Gunfreak Skrevet 14. juni 2008 Rapporter Del Skrevet 14. juni 2008 jeg driver å diskuterer med en tulling kan noen hjelpe meg å finne dirt om Jerry Bergman Lenke til kommentar
Zippio Skrevet 14. juni 2008 Rapporter Del Skrevet 14. juni 2008 jeg driver å diskuterer med en tulling kan noen hjelpe meg å finne dirt om Jerry Bergman Nja, det står vel kanskje noe på Wikipedia? står noe om at han mista jobben sin fordi han ga falske opplysninger om credentialsa hans. Veit ikke så mye om han men noen raske søk viser at han gir Evolusjon(Darwinism) store deler av skylda for Hitlers rase utryddning, og hvis de hadde trodd på gud så hadde det ikke skjedd. http://www.answersingenesis.org/tj/v13/i2/nazi.asp "Of the many factors that produced the Nazi holocaust and World War II, one of the most important was Darwin’s notion that evolutionary progress occurs mainly as a result of the elimination of the weak in the struggle for survival. Although it is no easy task to assess the conflicting motives of Hitler and his supporters, Darwinism-inspired eugenics clearly played a critical role. Darwinism justified and encouraged the Nazi views on both race and war. If the Nazi party had fully embraced and consistently acted on the belief that all humans were descendants of Adam and Eve and equal before the creator God, as taught in both the Old Testament and New Testament Scriptures, the holocaust would never have occurred." Han tror også at Evolusjon og rasisme er det samme. http://www.talkorigins.org/faqs/bergman-and-racism.html "Evolution and racism are the same thing," declares Jerry Bergman (McIver 1990:21; see Bergman's "Evolution and the Development of Nazi Race Policy" in Bible-Science Newsletter [1988] and articles in Creation Research Society Quarterly [1980], CSSHQ [1986], and Creation Ex Nihilo Technical Journal [1991, 1992]).[2] Hadde ikke så mye tid til å lese igjenom hele sidene så ta alt med en klype salt. off to the beach I go~ Lenke til kommentar
Venerable Skrevet 14. juni 2008 Rapporter Del Skrevet 14. juni 2008 (endret) Jeg er fullstendig uenig i at evolusjon har noe med rasisme å gjøre. Hvis noe, så beviser vitenskapen rundt evolusjon at fargeulikhetene blandt mennesker er på grensen til ubetydelige. Når det gjelder jødeutryddningen. Så godt som alle i Tyskland på den tiden var kristne, derfor er ideen hans bare nok et fortrengt syn på at evolusjon og ateisme er det samme. Men jeg kan godt se hvordan misforståelse av evolusjon og vitenskap ville ha forsterket Hitler sine ideer. Det største problemet med alt dette, er ikke selvmotsigelsene. Og generelt dårlige meninger. Det virker som Bergman fremmer tanken om at man kan bedømme hvor ekte noe er. Basert på hvor positivt eller negativt det er på en moralsk måte. "Bibelen er snill, derfor må den være sann" "Evolusjon skapte Nazi-Tyskland, derfor må det være usant" Endret 14. juni 2008 av LunarPoet Lenke til kommentar
Imsvale Skrevet 14. juni 2008 Rapporter Del Skrevet 14. juni 2008 Holocaust var grusomt, derfor skjedde det ikke... Lenke til kommentar
Pricks Skrevet 16. juni 2008 Rapporter Del Skrevet 16. juni 2008 jeg driver å diskuterer med en tulling kan noen hjelpe meg å finne dirt om Jerry Bergman Google+TalkOrigins Lenke til kommentar
