Hvordan installere x-fi-beta-drivere?
Hei. Er ny på linux og har problemer med å få x-fi-kortet mitt til å virke i ubuntu. Har lastet ned creatives nyeste beta-driver, men vet ikke helt hvordan jeg skal få installert filene jeg laster ned.
Fra readme-filen:
Quick install
1) You must have the fully configured source for the Linux kernel and
ALSA which you
want to use for this device driver. Partial installed
kernels (e.g. From distribution makers) may be unusable for this
action.
2) Run one of the following commands as root in the terminal:
./installer
OR
./installer --with-alsainc=<ALSA_include_directory>
* ALSA Source Tree
On 2.6 kernels, the location of the ALSA source include directory
is parsed automatically from the running kernel.
If it is not in the standard place, specify the path via
--with-alsainc=<ALSA_include_directory>.
On 2.4 kernels, the location of the ALSA source include directory
must be specified via --with-alsainc=<ALSA_include_directory>.
* Note
If integrated ALSA is to be used to build, --with-alsainc option
must not be specified.
Er en fil som heter "installer" i pakken, men jeg greier ikke å få kjørt den.
Stor takk til all hjelp.
