Trenger hjelp med lockdown v2.1 (PSP)
Benbels
Hei!
Jeg trenger litt hjelp med lockdowen til pspen min : )
Sitat fra read me:
1. Open flash0 via USB. Go to flash0:/vsh/module folder. Make sure you have enough free space to install both the files.
2. Rename the vshmain.prx to vshmain_real.prx
3. Paste the vshmain.prx from the archive into this folder.
3. Reboot PSP. You will see the password screen asking you to set a new password. You can use the PSP face buttons, the D-Pad and L-Trigger & R-Trigger. You can enter a maximum of 10 buttons. Press Start after you are done. It will ask you to re-type the password for confirmation. Then choose the mode you want (ask password only on reboot, or ask password everytime XMB is started). After that the XMB will launch.
4. If the above worked out correctly, then you can now proceed to protect the recovery menu. If it didn't work then use recovery mode to restore your original vshmain.prx. To protect recovery mode, open flash0 via USB and go to the flash0:/vsh/module folder. Rename the recovery.prx to recovery_real.prx
5. Paste the recovery.prx from the archive into this folder.
Sitat slutt.
Det jeg lurer på er hvordan kommer jeg til mappa "module folder"? Jeg finner den ikke når jeg er inne på flash0.
Takker for svar :)
Endret av Baby B
Hei!
Sitat fra read me:
Sitat slutt.
Takker for svar :)
Faktisk å skjønner jeg ikke hva du driver med. Hva mener du med lockdowen?
