Jeg lurer på en ting...
Jeg har en dell maskin som hadde et GF3 kort. I går fikk jeg mitt nye GF4 TI4600 kort, men jeg må si jeg ble veldig skuffa... ytelsen ble ikke noe bedre, så noe må være galt! Så satt jeg å tenkte litt i dag og lurer på:
Oppdateres instillingene i BIOS automatisk? Eller kjører mitt GF4 kort på samme klokke frekvens som det gamle GF3 kortet mitt gjorde? Grunnen til at jeg spør er at grafikken er finere, men FPS'en i spillene mine er den samme... :roll:
CPU Properties
CPU Type Intel Pentium 4, 1600 MHz (4 x 400)
CPU Alias P68, Willamette, A80528
Original Clock 1600 MHz
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 42 million
Process Technology 6M, 0.18 um, CMOS
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
Typical Power 55.3 - 75.3 W (depending on clock speed)
Maximum Power 72 - 100 W (depending on clock speed)
CPUID Properties
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel® Pentium® 4 CPU 1.60GHz
CPUID Revision 0F12h
IA Brand ID 08h (Intel Pentium 4)
Platform ID 0Ch (Socket 478)
IA CPU Serial Number Unknown
MSR 00000017 0008-0000-0000-0000
MSR 0000002A 0000-0000-0000-4000
MSR 0000002C 0000-0000-8201-FF00
Instruction Set
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD x86-64 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
Conditional Move Instruction Supported
CPUID Features
36-bit Page Size Extension Supported
Automatic Clock Control Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Fast System Call Supported
Hyper-Threading Technology Not Supported
Local APIC On Chip Supported
LongRun Not Supported
LongRun Table Interface Not Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
Page Attribute Table Supported
Page Global Extension Supported
Physical Address Extension Supported
Processor Duty Cycle Control Supported
Processor Serial Number Not Supported
Self-Snoop Supported
Time Stamp Counter Supported
Virtual Mode Extension Supported
Motherboard Properties
Motherboard ID <DMI>
Motherboard Name Dell Computer Corporation Dimension 4300
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz
Effective Clock 133 MHz
Bandwidth 1067 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Memory Module Properties (Har to slike brikker)
Module Name Kingston 32MX64PC133CL3168
Serial Number 37032202
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Highest CAS Latency 3.0 (7.5 ns @ 133 MHz)
2nd Highest CAS Latency 2.0 (10.0 ns @ 100 MHz)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Supported
Precharge All Supported
Write1/Read Burst Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Chipset Properties
Motherboard Chipset Intel Brookdale i845
CAS Latency 3T
RAS To CAS Delay 3T
RAS Precharge 3T
Memory Slots
DRAM Slot #1 256 MB (SDRAM)
DRAM Slot #2 256 MB (SDRAM)
AGP Properties
AGP Version 2.00
AGP Status Enabled
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Supported, Enabled
Side Band Addressing Supported, Enabled
det er sdramen om trekker ned, beklager men slik er det. Hvis du hadde hatt ddr-dimm eller rambus (rd-ram) så hadde saken vært en annen.
Et forslag er å kjøpe nytt hk og minne (ca 2000 (kommer ann på hva du skal ha kan bli mye billigere)) så blir det bedre men da mister du garanti
Ellers har jeg ikke peiling på intel systemer
Etter å ha lest den andre tråden så er det vel bare å si kjøp ny pc koble i nettverk dra med en kompis og spill et eller annet, unreal tournament eller noe mot hverandre :wink:
