ATI 47xx/48xx-tråden (4770, 4850, 4870, 4890, 4850x2, 4870x2)
FrodeA
Ikke sikker på om denne testen er linket til før men jeg fant en test med 9800gtx+ mot 4850
http://www.legitreviews.com/article/731/1/
Skal lese den nøyere nå, mulig den er fake.
Fant dette over på XS...
Quake Wars: 1920x1200 AA4x
HD 4850 : 68
9800GTX+ : 70.8
Half Life 2 : 1920x1200 AA4x
HD 4850 : 73.1
9800GTX+ : 74.2
STALKER : 1920x1200 No AA
HD 4850 : 49
9800GTX+ : 54
Rainbow Six : 1920x1200 AA4x
HD 4850 : 36.9
9800GTX+ : 32.8
Oblivion : 1920x1200 AA4x
HD 4850 : 66.3
9800GTX+ : 54.9
GRID : 1920x1200 AA4x
HD 4850 : 70
9800GTX+ : 62.8
Bioshock DX10 : 1920x1200 No AA
HD 4850 : 119.6
9800GTX+ : 108.2
Company of Heroes: 1920x1200 AA4x
HD 4850 : 38.3
9800GTX+ : 42.1
World in Conflict: 1920x1200 No AA
HD 4850 : 27
9800GTX+ : 19
Crysis DX10 : 1920x1200 AA4x
HD 4850 : 16.9
9800GTX+ : 12.5
Indice : 1920x1200 AA4x
HD 4850 : 77.4
9800GTX+ : 69.3
These are the AA4x results, except for the few games where AA didn't work I used the (No AA) numbers. The 9800GTX+ is faster in 4 games (two of those games by only 1-2 frames), while the HD 4850 is faster in 7 games.
http://www.hardware.fr/articles/724-3/b-ma...800-gtx-v2.html
- Rob
Endret av Rob Halford
HD 4850 : 68
9800GTX+ : 70.8
HD 4850 : 73.1
9800GTX+ : 74.2
HD 4850 : 49
9800GTX+ : 54
HD 4850 : 36.9
9800GTX+ : 32.8
HD 4850 : 66.3
9800GTX+ : 54.9
HD 4850 : 70
9800GTX+ : 62.8
HD 4850 : 119.6
9800GTX+ : 108.2
HD 4850 : 38.3
9800GTX+ : 42.1
HD 4850 : 27
9800GTX+ : 19
HD 4850 : 16.9
9800GTX+ : 12.5
HD 4850 : 77.4
9800GTX+ : 69.3
- Rob
Hvis dette er faktiske tall, så må jeg si nvidia skuffer litt. Trodde 9800GTX+ skulle bli endel bedre enn HD4850 ihvertfall...
-ASUS P5E3, X38, Socket-775, DDR3, ATX, Firewire, GbLAN, 2xPCI-Ex(2.0)x16 (P5E3)
-INTEL Core 2 Duo E8400 3.0GHz LGA775 FSB1333 6Mb UTEN Kjøler! (E8400bulk)
-CORSAIR Powersupply 550W Bulk, black, (CMPSU-550VXEU BULK)
Har 3gb DDR2 800 MHz fra før,
dette + HD 4850 (og evt. enda et 4850 i crossfire senere)
Alt ser ut til å fungere? Eller er det noe jeg må ta med i beregningene? :)
(om det er feil tråd for et så konkret spørsmål, og ikke bare generelt rundt 4850, beklager jeg)
Det hovedkortet krever DDR3 minne, du sier du har DDR2.
Bruk ASUS P5E, X38 hvis du ønsker å bruke DDR2 minnet ditt...
Men vil man få bruk for de 230gib. ATI har hatt en tendens til å gå largly overkill på minnebåndbredde før HD38 serien.
2900 xt og 2900 pro er de eneste kortene med 512 bit båndbredde. Både x1900 xtx og x1950 xtx hadde 256 bit båndbredde(49,6 og 64 GB/s). Dette er ikke largly overkill.
Da var det kun minnekontrolleren som var 512bit og ikke minnebussen på de førstnevnte. Kontrolleren fikk mye oppmerksomhet.
Nå skal det sies at overkill på minnebåndbredde ikke koster særlig mye (og dermed ikke er særlig med bortkasting av penger). Overkill på minnebåndbredde gir heller ikke noe særlig økt og unødvendig effektforbruk.
Hadde man gjort omvendt og hatt overkill GPU-hastighet så ville det trolig kostet mye både i form av penger og effektforbruk.
På et skjermkort står minnet for rundt 5% av effektforbruket. GPU står for rundt 93%. De to siste prosentene er effekttap i spenningskontrollerne og andre komponenter.
Hvis GDDR5 ikke koster mer enn GDDR3 så er jeg enig.
Ifølge wikipedia har 2900 xt og pro 512 bit buss width .
2900 serien hadde 512 bit minnebuss. Men det hjalp som vi vet svært lite når gpuen var for dårlig implementert.
Sikkert et bra kort, men personlig ville jeg kjøpt et kort fra Abit, x38 eller x48, ingen forskjell mm. du har tenket å overklokke endel. Dvs 500fsb+. Men du må ha P5E versionen, P5E3 er DDR3.
Kanon prosessor.
Sikkert den beste PSU'en man får for pengene, men kjøp 520w'en om den koster noenlunde det samme i den butikken du skal handle fra. Den er faktisk kraftigere.
Jeg ville ventet på 4870 og sett hvordan dette yter, det var vel 26. det var snakk om.
Endret av todda7 -2rst1-
Blir ikke 4870 en del dyrere?
Skal bort en uke nå, veldig fristende å få bestilt så jeg kan komme hjem til pc-bygging :p
Planlegger uansett crossfire (om et par lønninger) og har ikke lyst å punge ut for 2 x 4870 om de går opp i 2000 kr klassen, heller 2x 4850 da :)
todda7 -2rst1-:
(Endra hovedkortet, takk for at du sa fra, den hadde vært veldig kjip hvis jeg hadde sitti der og ikke skjønt hvorfor ingenting virka :s)
Den PSU'en er veldig billig hos komplett, de har visst 2000+ på lager så sparer 200 på å kjøpe den der.
Endret av tmg
Vel er ikke ment som klaging, 2000 er akseptabelt, men nå har jeg råd til 2x 4850 og jeg vil håpe og tro at det vil være bedre enn 1x 4870?
Jeg er en fattig skoleelev med bare deltidsjobb :(
Var ikke meninga å kalle det klaging heller, fikk bare gode minner fra noen år tilbake :wee:
