problemmer med codes til avi film
hejsa
jeg har et problem med en avi film som jeg har hentet.
den er grøn og næsten umulig at se. jeg har så prøvet at hente den sidste version af nimo codes som jeg kunne finde men uden at det hjælper.
er der nogle af jer der har et forslag til hvordan jeg skal løse problemmet.
jeg bruger media player og divx player 2.0 til at afspille film.
håber at i kan hjælpe mig, på forhånd tak for hjælpen
:o
Har samme problem. Xvid kodeksen som du referete til her hjalp ikke et døyt. De som er grønne er såkalte DVD screenere. Jeg hvet at de fungerer.
Har instalert:
Divx 3.11 Alpha
Divx 5.03
Xvid kodek som referert til over her.
had the same problem with blurred green blocks and stuff. I found that Goldmember wouldn't play but scorpian king would!. I think there may be a conflict in the nimo pack 8 as i also had problems with a band down the right hand side of my videos when i was playing compatable movies as well, so this is what i did:
I uninstalled nimo 8. You will also need to do a search for any files containing divx or xvid on your comp and delete those as well as sometimes they stay in your registry. For any of yous that were puzzled as to why you can still play the divx files after uninstalling this is why!(click start and find files and folders etc.). You may need to restart your comp b4 doing this otherwise you may get sharing violations etc.
I betta say this now: i dont know if this will work for those that make their own movies cos i only watch them .
Next i downloaded and installed nimo 7. I did the BASIC install and added a few things. this is what i had checked in the setup menu:
divx 5.01 codec, microsoft mpeg4, 3ivx 3.5 codec, avi synth 1.05 max, divx audio, fran. mpeg layer 3 codec, vobsub 2.12/ dierctsub vob2.12, ogg vorbis, divx antifreeze, ac3 audiodecoder, morgan stream switcher, divx player (some movies need it), help files.
altså nimo 7 ikke 8 .de kræsjer
