Problemer med PartitionMagic
Lastet ned en versjon av POWERQUEST PartitionMagic 8.0 og NORTON PartitionMagic 8.0. Begge ser ut til å gi meg samme problemet:
Feilmelding 1:
Error
Init failed: error 117
Partition's drive letter cannot be identified
Feilmelding 2:
Disk Information
Disk error(s) were detected on this drive. See the 'Errors:' list for more details.
Feilmelding 3:
Disk Information
Disk Geometry error(s) were detected on this drive.
Når jeg så går inn på partitioninfo fra programmenyen finner jeg følgende:
-> Partitioninfo
Disk & partition errors:
Error #105: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 214.
Error #106: Partition didn't begin on head boundary.
ucBeginSector expected to be 1, not 39.
Error #108: Partition didn't end on cylinder boundary.
ucEndHead expected to be 239, not 92.
ucEndSector expected to be 63, not 44.
->Preview
Symantec PartitionInfo 8.0 -- Windows NT/2000 Version
Date Generated: 06/03/08 20:41:36
Copyright ©1994-2004, Symantec Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way. All other rights are reserved.
Symantec, makers of Norton PartitionMagic®, Drive Image, and DriveCopy, can be reached at:
Voice: 801-437-8900
Fax: 801-226-8941
Web site: http://www.symantec.com/techsupp/
General System Information:
Total Physical Memory (bytes): 2,128,842,752
Used Physical Memory: (bytes): 552,361,984
Maximum Page File Size: (bytes): 4,113,166,336
Current Page File Size: (bytes): 443,658,240
Disk Geometry Information for Disk 1: 25841 Cylinders, 240 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 00 0 32 33 27 931 214 38 2,048 14,088,192
Info: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 32.
ucBeginSector expected to be 1, not 33.
Info: Partition didn't end on cylinder boundary.
ucEndHead expected to be 239, not 214.
ucEndSector expected to be 63, not 38.
0 1 80 931 214 39 07 1023 92 44 14,090,240 61,440,000
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 1 80 931 214 39 07 4995 92 44 14090240 61440000
0 2 00 1023 0 1 0F 1023 239 63 75,539,520 315,176,400
Info: Begin C,H,S values were large drive placeholders.
Actual values are:
0 2 00 4996 0 1 0F 25840 239 63 75539520 315176400
75,539,520 0 00 1023 1 1 07 1023 239 63 75,539,583 20,487,537
Actual values are:
75539520 0 00 4996 1 1 07 6350 239 63 75539583 20487537
75,539,520 1 00 1023 0 1 05 1023 239 63 96,027,120 294,688,800
Actual values are:
75539520 1 00 6351 0 1 05 25840 239 63 96027120 294688800
96,027,120 0 00 1023 1 1 07 1023 239 63 96,027,183 294,688,737
Actual values are:
96027120 0 00 6351 1 1 07 25840 239 63 96027183 294688737
Partition Information for Disk 1: 190,779.3 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects
Type 27 Pri 6,879.0 0 0 2,048 14,088,192
C: NTFS Pri,Boot 30,000.0 0 1 14,090,240 61,440,000
ExtendedX Pri 153,894.7 0 2 75,539,520 315,176,400
EPBR Log 10,003.7 None -- 75,539,520 20,487,600
D: NTFS Log 10,003.7 75,539,520 0 75,539,583 20,487,537
EPBR Log 143,891.0 75,539,520 1 96,027,120 294,688,800
E: NTFS Log 143,891.0 96,027,120 0 96,027,183 294,688,737
Boot Record for drive C: (Drive: 1, Starting sector: 14,090,240, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
3. Bytes per Sector: 512
4. Sectors per Cluster: 8
5. Reserved Sectors: 0
6. Number of FATs: 0
7. Root Dir Entries: 0
8. Total Sectors: 0
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 240 (0xF0)
13. Hidden Sectors: 14090240 (0xD70000)
14. Total Sectors (>32MB): 0 (0x0)
15. Unused: 0x80008000
16. Total NTFS Sectors: 61439999
17. MFT Start Cluster: 786432
18. MFT Mirror Start Clust: 3839999
19. Clusters per FRS: 246
20. Clusters per Index Blk: 1
21. Serial Number: 0xE2E80DE7E80DBAB5
22. Checksum: 0 (0x0)
23. Boot Signature: 0xAA55
Boot Record for drive D: (Drive: 1, Starting sector: 75,539,583, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
8. Total Sectors: 0
13. Hidden Sectors: 63 (0x3F)
16. Total NTFS Sectors: 20487536
18. MFT Mirror Start Clust: 1280471
21. Serial Number: 0xBE047EAE047E68F3
Boot Record for drive E: (Drive: 1, Starting sector: 96,027,183, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
8. Total Sectors: 0
16. Total NTFS Sectors: 294688736
18. MFT Mirror Start Clust: 18418046
21. Serial Number: 0xE0A808C2A80898E4
Det var det. Det står noe om at programmet ikke kan brukes på en dynamisk disk, jeg vet ikke om det kan ha noe med det og gjøre?? Noen som vet hva som kan være problemet??
