FW 4.00 til PSP
Ny firmware til PSP på vei:
I wanted to give you all a heads up that a new PSP system software update, v4.00, will be released soon, adding Google Internet search directly to the XMB (XrossMediaBar) interface.
This new upgrade replicates the Google Internet search experience, delivering the same search results that you’d get at www.google.com. And with a search history recall of 20 items, Web searches couldn’t be easier.
After you download and install the firmware on your PSP, click on the XMB’s Network icon and then the new Internet Search icon. Enter your keywords and then let Google’s algorithms do the work. You’ll need to be connected to the Internet via a wireless access point or Wi-Fi hotspot. Googling something on the go has never been more convenient on your PSP.
Another new feature delivered through the 4.00 update is the ability to change viewing speed during playback of videos stored on your Memory Stick PRO Duo, so you can speed through or slow down what you’re watching. To do this simply press the up or down directional buttons while playing a video. Enjoy!
Kilde
Håper at de heller fokuserer på FW 2,40 til PS3. Men håper ikke at de slutter helt med PSP.
Håper at det ikke er samme folka som jobber på firmware til PS3/PSP. Nesten så jeg begynner å lure om de bare har 1 nerd som sitter å mekker firmware, er ikke mye å skryta av hverken til PSP eller PS3 for tiden.
