Ybbe Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 Jeg har en netgear rp614 router, og jeg lurer på hvilke porter jeg skal åpne for å få det til å virke ??? Lenke til kommentar
teoball Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 Les FAQ'en på Dc++ sin webside (http://dcplusplus.sourceforge.net). Her er utdrag fra hvordan sette opp en aktiv oppkobling ved bruk av brannvegg: "How to set up active mode with a hardware firewall/router. Active mode requires both UDP and TCP access on the same port. First you need to set up the router to forward the connections to the computer with DC++. This is could be called Port mapping, port redirecting, port forwarding or something like that. Find out how to do this with your router, you need to forward one port (select a number between 1000 - 20000, they should mostly all be free. The default port is 1412, but it is wise to select a unique one) and make sure both UDP and TCP is forwarded. The IP that you are forwarding to should be the internal IP address of your DC++ computer. It usually begins with "192.168". When you have mapped a port, you need to open up DC++ and go to the settings. Where you select active mode, in the port field, enter the port number that you are forwarding on the router. In the IP field, you need to enter the -external- IP address of your router. This can easily be checked on several webpages (www.whatismyip.com for instance). Sometimes your IP address changes - if you have a dynamic IP - when you disconnect from your internet connection. Check your IP every now and then to make sure." Lenke til kommentar
JarleW Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 Tror det er 412 eller 411. I NMDC så... Lenke til kommentar
Thlom Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 Tror det er 412 eller 411. I NMDC så... w00t? /me skjønner ingenting. Lenke til kommentar
Lch Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 Neo Modus DC-klienten aka NMDC aka Piece Of Shit bruker port 412 som default. Hubbene bruker port 411 som default, men det trenger man ikke bry seg om når man setter opp en klient. DC++ og oDC bruker 1412 eller 'random' som default port. Capice? Lenke til kommentar
Thlom Skrevet 11. mars 2003 Del Skrevet 11. mars 2003 jepp, forstod bare ikke NMDC forkortelsen. hehe Lenke til kommentar
