Rutinesjekk av PC-en. Har den noe uggent inne?
Heisann.
Åpnet en slik lenke fra "youtube" slik mange gjør, og jeg frykter at PC-en kan ha blitt infisert. Det er også greit å få noen til å ta en rutinesjekk.
På forhånd takk.
ComboFix-logg
Klikk for å se/fjerne innholdet nedenfor
ComboFix 08-06-05.3 - Mads 2008-06-06 17:55:45.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1044.18.1034 [GMT 2:00]
Running from: F:\Documents and Settings\Mads\Skrivebord\ComboFix.exe
* Created a new restore point
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((( Files Created from 2008-05-06 to 2008-06-06 )))))))))))))))))))))))))))))))
2008-06-06 16:37 . 2008-06-06 16:37 <DIR> d-------- F:\Programfiler\Malwarebytes' Anti-Malware
2008-06-06 16:37 . 2008-06-06 16:37 <DIR> d-------- F:\Documents and Settings\Mads\Programdata\Malwarebytes
2008-06-06 16:37 . 2008-06-06 16:37 <DIR> d-------- F:\Documents and Settings\All Users\Programdata\Malwarebytes
2008-06-06 16:37 . 2008-06-05 16:04 34,296 --a------ F:\WINDOWS\system32\drivers\mbamcatchme.sys
2008-06-06 16:37 . 2008-06-05 16:04 15,864 --a------ F:\WINDOWS\system32\drivers\mbam.sys
2008-06-05 23:49 . 2008-06-05 23:49 <DIR> d-------- F:\Programfiler\Spybot - Search & Destroy
2008-06-05 23:49 . 2008-06-06 00:27 <DIR> d-------- F:\Documents and Settings\All Users\Programdata\Spybot - Search & Destroy
2008-06-05 23:42 . 2008-06-06 17:54 <DIR> dr-h----- F:\Documents and Settings\Mads\Siste
2008-06-05 23:31 . 2008-06-05 23:31 <DIR> d-------- F:\Programfiler\CCleaner
2008-05-28 23:52 . 2008-05-28 23:52 <DIR> d-------- F:\Programfiler\directx
2008-05-27 11:37 . 2008-05-28 23:52 <DIR> d-------- F:\Programfiler\Rockstar Games
2008-05-27 11:37 . 2008-05-27 11:37 <DIR> d-------- F:\Documents and Settings\Mads\WINDOWS
2008-05-27 11:37 . 1997-11-19 14:49 303,616 --a------ F:\WINDOWS\IsUninst.exe
2008-05-26 22:29 . 2008-05-26 22:29 <DIR> d-------- F:\Documents and Settings\All Users\Programdata\TEMP
2008-05-26 22:29 . 2008-05-26 22:29 356,352 --a------ F:\WINDOWS\eSellerateEngine.dll
2008-05-26 22:29 . 2004-12-07 10:11 258,352 --a------ F:\WINDOWS\system32\Unicows.dll
2008-05-26 21:32 . 2008-05-26 22:21 <DIR> d-------- F:\Programfiler\Avidemux 2.4
2008-05-26 21:32 . 2008-05-26 22:23 <DIR> d-------- F:\Documents and Settings\Mads\Programdata\gtk-2.0
2008-05-26 21:32 . 2008-05-26 21:32 <DIR> d-------- F:\Documents and Settings\Mads\avidemux
2008-05-26 21:03 . 2008-02-28 13:26 1,414,440 --a------ F:\WINDOWS\system32\ShellManager310E2D762.dll
2008-05-26 21:03 . 2008-02-28 13:01 774,144 --a------ F:\WINDOWS\system32\NEROINSTAEC43759.DB
2008-05-26 21:02 . 2008-05-26 21:02 0 --a------ F:\WINDOWS\Irremote.ini
2008-05-26 18:42 . 2008-05-26 22:23 69 --a------ F:\WINDOWS\NeroDigital.ini
2008-05-26 18:15 . 2008-05-26 18:15 <DIR> d-------- F:\Programfiler\NeroInstall.bak
2008-05-26 17:58 . 2008-05-26 17:58 <DIR> d-------- F:\Documents and Settings\Mads\Programdata\Nero
2008-05-26 17:53 . 2008-05-26 17:53 <DIR> d-------- F:\Programfiler\Nero
2008-05-26 17:53 . 2008-05-26 22:00 <DIR> d-------- F:\Programfiler\Fellesfiler\Nero
2008-05-26 17:53 . 2008-05-26 21:58 <DIR> d-------- F:\Documents and Settings\All Users\Programdata\Nero
2008-05-21 21:23 . 2004-08-04 01:03 159,232 --a------ F:\WINDOWS\system32\ptpusd.dll
2008-05-21 21:23 . 2001-10-06 14:02 5,632 --a------ F:\WINDOWS\system32\ptpusb.dll
2008-05-12 01:50 . 2008-05-12 01:50 <DIR> d-------- F:\Programfiler\AndreaMosaic
2008-05-12 01:50 . 2008-05-12 01:50 737,280 --a------ F:\WINDOWS\iun6002.exe
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-06-06 11:41 --------- d-----w F:\Documents and Settings\Mads\Programdata\OpenOffice.org2
2008-06-02 19:17 --------- d-----w F:\Documents and Settings\Mads\Programdata\dvdcss
2008-06-02 15:15 --------- d-----w F:\Programfiler\Yahoo!
2008-05-28 21:52 --------- d--h--w F:\Programfiler\InstallShield Installation Information
2008-05-28 15:56 --------- d-----w F:\Documents and Settings\Mads\Programdata\Apple Computer
2008-05-26 20:32 --------- d-----w F:\Programfiler\ABC Amber SVG Converter
2008-04-29 20:30 --------- d-----w F:\Programfiler\Fellesfiler\Adobe
2008-04-20 10:37 --------- d-----w F:\Programfiler\DVD Shrink
2008-04-20 10:37 --------- d-----w F:\Documents and Settings\All Users\Programdata\DVD Shrink
2008-04-16 22:17 --------- d-----w F:\Programfiler\Celtx
2008-04-06 20:13 --------- d-----w F:\Programfiler\Opera
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="F:\WINDOWS\system32\ctfmon.exe" [2004-08-04 01:03 15360]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"OfficeScanNT Monitor"="F:\Programfiler\Trend Micro\OfficeScan Client\pccntmon.exe" [2007-09-06 21:45 710000]
"StartCCC"="F:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2006-11-10 13:35 90112]
"RTHDCPL"="RTHDCPL.EXE" [2006-10-30 20:49 16269312 F:\WINDOWS\RTHDCPL.exe]
"SkyTel"="SkyTel.EXE" [2006-05-16 19:04 2879488 F:\WINDOWS\SkyTel.exe]
"SunJavaUpdateSched"="F:\Programfiler\Java\jre1.6.0_05\bin\jusched.exe" [2008-02-22 05:25 144784]
"Acrobat Assistant 8.0"="F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe" [2007-05-10 23:46 624248]
"Adobe_ID0EYTHM"="F:\PROGRA~1\FELLES~1\Adobe\ADOBEV~1\Server\bin\VERSIO~2.EXE" [2007-03-20 17:40 1884160]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="F:\WINDOWS\system32\CTFMON.EXE" [2004-08-04 01:03 15360]
F:\Documents and Settings\All Users\Start-meny\Programmer\Oppstart\
Adobe Reader Speed Launch.lnk - F:\Programfiler\Adobe\Reader 8.0\Reader\reader_sl.exe [2006-10-23 02:48:20 40048]
Clean Access Agent.lnk - F:\Programfiler\Cisco Systems\Clean Access Agent\CCAAgent.exe [2007-04-26 13:35:24 2048074]
[HKLM\~\startupfolder\F:^Documents and Settings^All Users^Start-meny^Programmer^Oppstart^iFinger 2.1.lnk]
path=F:\Documents and Settings\All Users\Start-meny\Programmer\Oppstart\iFinger 2.1.lnk
backup=F:\WINDOWS\pss\iFinger 2.1.lnkCommon Startup
[HKLM\~\startupfolder\F:^Documents and Settings^Mads^Start-meny^Programmer^Oppstart^OpenOffice.org 2.3.lnk]
path=F:\Documents and Settings\Mads\Start-meny\Programmer\Oppstart\OpenOffice.org 2.3.lnk
backup=F:\WINDOWS\pss\OpenOffice.org 2.3.lnkStartup
[HKLM\~\startupfolder\F:^Documents and Settings^Mads^Start-meny^Programmer^Oppstart^Yahoo! Widgets.lnk]
path=F:\Documents and Settings\Mads\Start-meny\Programmer\Oppstart\Yahoo! Widgets.lnk
backup=F:\WINDOWS\pss\Yahoo! Widgets.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IndxStoreSvr_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}]
--a------ 2008-02-28 17:07 1828136 F:\Programfiler\Fellesfiler\Nero\Lib\NMIndexStoreSvr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
--a------ 2007-12-11 13:10 267048 F:\Programfiler\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NBKeyScan]
--a------ 2008-02-18 16:29 2221352 F:\Programfiler\Nero\Nero8\Nero BackItUp\NBKeyScan.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
--a------ 2008-02-28 09:59 570664 F:\Programfiler\Fellesfiler\Nero\Lib\NeroCheck.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\OpwareSE2]
--a------ 2003-05-08 13:00 49152 F:\Programfiler\ScanSoft\OmniPageSE2.0\OpwareSE2.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Power_Gear]
F:\Programfiler\ASUS\Power4 Gear\BatteryLife.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
--a------ 2007-12-11 11:56 286720 F:\Programfiler\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\security center]
"AntiVirusDisableNotify"=dword:00000001
"UpdatesDisableNotify"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\TrendAntiVirus]
"DisableMonitoring"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\TrendFirewall]
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"F:\\Programfiler\\iTunes\\iTunes.exe"=
"F:\\Programfiler\\Bonjour\\mDNSResponder.exe"=
"F:\\Programfiler\\Fellesfiler\\Adobe\\Adobe Version Cue CS3\\Server\\bin\\VersionCueCS3.exe"=
"F:\\Programfiler\\Windows Live\\Messenger\\msnmsgr.exe"=
"F:\\Programfiler\\Windows Live\\Messenger\\livecall.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"12345:TCP"= 12345:TCP:Trend Micro OfficeScan Listener
"3703:TCP"= 3703:TCP:Adobe Version Cue CS3 Server
"3704:TCP"= 3704:TCP:Adobe Version Cue CS3 Server
"50900:TCP"= 50900:TCP:Adobe Version Cue CS3 Server
"50901:TCP"= 50901:TCP:Adobe Version Cue CS3 Server
R2 TabletServicePen;TabletServicePen;F:\WINDOWS\system32\Pen_Tablet.exe [2007-09-07 12:16]
R3 wacommousefilter;Wacom Mouse Filter Driver;F:\WINDOWS\system32\DRIVERS\wacommousefilter.sys [2007-02-16 12:12]
R3 wacomvhid;Wacom Virtual Hid Driver;F:\WINDOWS\system32\DRIVERS\wacomvhid.sys [2007-02-16 11:30]
R3 WacomVKHid;Virtual Keyboard Driver;F:\WINDOWS\system32\DRIVERS\WacomVKHid.sys [2007-02-15 17:11]
*Newly Created Service* - CATCHME
Contents of the 'Scheduled Tasks' folder
"2008-05-23 08:10:03 F:\WINDOWS\Tasks\Oppdater Ordnett Pluss.job"
- F:\Programfiler\Kunnskapsforlaget\Ordnett Pluss\updater.exe
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-06-06 17:59:15
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
Completion time: 2008-06-06 18:00:40
ComboFix-quarantined-files.txt 2008-06-06 16:00:11
Pre-Run: 11,557,093,376 byte ledig
Post-Run: 12,378,001,408 byte ledig
145
Hijackthis-logg:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 18:02:39, on 06.06.2008
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
F:\WINDOWS\System32\smss.exe
F:\WINDOWS\system32\winlogon.exe
F:\WINDOWS\system32\services.exe
F:\WINDOWS\system32\lsass.exe
F:\WINDOWS\system32\Ati2evxx.exe
F:\WINDOWS\system32\svchost.exe
F:\WINDOWS\System32\svchost.exe
F:\WINDOWS\system32\spoolsv.exe
F:\WINDOWS\RTHDCPL.EXE
F:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
F:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
F:\Programfiler\Fellesfiler\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
F:\Programfiler\Bonjour\mDNSResponder.exe
F:\Programfiler\Nero\Nero8\Nero BackItUp\NBService.exe
F:\WINDOWS\system32\IoctlSvc.exe
F:\Programfiler\Fellesfiler\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
F:\Programfiler\Windows Live\Messenger\usnsvc.exe
F:\Programfiler\Opera\Opera.exe
F:\Programfiler\Trend Micro\OfficeScan Client\PccNTMon.exe
F:\Programfiler\Trend Micro\OfficeScan Client\tmlisten.exe
F:\Programfiler\Trend Micro\OfficeScan Client\TmPfw.exe
F:\Programfiler\Trend Micro\OfficeScan Client\ntrtscan.exe
F:\Programfiler\Trend Micro\OfficeScan Client\TmProxy.exe
F:\Programfiler\Trend Micro\OfficeScan Client\CNTAoSMgr.exe
F:\WINDOWS\explorer.exe
F:\WINDOWS\system32\notepad.exe
F:\Programfiler\Trend Micro\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - F:\Programfiler\Fellesfiler\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: ContributeBHO Class - {074C1DC5-9320-4A9A-947D-C042949C6216} - F:\Programfiler\Adobe\/Adobe Contribute CS3/contributeieplugin.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - F:\Programfiler\Java\jre1.6.0_05\bin\ssv.dll
O2 - BHO: iFinger plugin / Browser helper object - {A114D52B-870C-4F15-8021-B6D7F91A054B} - F:\Programfiler\iFinger\plugins\IE.ifp
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Contribute Toolbar - {517BDDE4-E3A7-4570-B21E-2B52B6139FC7} - F:\Programfiler\Adobe\/Adobe Contribute CS3/contributeieplugin.dll
O4 - HKLM\..\Run: [OfficeScanNT Monitor] "F:\Programfiler\Trend Micro\OfficeScan Client\pccntmon.exe" -HideWindow
O4 - HKLM\..\Run: [startCCC] F:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [skyTel] SkyTel.EXE
O4 - HKLM\..\Run: [sunJavaUpdateSched] "F:\Programfiler\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [Adobe_ID0EYTHM] F:\PROGRA~1\FELLES~1\Adobe\ADOBEV~1\Server\bin\VERSIO~2.EXE
O4 - HKCU\..\Run: [CTFMON.EXE] F:\WINDOWS\system32\ctfmon.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] F:\WINDOWS\system32\CTFMON.EXE (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] F:\WINDOWS\system32\CTFMON.EXE (User 'NETTVERKSTJENESTE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] F:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] F:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Global Startup: Adobe Reader Speed Launch.lnk = F:\Programfiler\Adobe\Reader 8.0\Reader\reader_sl.exe
O4 - Global Startup: Clean Access Agent.lnk = F:\Programfiler\Cisco Systems\Clean Access Agent\CCAAgent.exe
O8 - Extra context menu item: Append to existing PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://F:\Programfiler\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - F:\Programfiler\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - F:\Programfiler\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: iFinger - {936E5D60-596C-11D3-BB96-00600816DF55} - F:\WINDOWS\system32\SHDOCVW.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - F:\Programfiler\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - F:\Programfiler\Messenger\msmsgs.exe
O23 - Service: Adobe Version Cue CS3 - Adobe Systems Incorporated - F:\Programfiler\Fellesfiler\Adobe\Adobe Version Cue CS3\Server\bin\VersionCueCS3.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - F:\Programfiler\Fellesfiler\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - F:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762## (Bonjour Service) - Apple Computer, Inc. - F:\Programfiler\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - F:\Programfiler\Fellesfiler\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: iPod-tjeneste (iPod Service) - Apple Inc. - F:\Programfiler\iPod\bin\iPodService.exe
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - F:\Programfiler\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - F:\Programfiler\Fellesfiler\Nero\Lib\NMIndexingService.exe
O23 - Service: OfficeScanNT RealTime Scan (ntrtscan) - Trend Micro Inc. - F:\Programfiler\Trend Micro\OfficeScan Client\ntrtscan.exe
O23 - Service: PLFlash DeviceIoControl Service - Prolific Technology Inc. - F:\WINDOWS\system32\IoctlSvc.exe
O23 - Service: TabletServicePen - Wacom Technology, Corp. - F:\WINDOWS\system32\Pen_Tablet.exe
O23 - Service: OfficeScan NT Listener (tmlisten) - Trend Micro Inc. - F:\Programfiler\Trend Micro\OfficeScan Client\tmlisten.exe
O23 - Service: OfficeScan NT Firewall (TmPfw) - Trend Micro Inc. - F:\Programfiler\Trend Micro\OfficeScan Client\TmPfw.exe
O23 - Service: OfficeScan NT Proxy Service (TmProxy) - Trend Micro Inc. - F:\Programfiler\Trend Micro\OfficeScan Client\TmProxy.exe
End of file - 8092 bytes
Malwarebytes' Anti-Malware-logg:
Malwarebytes' Anti-Malware 1.15
Database versjon: 834
17:54:36 06.06.2008
mbam-log-6-6-2008 (17-54-36).txt
Skann type: Full Skann (C:\|F:\|)
Objekter skannet: 183591
Tid tilbakelagt: 1 hour(s), 16 minute(s), 33 second(s)
Minneprosesser infisert: 0
Minnemoduler infisert: 0
Registernøkler infisert: 0
Registerverdier infisert: 0
Registerfiler infisert: 0
Mapper infisert: 0
Filer infisert: 0
(Ingen mistenkelige filer funnet)
Mapper infisert:
Filer infisert:
Maskina ser nokså frisk ut, og oppfører seg slik også, men bedre å være helt sikker. Bruker Trend Micro Officescan.
