUSB.SYS
2008-04-29 01:42 220,160 ----a-w C:\Windows\system32\drivers\bthport.sys
2008-04-28 15:18 --------- d-----w C:\Program Files\Apache Software Foundation
2008-04-26 08:08 1,314,816 ----a-w C:\Windows\System32\quartz.dll
2008-04-25 04:35 826,880 ----a-w C:\Windows\System32\wininet.dll
2008-04-02 16:01 2,560 ----a-w C:\Windows\_MSRSTRT.EXE
2008-03-26 20:02 21 ---ha-w C:\qpmd8379.bin
2008-03-26 20:01 36,864 ----a-w C:\Windows\System32\cfperfmon_8.dll
2008-03-05 08:18 76 --sh--r C:\Windows\CT4CET.bin
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\UEAFOverlay]
@={F2F31467-B1AC-4df0-AE79-FD5FA085E22B}
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\UEAFOverlayOpen]
@={A3E208F7-0E3A-4182-A7A6-B169D5D691AA}
[HKEY_CLASSES_ROOT\CLSID\{F2F31467-B1AC-4df0-AE79-FD5FA085E22B}]
2007-04-17 01:13 721408 --a------ C:\Program Files\Fingerprint Reader Suite\farchns.dll
[HKEY_CLASSES_ROOT\CLSID\{A3E208F7-0E3A-4182-A7A6-B169D5D691AA}]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"ehTray.exe"="C:\Windows\ehome\ehTray.exe" [2008-01-19 09:33 125952]
"swg"="C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-03-05 10:27 68856]
"msnmsgr"="C:\Program Files\Windows Live\Messenger\msnmsgr.exe" [2007-10-18 12:34 5724184]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"ECenter"="C:\Dell\E-Center\EULALauncher.exe" [2007-05-25 08:03 17920]
"Apoint"="C:\Program Files\DellTPad\Apoint.exe" [2007-09-07 10:50 159744]
"OEM02Mon.exe"="C:\Windows\OEM02Mon.exe" [2007-08-28 07:51 36864]
"SunJavaUpdateSched"="c:\Program Files\Java\jre1.6.0\bin\jusched.exe" [2008-03-05 10:14 77824]
"PSQLLauncher"="C:\Program Files\Fingerprint Reader Suite\launcher.exe" [2007-04-17 00:50 49168]
"DELL Webcam Manager"="C:\Program Files\Dell\Dell Webcam Manager\DellWMgr.exe" [2007-07-27 18:43 118784]
"IAAnotif"="C:\Program Files\Intel\Intel Matrix Storage Manager\Iaanotif.exe" [2007-03-21 15:00 174872]
"Google Desktop Search"="C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" [2008-03-05 10:27 1838592]
"PCMService"="C:\Program Files\Dell\MediaDirect\PCMService.exe" [2007-11-01 17:39 189736]
"AVG8_TRAY"="C:\PROGRA~1\AVG\AVG8\avgtray.exe" [2008-06-20 08:37 1231128]
"RegistryMechanic"="" []
"Adobe Reader Speed Launcher"="C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 22:16 39792]
"GrooveMonitor"="C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe" [2007-08-24 07:00 33648]
"RemoteControl8"="C:\Program Files\CyberLink\PowerDVD8\PDVD8Serv.exe" [2008-03-20 20:23 83240]
"PDVD8LanguageShortcut"="C:\Program Files\CyberLink\PowerDVD8\Language\Language.exe" [2007-12-14 11:36 50472]
"BDRegion"="C:\Program Files\Cyberlink\Shared Files\brs.exe" [2008-03-21 10:21 91432]
"NBKeyScan"="C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe" [2008-02-18 17:29 2221352]
"SigmatelSysTrayApp"="C:\Program Files\SigmaTel\C-Major Audio\WDM\sttray.exe" [2007-12-03 06:28 405504]
"NvSvc"="C:\Windows\system32\nvsvc.dll" [2007-10-04 21:24 86016]
"NvCplDaemon"="C:\Windows\system32\NvCpl.dll" [2007-10-04 21:24 8497696]
"NvMediaCenter"="C:\Windows\system32\NvMcTray.dll" [2007-10-04 21:24 81920]
"NVHotkey"="C:\Windows\system32\nvHotkey.dll" [2007-10-04 21:24 86016]
"QuickTime Task"="C:\Program Files\QuickTime\QTTask.exe" [2008-05-27 10:50 413696]
"iTunesHelper"="C:\Program Files\iTunes\iTunesHelper.exe" [2008-06-02 11:13 267048]
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
BTTray.lnk - C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe [2006-11-03 19:55:50 703280]
QuickSet.lnk - C:\Program Files\Dell\QuickSet\quickset.exe [2007-09-07 18:27:08 1180952]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"DisableCAD"= 1 (0x1)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\psfus]
C:\Windows\system32\psqlpwd.dll 2007-04-17 01:04 86528 C:\Windows\System32\psqlpwd.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Wdf01000.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiSpyware]
"DisableMonitoring"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\FirewallRules]
"{537AA1EE-1FF3-4289-B93B-5A151A559062}"= C:\Program Files\Dell\MediaDirect\MediaDirect.exe:Dell MediaDirect
"{90F331AB-EF9D-49CE-9785-8F6A7E6E2E24}"= C:\Program Files\Dell\MediaDirect\PCMService.exe:CyberLink PowerCinema Resident Program
"{6EC79BFD-88B5-40B2-98B9-3773C23911F5}"= C:\Program Files\Dell\MediaDirect\Kernel\DMP\CLBrowserEngine.exe:Cyberlink Media Server Browser Engine
"{DE9D9F40-D88F-4B03-8C0D-DFA5740AAABA}"= C:\Program Files\Dell\MediaDirect\Kernel\DMS\CLMSService.exe:CyberLink Media Server
"{1AB9B7CC-62D2-41A7-BBB1-85509F0D31A1}"= UDP:C:\Program Files\Bonjour\mDNSResponder.exe:Bonjour
"{3F310063-A459-4735-B62A-33736DDD0829}"= TCP:C:\Program Files\Bonjour\mDNSResponder.exe:Bonjour
"{5A24759B-EF3F-4429-ADB4-EF34E15A1C68}"= C:\Program Files\Windows Live\Messenger\livecall.exe:Windows Live Messenger (Phone)
"{104DFCAD-1E9D-47CC-808D-BBB11393594F}"= C:\Program Files\AVG\AVG8\avgupd.exe:avgupd.exe
"{6259906D-159A-4C74-917A-4F5DB3B679A0}"= C:\Program Files\AVG\AVG8\avgnsx.exe:avgnsx.exe
"TCP Query User{28EE6A68-597A-4F3D-933A-261B391AA73B}C:\\users\\thomas\\desktop\\counter-strike v1.6\\counter-strike v1.6\\hl.exe"= UDP:C:\users\thomas\desktop\counter-strike v1.6\counter-strike v1.6\hl.exe:hl.exe
"UDP Query User{5EA63969-16D7-4DF8-8B03-8CB66C30CD49}C:\\users\\thomas\\desktop\\counter-strike v1.6\\counter-strike v1.6\\hl.exe"= TCP:C:\users\thomas\desktop\counter-strike v1.6\counter-strike v1.6\hl.exe:hl.exe
"{7A3D9836-01AE-43D0-BE66-075986423D72}"= TCP:6004|C:\Program Files\Microsoft Office\Office12\outlook.exe:Microsoft Office Outlook
"{10ECA484-A00A-4429-A215-249F5C140862}"= UDP:C:\Program Files\Microsoft Office\Office12\GROOVE.EXE:Microsoft Office Groove
"{470E2D45-F3D0-48D9-AB3B-252CB8CE0FA0}"= TCP:C:\Program Files\Microsoft Office\Office12\GROOVE.EXE:Microsoft Office Groove
"{EFA619F7-E892-4031-AC35-BBC4B8A4AD18}"= UDP:C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{117AA113-E6D9-4FE2-AF7E-25F8C92584A5}"= TCP:C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{9B1A1582-DE67-4375-898A-19EACA28EBD3}"= C:\Program Files\CyberLink\PowerDVD8\PowerDVD8.EXE:CyberLink PowerDVD 8.0
"{34C5F569-F033-4DA7-BADB-7189BD5195FC}"= UDP:C:\Program Files\iTunes\iTunes.exe:iTunes
"{F9E4C988-F42C-4714-8F3A-58F31F0F91B6}"= TCP:C:\Program Files\iTunes\iTunes.exe:iTunes
"{EC7598A4-4980-4008-AA50-5BE66C3CB55F}"= UDP:C:\Program Files\nusphere\phped\Srv.exe:NuSphere PhpED SRV web server
"{2D0238C2-FC4A-463B-84AE-536D3CC92A65}"= TCP:C:\Program Files\nusphere\phped\Srv.exe:NuSphere PhpED SRV web server
"{743BA8C9-5CEC-490C-8D0C-48A704308F56}"= UDP:C:\Program Files\nusphere\phped\debugger\DbgListener.exe:NuSphere PhpED Dbg Listener
"{EBF13851-56E5-465F-8C6E-639F1FB6B837}"= TCP:C:\Program Files\nusphere\phped\debugger\DbgListener.exe:NuSphere PhpED Dbg Listener
"{C55A4729-5003-4A87-A1DB-604D6CC2BD31}"= UDP:C:\Program Files\nusphere\phped\phped.exe:NuSphere PhpED Embedded browser
"{91FD1E0A-CDBF-4C45-8B2E-5449C7161F95}"= TCP:C:\Program Files\nusphere\phped\phped.exe:NuSphere PhpED Embedded browser
R0 AvgRkx86;avgrkx86.sys;C:\Windows\system32\Drivers\avgrkx86.sys [2008-06-20 08:37]
R1 AvgLdx86;AVG AVI Loader Driver x86;C:\Windows\system32\Drivers\avgldx86.sys [2008-06-20 08:37]
R2 {FE4C91E7-22C2-4D0C-9F6B-82F1B7742054};{FE4C91E7-22C2-4D0C-9F6B-82F1B7742054};C:\Program Files\CyberLink\PowerDVD8\000.fcl [2008-02-01 17:24]
R2 AESTFilters;Andrea ST Filters Service;C:\Windows\system32\aestsrv.exe [2007-12-03 06:27]
R2 avg8wd;AVG8 WatchDog;C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2008-06-20 08:37]
R3 AvgWfpX;AVG8 Firewall Driver x86;C:\Windows\system32\Drivers\avgwfpx.sys [2008-06-20 08:37]
R3 OEM02Dev;Creative Camera OEM002 Driver;C:\Windows\system32\DRIVERS\OEM02Dev.sys [2007-08-28 07:51]
R3 OEM02Vfx;Creative Camera OEM002 Video VFX Driver;C:\Windows\system32\DRIVERS\OEM02Vfx.sys [2007-08-28 07:51]
R3 yukonwlh;NDIS6.0 Miniport Driver for Marvell Yukon Ethernet Controller;C:\Windows\system32\DRIVERS\yk60x86.sys [2007-12-06 09:51]
S2 Apache2.2;Apache2.2;"C:\Program Files\Apache Software Foundation\Apache2.2\bin\httpd.exe" -k runservice []
S3 btwaudio;Bluetooth-lydenhet;C:\Windows\system32\drivers\btwaudio.sys [2006-11-07 03:37]
S3 btwavdt;Bluetooth AVDT;C:\Windows\system32\drivers\btwavdt.sys [2006-11-07 01:13]
S3 btwrchid;btwrchid;C:\Windows\system32\DRIVERS\btwrchid.sys [2006-11-07 01:13]
S3 R300;R300;C:\Windows\system32\DRIVERS\atikmdag.sys [2006-11-02 09:36]
S3 wampapache;wampapache;"c:\WAMP\bin\apache\apache2.2.8\bin\httpd.exe" -k runservice []
S3 wampmysqld;wampmysqld;c:\WAMP\bin\mysql\mysql5.0.51a\bin\mysqld-nt.exe wampmysqld []
S4 iaNvStor;Intel® Turbo Memory Controller;C:\Windows\system32\drivers\ianvstor.sys [2007-09-07 11:27]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
bthsvcs REG_MULTI_SZ BthServ
Contents of the 'Scheduled Tasks' folder
"2008-03-14 19:13:06 C:\Windows\Tasks\Se etter oppdateringer for Windows Live Toolbar.job"
- C:\Program Files\Windows Live Toolbar\MSNTBUP.EXE
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-06-26 12:54:41
Windows 6.0.6001 Service Pack 1 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
------------------------ Other Running Processes ------------------------
C:\Windows\System32\audiodg.exe
C:\Program Files\Fingerprint Reader Suite\upeksvr.exe
C:\Windows\System32\wlanext.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\IAANTmon.exe
C:\Windows\System32\IoctlSvc.exe
C:\Windows\System32\stacsv.exe
C:\PROGRA~1\AVG\AVG8\avgam.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\Windows\System32\conime.exe
C:\Program Files\DellTPad\hidfind.exe
C:\Program Files\DellTPad\ApntEx.exe
C:\Windows\System32\wbem\WMIADAP.exe
C:\Windows\servicing\TrustedInstaller.exe
Completion time: 2008-06-26 13:01:32 - machine was rebooted
ComboFix-quarantined-files.txt 2008-06-26 11:01:09
Pre-Run: 159,756,382,208 byte ledig
Post-Run: 159,650,988,032 byte ledig
324 --- E O F --- 2008-06-26 10:08:00
Endret av php_user
Kopiere fet tekst under bildet->åpne notisblokk og lim inn.
Lagre på skrivebordet som CFScript.txt
Gjør som på bildet combofix vil starte,Post logg c:\combofix.txt
File::
Start HijackThis "scan" finn disse linjene merk dem,så trykk fix checked.
Last ned kjør CCleaner
'Valg'->'Avansert'. Fjern avkryssingen framfor: "bare slett midlertidige filer som er eldere enn 48 t.
Kjør register-renser"svar ja til og reparere"(kjør en par ganger til alle feil er borte)
Last ned oppdatere og kjør full scan SAS free
Post loggen fra SAS (preferences->statistics/logs)
Restart
Lag en ny hijackthis logg.
Ardamax Keylogger er dette noe du har innstalert?
http://www.ardamax.com/keylogger/
Endret av SNIPPSAT
Hvis du fulgte veilidningen til snippsat, skal du ha postet en logg fra SUPERAntiSpyware. Jeg tipper at dette programmet fjernet de filene du ikke fant i HijackThis. Post logg fra SAS ;)
Post ny HijackThis-logg, så ser vi fort hva som fortsatt er der :)
Du svarte heller ikke på spørsmålet om du selv installerte adamax keylogger
Endret av r2d290
Har ikke kommet så langt :p
Driver å scanner med SAS nå.
Det har jeg ikke instalert nei..
Endret av php_user
File::
Restart
hijackthis logg:
ComboFix 08-06-20.4 - Thomas 2008-06-26 15:52:55.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.1.1044.18.2045 [GMT 2:00]
Command switches used :: C:\Users\Thomas\Desktop\CFScript.txt
FILE ::
2008-06-26 13:30 . 2008-02-28 14:26 1,414,440 --a------ C:\Windows\System32\ShellManager310E2D762.dll
2008-06-26 13:30 . 2008-02-28 14:01 774,144 --a------ C:\Windows\System32\NEROINSTAEC43759.DB
2008-06-26 13:29 . 2008-06-26 13:29 0 --a------ C:\Windows\Irremote.ini
2008-06-08 19:56 . 2008-06-26 13:31 <DIR> d-------- C:\Users\All Users\Nero
2008-06-08 19:56 . 2008-06-26 13:31 <DIR> d-------- C:\ProgramData\Nero
2008-06-08 19:56 . 2008-06-26 13:31 <DIR> d-------- C:\Program Files\Common Files\Nero
2008-06-26 11:16 --------- d--h--w C:\Program Files\InstallShield Installation Information
((((((((((((((((((((((((((((( snapshot@2008-06-26_13.00.24.04 )))))))))))))))))))))))))))))))))))))))))
- 2008-06-26 10:53:42 67,584 --s-a-w C:\Windows\bootstat.dat
+ 2008-06-26 13:40:21 67,584 --s-a-w C:\Windows\bootstat.dat
+ 2008-06-26 13:40:21 2,048 --sha-w C:\Windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2008-06-26 13:40:21 2,048 --sha-w C:\Windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2008-06-26 10:54:23 262,144 --sha-w C:\Windows\ServiceProfiles\LocalService\NTUSER.DAT
+ 2008-06-26 13:41:39 262,144 --sha-w C:\Windows\ServiceProfiles\LocalService\NTUSER.DAT
+ 2008-06-26 13:41:39 262,144 ---ha-w C:\Windows\ServiceProfiles\LocalService\ntuser.dat.LOG1
- 2008-06-26 10:54:23 262,144 --sha-w C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT
+ 2008-06-26 13:42:17 262,144 --sha-w C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT
+ 2008-06-26 13:42:17 262,144 ---ha-w C:\Windows\ServiceProfiles\NetworkService\ntuser.dat.LOG1
- 2008-06-26 10:08:05 101,748 ----a-w C:\Windows\System32\perfc009.dat
+ 2008-06-26 13:47:52 101,748 ----a-w C:\Windows\System32\perfc009.dat
- 2008-06-26 10:08:05 76,976 ----a-w C:\Windows\System32\perfc014.dat
+ 2008-06-26 13:47:52 76,976 ----a-w C:\Windows\System32\perfc014.dat
- 2008-06-26 10:08:05 589,750 ----a-w C:\Windows\System32\perfh009.dat
+ 2008-06-26 13:47:52 589,750 ----a-w C:\Windows\System32\perfh009.dat
- 2008-06-26 10:08:05 454,906 ----a-w C:\Windows\System32\perfh014.dat
+ 2008-06-26 13:47:52 454,906 ----a-w C:\Windows\System32\perfh014.dat
- 2008-06-26 10:55:53 7,146 ----a-w C:\Windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2801329700-972398259-1524645511-1000_UserData.bin
+ 2008-06-26 13:42:32 7,478 ----a-w C:\Windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2801329700-972398259-1524645511-1000_UserData.bin
- 2008-06-26 10:55:53 65,786 ----a-w C:\Windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2008-06-26 13:42:32 65,810 ----a-w C:\Windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2008-06-26 11:58:24 2,670 ----a-w C:\Windows\System32\WDI\ERCQueuedResolutions.dat
- 2008-06-26 10:03:26 49,820 ----a-w C:\Windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2008-06-26 13:42:30 49,860 ----a-w C:\Windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
REGEDIT4
"NBKeyScan"="C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe" [ ]
@="Driver"
R2 {FE4C91E7-22C2-4D0C-9F6B-82F1B7742054};{FE4C91E7-22C2-4D0C-9F6B-82F1B7742054};C:\Program Files\CyberLink\PowerDVD8�0.fcl [2008-02-01 17:24]
*Newly Created Service* - CATCHME
Rootkit scan 2008-06-26 15:56:24
hidden files: 0
Completion time: 2008-06-26 15:57:59
ComboFix-quarantined-files.txt 2008-06-26 13:57:46
ComboFix2.txt 2008-06-26 11:01:34
Pre-Run: 159,035,666,432 byte ledig
Post-Run: 159,006,175,232 byte ledig
314 --- E O F --- 2008-06-26 10:08:00
- Disse filene var ikke der nå.
- Ja, da er det gjort.
Loggen fra SAS:
SUPERAntiSpyware Scan Log
http://www.superantispyware.com
Generated 06/26/2008 at 05:32 PM
Application Version : 4.15.1000
Core Rules Database Version : 3491
Trace Rules Database Version: 1482
Scan type : Complete Scan
Total Scan Time : 00:56:05
Memory items scanned : 598
Memory threats detected : 0
Registry items scanned : 7198
Registry threats detected : 0
File items scanned : 29485
File threats detected : 1
Trojan.Downloader-Gen/Suspicious
C:\USERS\THOMAS\DOCUMENTS\DOWNLOADS\***! [LATEST VERSION]\PATCH.EXE
Restart
- Det er gjort.
[url="http://www.ardamax.com/keylogger/"]http://www.ardamax.com/keylogger/[/url]
- Nei, jeg har ikke instalert dette.
- Ny logg:
Scan saved at 17:49:35, on 26.06.2008
Boot mode: Normal
Running processes:
C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Windows\System32\notepad.exe
C:\Program Files\uTorrent\uTorrent.exe
C:\Windows\system32\DllHost.exe
O3 - Toolbar: (no name) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - (no file)
O4 - HKCU\..\Run: [sUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
End of file - 10948 bytes
- Er viruset borte nå? Hva må jeg gjøre nå?
Endret av php_user
Ja da bør vi få bort alle rester fra Ardamax Keylogger,den er ikke noe særlig og ha på systemet.
Lag et nytt CFScript.txt av fet tekst.
Samme rutine som i post #7
Huske og poste combofix loggen.
Dette er for og se at CFScript.txt har virket og det kan dukke opp noe mere.
File::
Folder::
Endret av SNIPPSAT
File::
Folder::
Combofix loggen ser slik ut nå:
ComboFix 08-06-20.4 - Thomas 2008-06-26 21:42:32.3 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.1.1044.18.1919 [GMT 2:00]
Running from: C:\Users\Thomas\Desktop\Rens, Virus, Spyware\ComboFix\ComboFix.exe
Command switches used :: C:\Users\Thomas\Desktop\Rens, Virus, Spyware\ComboFix\CFScript.txt
FILE ::
C:\Windows\System32\test\
2008-06-26 16:34 . 2008-06-26 16:34 <DIR> d-------- C:\Users\Thomas\AppData\Roaming\SUPERAntiSpyware.com
2008-06-26 16:34 . 2008-06-26 16:34 <DIR> d-------- C:\Users\All Users\SUPERAntiSpyware.com
2008-06-26 16:34 . 2008-06-26 16:34 <DIR> d-------- C:\ProgramData\SUPERAntiSpyware.com
2008-06-26 16:34 . 2008-06-26 16:34 <DIR> d-------- C:\Program Files\SUPERAntiSpyware
2008-06-26 16:33 . 2008-06-26 16:33 <DIR> d-------- C:\Program Files\Common Files\Wise Installation Wizard
2008-06-26 15:52 --------- d-----w C:\Users\Thomas\AppData\Roaming\uTorrent
2008-06-26 15:26 --------- d--h--w C:\Program Files\InstallShield Installation Information
2008-06-26 15:20 --------- d-----w C:\Program Files\CCleaner
+ 2008-06-26 15:34:50 67,584 --s-a-w C:\Windows\bootstat.dat
- 2008-06-20 16:26:51 51,200 ----a-w C:\Windows\inf\infpub.dat
+ 2008-06-26 15:24:14 51,200 ----a-w C:\Windows\inf\infpub.dat
- 2008-06-20 16:26:51 86,016 ----a-w C:\Windows\inf\infstor.dat
+ 2008-06-26 15:24:14 86,016 ----a-w C:\Windows\inf\infstor.dat
- 2008-06-20 16:26:50 143,360 ----a-w C:\Windows\inf\infstrng.dat
+ 2008-06-26 15:24:14 143,360 ----a-w C:\Windows\inf\infstrng.dat
+ 2008-06-26 14:34:08 34,304 ----a-r C:\Windows\Installer\{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}\IconCDDCBBF1.exe
+ 2008-06-26 15:34:51 2,048 --sha-w C:\Windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2008-06-26 15:34:51 2,048 --sha-w C:\Windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2008-06-26 15:36:48 262,144 --sha-w C:\Windows\ServiceProfiles\LocalService\NTUSER.DAT
+ 2008-06-26 15:36:48 262,144 ---ha-w C:\Windows\ServiceProfiles\LocalService\ntuser.dat.LOG1
+ 2008-06-26 15:36:53 262,144 --sha-w C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT
+ 2008-06-26 15:36:53 262,144 ---ha-w C:\Windows\ServiceProfiles\NetworkService\ntuser.dat.LOG1
+ 2008-06-26 15:41:29 101,748 ----a-w C:\Windows\System32\perfc009.dat
+ 2008-06-26 15:41:29 76,976 ----a-w C:\Windows\System32\perfc014.dat
+ 2008-06-26 15:41:29 589,750 ----a-w C:\Windows\System32\perfh009.dat
+ 2008-06-26 15:41:29 454,906 ----a-w C:\Windows\System32\perfh014.dat
+ 2008-06-26 15:37:05 7,538 ----a-w C:\Windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2801329700-972398259-1524645511-1000_UserData.bin
+ 2008-06-26 15:37:05 66,282 ----a-w C:\Windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2008-06-26 15:37:03 50,064 ----a-w C:\Windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
- 2008-06-21 22:23:58 164,716 ----a-w C:\Windows\System32\WDI\SuspendPerformanceDiagnostics_SystemData_S3.bin
+ 2008-06-26 14:24:25 176,170 ----a-w C:\Windows\System32\WDI\SuspendPerformanceDiagnostics_SystemData_S3.bin
-- Snapshot reset to current date --
REGEDIT4
"SUPERAntiSpyware"="C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2008-05-28 10:33 1506544]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\shellexecutehooks]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= C:\Program Files\SUPERAntiSpyware\SASSEH.DLL [2008-05-13 10:13 77824]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
C:\Program Files\SUPERAntiSpyware\SASWINLO.dll 2007-04-19 13:41 294912 C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
@="Driver"
Rootkit scan 2008-06-26 21:45:49
hidden files: 0
Completion time: 2008-06-26 21:47:23
ComboFix-quarantined-files.txt 2008-06-26 19:47:18
Pre-Run: 170,074,906,624 byte ledig
Post-Run: 170,044,325,888 byte ledig
329 --- E O F --- 2008-06-26 10:08:00
Er det fikset nå? Hva skal jeg gjøre nå?
Ser bra ut.
Kjøre en runde med CCleaner.
Nå scanner du med avg og ser om det er greit.
Gi tilbakemelding,så må vi fjerne bakcup som combofix lager.
AVG Fant ingen ting i c:\windows nå :)
Hvordan fjerner jeg backup som combofix lager ???
Endret av php_user
Jepp programet skal vekk.
Combofix er ikke noe vanelig verktøy du skal bruke.
Har du mistanke til noe kan du laste ned på nytt(kommer stadig oppdatringer i den)
Da gjør du som nå poster combofix loggen her.
SAS derimot fortsetter du og bruke en gang iblant.
Surf trygt.
Endret av SNIPPSAT
Dersom du mener at problemet med maskinen din er løst, kan du endre emnetittelen din, ved å trykke på p_edit.gif i førsteposten din, og velge full endring. Øverst der emnetittelen din er, skriver du:
[LØST]
foran emnetittelen din.
Eks: [LØST] Har fått virus på maskinen
Dette vil være med på å holde forumet mer oversiktlig for supporterne, samt at nye folk som får samme problemet lettere vil finne en passende tråd å se i.
-Surf trygt-
