Tråden for romfergeoppdraget STS-125 - Hubble Service Mission 4
HKS
Her er aktivitetene i nedtellingen for søndag (NB! Norsk tid, CET):
Launch-1 Day (Sunday, May 10)
Resume countdown (06:00)
Begin filling pad sound suppression system water tank (07:00)
Main engine avionics, pneumatics and controller checkout completed (08:00)
Pad sound suppression system water tank filling complete (10:00)
Begin star tracker functional checks (13:50)
Enter planned hold at T-11 hours for 13 hours, 41 minutes (14:00)
Activate the orbiter's communications systems
Move Rotating Service Structure to the park position (11.05.09 - 00:00)
Perform ascent switch list
Fuel cell flow-through purge complete
Resume countdown at T-11 hours (11.05.09 - 03:41)
Clear the blast danger area of all nonessential personnel
Switch Atlantis’ purge air to gaseous nitrogen (11.05.09 - 03:51)
Activate the orbiter's fuel cells (11.05.09 - 03:51)
RSS (Rotating Service Structure) som beskytter romfergen, og gir tilgang til lasterommet er nå rotert bort fra Atlantis, og hun står klar på utskytningsrampen!
Titligere idag på L-1 pressekonferansen ble det informert om at nedtellingen går glatt, ingen problemer så langt. Metrologen har også justert opp værvarslet. Det er nå 90% sjans for at været er bra nok til oppskytning imorgen!
Rett under 20 timer igjen til oppskytning nå!
Endret av [GDI]Raptor
Aktiviteter i nedtellingen siste dag:
Launch Day (Monday, May 11)
Enter planned 2-hour built-in hold at the T-6 hour mark (08:41)
Launch team verifies no violations of launch commit criteria prior to cryogenic loading of the external tank
Clear pad of all personnel
Resume countdown (10:41)
Chill down propellant transfer lines (10:41)
Begin loading the external fuel tank with about 500,000 gallons of cryogenic propellants (10:51)
Enter planned 2-hour, 30-minute built-in hold at T-3 hours (11:41)
Complete filling the external tank with its flight load of liquid hydrogen and liquid oxygen propellants (about 11:41)
Final Inspection Team proceeds to launch pad
Perform inertial measurement unit preflight calibration
Align Merritt Island Launch Area tracking antennas
Resume countdown at T-3 hours (16:11)
Perform open loop test with Eastern Range
Crew departs Operations and Checkout Building for the pad (16:41)
Complete closeout preparations in the White Room
Check cockpit switch configurations
Begin Eastern Range final network open loop command checks
Flight crew begins entry into the orbiter (16:46)
Astronauts perform air-to-ground voice checks with Launch and Mission Control
Begin to close Atlantis’ crew hatch (18:01)
Perform hatch seal and cabin leak checks
Complete White Room closeout
Closeout crew moves to fallback area
Primary ascent guidance data is transferred to the backup flight system
Enter planned 10-minute hold at T-20 minutes (18:51)
NASA test director conducts final launch team briefings
Resume countdown at T-20 minutes (19:01)
Transition the orbiter's onboard computers to launch configuration
Start fuel cell thermal conditioning
Close orbiter cabin vent valves
Transition backup flight system to launch configuration
Enter estimated 40-minute hold at T-9 minutes (19:12)
Launch director, Mission Management Team and NASA test director conduct final polls for "go/no go" to launch
Resume countdown at T-9 minutes (19:52)
Når nedtellingen fortsetter etter T-9 minutter går de inn i det som heter terminal countdown. Kommer med detaljer om hva som skjer da litt ut over dagen!
NASA har gitt GO til å begynne å fylle romfergen sin eksterne tank med flytende hydrogen og oksygen.
Tanken rommer litt over 2 millioner liter med flytende drivstoff, og gir drivstoff til romfergen sine tre hovedmotorer (SSME) hele veien opp. (8 minutter)
Været er bra i Florida. Fremdeles 90% sjanse for bra nok vær til oppskytning idag!
Det eneste problemet kommer til å være været i Europa. Romfergen er avhengig av å ha bra vær på en TAL (Trans Atlantic Landing) landingsplass i Spania. Grunnen til dette er at hvis det skulle blitt problemer med en av romfergen sine motorer på vei opp skal de ha mulighet til å avbryte og lande trygt i Europa. Dette kalles TAL-Abort, og er en av flere muligheter til av avbryte hvis de får problemer.
Edit: Fordelen med dette oppdraget som skal til Hubble isteden for den internasjonale romstasjonen (ISS) er at oppskytningsvinduet til Hubble er på en time, til ISS varer det mellom 5 og 10 minutter.
Tankingen er fullført nå. Ingen problemer under tanking!
Inspeksjonsteamet er på vei ut til rampen nå. De skal titte over romfergen, og sørge for at det ikke er noen isklumper, frost og annen FOD på steder hvor det ikke skal være.
Litt over 6 timer igjen nå!
Oppskytningsvinduet for Hubble idag er følgende (Norsk tid):
19:41:56 - 20:43:47
Foretrukket oppskytning er 20:01:47
Inspeksjonen av Atlantis er nå snart ferdig.
Ingen problemer oppdaget så langt!
Astronautene er nå i suit-up room, og driver så å setter på seg draktene de har under oppskytning. Disse kalles "Launch and Entry Suits" og de brukes både under oppskytning og re-entry.
Om ca. 20 minutter blir astronautene kjørt ut til rampen.
Ja nå venter tre timer liggende på ryggen mens nedtellingen tikker mot 0.
Ettersom dette er en oppskyting til Hubble er oppskytingsvinduet på 60 minutter, istedet for 10 slik det er til romstasjonen. Dermed er det litt større slingringsmonn i forhold til ting som kan oppstå under nedtellingen. Dette fører også til at astronautene kan bli liggende enda en time før oppskyting
Alle astronautene er nå ombord i romfergen.
Bakkemannskapet driver nå og gjør klar kabinen til å lukke luken. Det er da viktig at de får med seg alt ut som ikke skal være med opp til verdensrommet.
T-9 minutter og pause i nedtellingen!
Dette er siste pause i nedtellingen. Det varer i ca. 40 minutter. I løpet av denne tiden skal alle forskjellige som kontrolleres i nedtellingen i GO eller NO GO for oppskytning til NASA sin Launch Director.
Når de går ut av denne siste pausen aktiveres det som kalles GLS (Ground Launch Sequencer). Dette er datamaskinen som kontrollerer nedtellingen. Denne datamaskinen har kontroll over nedtellingen helt frem til T-31 sekunder, da går man inn i det som kalles Auto Sequence Start, og Atlantis sine datamaskiner tar over kontrollen for siste del av nedtellingen.
Her er en liste over aktivitetene etter T-9 minutter:
Start automatic ground launch sequencer (T-9 minutes)
Retract orbiter crew access arm (T-7:30)
Start APU (Auxiliary Power Unit) recorders (T-6:15)
Start auxiliary power units (T-5)
Terminate liquid oxygen replenish (T-4:55)
Start orbiter aerosurface profile test (T-3:55)
Start main engine gimbal profile test (T-3:30)
Pressurize liquid oxygen tank (T-2:55)
Begin retracting the gaseous oxygen vent arm (T-2:50)
Fuel cells to internal reactants (T-2:35)
Pressurize liquid hydrogen tank (T-1:57)
Deactivate bi-pod heaters (T-1:52)
Deactivate solid rocket booster joint heaters (T-0:50 seconds)
Orbiter transfers from ground to internal power (T-0:50 seconds)
Ground launch sequencer go for auto sequence start (T-0:31 seconds)
Booster gimbal profile (T-0:21 seconds)
Ignition of three space shuttle main engines (T-6.6 seconds)
Booster ignition and liftoff (T-0)
De har nettopp hatt litt diskusjon rundt en isklump under romfergen, men de har nettopp konkludert med at det ikke blir noe problem.
Alt er klart for å fortsette nedtellingen om ca. 10 minutter
