Spørsmål om reinstallering av Vista.
Sorry for engelsk, men orker ikke å oversette.. Har posta det på andre sider også~ Kan oversette hvis noen spør da..
Hi.
I dual boot XP and Vista, and it is working great. But i want to have vista x64 and not x86. Will there be any problems if i delete Vista, and install it on same partition (64 bit this time)? Alternately deleting Vista, installing XP again, and then, from XP upgrading or doing a clean install to Vista 64. I've had a lot of problems with the boot loader before, so I figured i wanted to be on the safe side.
Also, would it be possible just to insert the Vista CD while inside Vista, and doing a clean install from there?
In advance, thank you.
Mads, Norway.
Mads, Norway.
" sorry " for at jeg gidder å svare, men hvis du ikke " orker å oversette " så dårlig engelsk så er det ingen som forstår hva du mener.
f.e.
>>Also, would it be possible just to insert the Vista CD while inside Vista, and doing a clean install from there?<<
for meg høres dette helt tullete ut, men jeg tror jeg forstår hva du mener og svaret er: nei
lykke til
