Får feilmelding i boot
Jeg kjører Ubuntu og XP. Installerte fort kort tid siden Partition Magic for å justere en partisjon, får så beskjed om at maskinen på omstartes. Dette er en sekundør NTFS-partisjon, så jeg forstår egentlig ikke det helt.
Når jeg nå skal starte opp, kommer meldingen:
GRUB loading, please wait...
Error 17
Er det GRUB som ikke er venn med den ikke-tildelte partisjonen?
Trenger hjelp.
menu.lst
# menu.lst - See: grub(8), info grub, update-grub(8)
#			grub-install(8), grub-floppy(8),
#			grub-md5-crypt, /usr/share/doc/grub
#			and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default
entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default		4
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default
entry
# (normally the first entry defined).
timeout		20
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive
editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
## password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title		Windows 95/98/NT/2000
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kernel	/vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##	  kopt_2_6_8=root=/dev/hdc1 ro
##	  kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=90ac0c84-167c-4299-9d71-dfa97309239f ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,6)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##	  alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##	  lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
##	  lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##	  altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##	  howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##	  memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title		Ubuntu 7.10, kernel 2.6.22-14-generic
root		(hd0,6)
kernel		/boot/vmlinuz-2.6.22-14-generic
root=UUID=90ac0c84-167c-4299-9d71-dfa97309239f ro quiet splash
initrd		/boot/initrd.img-2.6.22-14-generic
quiet
title		Ubuntu 7.10, kernel 2.6.22-14-generic (recovery mode)
root		(hd0,6)
root=UUID=90ac0c84-167c-4299-9d71-dfa97309239f ro single
title		Ubuntu 7.10, memtest86+
root		(hd0,6)
kernel		/boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title		Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title		Microsoft Windows XP Professional
root		(hd0,0)
savedefault
makeactive
chainloader	+1
# This entry automatically added by the Debian installer for an existing
# linux installation on /dev/sda2.
title		Ubuntu 7.10, kernel 2.6.22-14-generic (on /dev/sda2)
root		(hd0,1)
root=UUID=0f099e49-a17b-44d3-9103-338ee7489f7a ro quiet splash
savedefault
boot
title		Ubuntu 7.10, kernel 2.6.22-14-generic (recovery mode) (on /dev/sda2)
root		(hd0,1)
root=UUID=0f099e49-a17b-44d3-9103-338ee7489f7a ro single
savedefault
boot
title		Ubuntu 7.10, memtest86+ (on /dev/sda2)
root		(hd0,1)
savedefault
boot
menu.lst.backup
## default num
entry
default		0
## timeout sec
entry
timeout		10
## hiddenmenu
#hiddenmenu
# Pretty colours
editing
# command 'lock'
# examples
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
## e.g. crashdump=1
# crashdump=0
# groot=(hd0,6)
# alternative=true
## alternatives
##	  lockold=true
# lockold=false
# xenhopt=
## e.g. howmany=all
##	  howmany=7
# howmany=all
##	  memtest86=false
# memtest86=true
# savedefault=false
root		(hd0,6)
quiet
root		(hd0,6)
root		(hd0,6)
quiet
# ones.
root
# on /dev/sda1
root		(hd0,0)
savedefault
makeactive
chainloader	+1
root		(hd0,1)
savedefault
boot
root		(hd0,1)
savedefault
boot
root		(hd0,1)
savedefault
boot
Endret av Vidi
