sliter med mounting av disker
slik ser min /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
UUID=a99ab6b8-8395-4e0b-a258-b6e100632cfd / ext3 relatime,errors=remount-ro 0 1
# /dev/sda5
UUID=40e28b1a-9eb9-480a-b7cb-413b7021919a none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
/dev/sda1 /media/windows ntfs-3g defaults 0 0
/dev/sda5 /media/spill ntfs-3g defaults 0 0
/dev/sda6 /media/div ntfs-3g defaults 0 0
/dev/sdb1 /media/500film ntfs-3g defaults 0 0
/dev/sdc1 /media/500serier ntfs-3g defaults 0 0
/dev/sdd1 /media/500HD ntfs-3g defaults 0 0
det går fint å mounte de, men problemet er at diskene skifter "navn" for hver boot. linux disken min skifter fra sda1 til sde1. Da blir det ey problem når linux disken er sda1 for da vil bare mouting bli krøll
noen som har noen forslag for å få låst navnene ?
Derfor du skal bruke UUID.
http://wiki.archlinux.org/index.php/Beginn...#.2Fetc.2Ffstab
due to active developments in the kernel and also udev, which may randomly change the ordering in which drivers for storage controllers are loaded, yielding an unbootable system/kernel panic. Nearly every motherboard has several controllers (onboard SATA, onboard IDE), and due to the aforementioned development updates, /dev/sda may become /dev/sdb on the next reboot- hence the persistent device naming convention of UUID has been adopted for reliability.
ls -lF /dev/disk/by-uuid/
