ATI 47xx/48xx-tråden (4770, 4850, 4870, 4890, 4850x2, 4870x2)
FrodeA
Med et 4870 kort på et hovedkort med PCI-E versjon 1/1.1(hovedkortet er P5K-E), vil jeg ikke få utnytte kortet fult ut? Siden kortet støtter PCI-E 2.0? Vet ihvertfall at de første kortene som kom med støtte for PCI-E 2.0, så merket man ikke noe forskjell fra om man hadde PCI-E 1/1.1, men hvordan er det med ATI Radeon 4870?
Syns jeg leste det tidligere i råden her, men jeg er glad for å høre det=)
Så rettere sagt....jeg har vært treg med å få med meg dette :p
Eneste som kan være greit å huske er å holde lik minnestørrelse på alle korta=)
Det viste jeg Lockbreaker:P
If everything goes according to plan, we will see AMD’s new Radeon GPU launch this week. But there is more news to this announcement and we are thinking about one special item you are unlikely to hear about: During AMD's Cinema 2.0 schmoozapalooza in The Americano restaurant in San Francisco we learned that your Radeon 3850, 3870 or 3870 X2 graphics card will hold extra value: Don’t get rid of your old card just yet.
A source close to AMD told us that there will be “inter-generation compatibility” between the Radeon 3800 and 4850: “Since they're both DirectX 10.1 parts, there is no reason why those two should not work together. (…) We will probably not qualify this interoperability, but who stops you from trying?"
It appears that ATI did not integrate a driver lock or something else that would stop you from combining a 3870 card with a 4850 or with a 4870 model. Just keep in mind that these two cards need to include the same amount of memory. If you mix and match a 3850 with 256 MB of memory with a 4850 512 MB, the 4850 card will default to 256 MB. If you wonder whether you will be able to combine a 3870 X2 card with a 4850 board, our sources indicated that this scenario should work as well.
There is nothing not to like about this interoperability. I personally believe this is a big win for the consumer: How often do you have to throw you old card away when a new generation is introduced? Usually, always (well, at least, if you are among those who try to always have the latest and greatest.)
Endret av Fluesopp
Helsinge ... Fins det ingen måter utenom å forandre shit'n i BIOS for å greie å overklokke HD4870 skikkelig ennå? Har prøvd AtiTool, PowerStrip og RivaTuner så langt but no go!!! :shrug:
Tempen min ligger under 50 grader når alt er klokka på max og den bare HYLER etter å bli klokka mere ... !!!
MEEEEREEEEEEEEEEEEEEEEEE!!!!!!!!!!!!! sier'n :D
Nei.
Er det mulig å kjøre 3x HD4870 i Crossfire?
har du nok PCI Express x16 porter ja
optil 4 stk RV770 (48x0) vil funke
du kan også mikse 4850 og 4870 ;)
Hvordan vil 3x HD4870 funke på et P5Q-Premium (P45)?
Blir det 8x / 8x / 8x da? Eller blir båndbredden enda lavere?
9 og 9.5 tommer
tommer x 2,5 = cm
Flott. :) Da har jeg ca 1 cm plass ektra. :D
Oppdater meg litt folkens; Har funnet at jeg enten kjøper 2*4850 eller 1*4870. Og jeg har funnet ut at det blir for dyt å oppgradere kjøleren(e). Så hvordan er det med varme/overklokking da?
Blir vel 8x/8x/4x
9 og 9.5 tommer
tommer x 2,5 = cm
Ville gått for 4870 der har du rimelig god kjøling og kjører jo "alt" uansett. Eller vente en måned på andre kjøleløsninger ferdig montert.
Som denne løsningen
http://www.tcmagazine.com/comments.php?sho...634&catid=2
med muligheter for å overklokke gpu til 950 og minne til 1200 (4800)
Bra viss noen finner ut at man kan legge denne tweaka bios inn på alle 4870
Endret av anordne
Jeg sitter å kuker med BIOS-modding nå :p
av det lille jeg har fått med meg er at 4870 er veldig villig hvis det får en åpen bios. går sikkert ikke lenge før det er flere fine bioser tilgjengelig.
er det den der bios editor greia fra techpoweup du styrer med?
samme gjelder powerplay, det funker visst bra hvis man tuller litt med det i bios
