Athlon XP-M (DTR), hvor selges det?
mandela
The mobile AMD Athlon XP-M processors are compatible with AMD’s Socket A infrastructure, and support the advanced 266MHz AMD Athlon front-side bus. The low-voltage mobile AMD Athlon XP-M processors are pin compatible with Socket A infrastructure, but are packaged in a smaller uPGA package. Mobile AMD Athlon XP-M processors are manufactured using AMD’s 0.13 micron copper process technology at Fab 30 in Dresden, Germany.
itbutikken selger mobile cpu's løst til gode priser, men itbutikken er en kjip butikk
