Xecuter Skrevet 26. mai 2008 Del Skrevet 26. mai 2008 Driver og installere Arch, å fikk jo valg om å sette opp GRUB på nytt, skuffende at jeg ikke fikk valg om å konfigurere en allerede-eksisterende GRUB. Uansett, GRUB-en som jeg har sitter på /dev/sda1, mens Arch er installert på /dev/sdc2. Hvordan setter jeg opp GRUB da? Fungerende GRUB: # menu.lst - See: grub(8), info grub, update-grub(8) # grub-install(8), grub-floppy(8), # grub-md5-crypt, /usr/share/doc/grub # and /usr/share/doc/grub-doc/. ## default num # Set the default entry to the entry number NUM. Numbering starts from 0, and # the entry number 0 is the default if the command is not used. # # You can specify 'saved' instead of a number. In this case, the default entry # is the entry saved with the command 'savedefault'. # WARNING: If you are using dmraid do not use 'savedefault' or your # array will desync and will not let you boot your system. default 0 ## timeout sec # Set a timeout, in SEC seconds, before automatically booting the default entry # (normally the first entry defined). timeout 3 ## hiddenmenu # Hides the menu by default (press ESC to see the menu) hiddenmenu # Pretty colours #color cyan/blue white/blue ## password ['--md5'] passwd # If used in the first section of a menu file, disable all interactive editing # control (menu entry editor and command-line) and entries protected by the # command 'lock' # e.g. password topsecret # password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/ # password topsecret # # examples # # title Windows 95/98/NT/2000 # root (hd0,0) # makeactive # chainloader +1 # # title Linux # root (hd0,1) # kernel /vmlinuz root=/dev/hda2 ro # # # Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST ### BEGIN AUTOMAGIC KERNELS LIST ## lines between the AUTOMAGIC KERNELS LIST markers will be modified ## by the debian update-grub script except for the default options below ## DO NOT UNCOMMENT THEM, Just edit them to your needs ## ## Start Default Options ## ## default kernel options ## default kernel options for automagic boot options ## If you want special options for specific kernels use kopt_x_y_z ## where x.y.z is kernel version. Minor versions can be omitted. ## e.g. kopt=root=/dev/hda1 ro ## kopt_2_6_8=root=/dev/hdc1 ro ## kopt_2_6_8_2_686=root=/dev/hdc2 ro # kopt=root=UUID=2fd4877f-321a-4f1c-a9ec-71abb4c03cbe ro ## Setup crashdump menu entries ## e.g. crashdump=1 # crashdump=0 ## default grub root device ## e.g. groot=(hd0,0) # groot=(hd0,0) ## should update-grub create alternative automagic boot options ## e.g. alternative=true ## alternative=false # alternative=true ## should update-grub lock alternative automagic boot options ## e.g. lockalternative=true ## lockalternative=false # lockalternative=false ## additional options to use with the default boot option, but not with the ## alternatives ## e.g. defoptions=vga=791 resume=/dev/hda5 # defoptions=quiet splash ## should update-grub lock old automagic boot options ## e.g. lockold=false ## lockold=true # lockold=false ## Xen hypervisor options to use with the default Xen boot option # xenhopt= ## Xen Linux kernel options to use with the default Xen boot option # xenkopt=console=tty0 ## altoption boot targets option ## multiple altoptions lines are allowed ## e.g. altoptions=(extra menu suffix) extra boot options ## altoptions=(recovery) single # altoptions=(recovery mode) single ## controls how many kernels should be put into the menu.lst ## only counts the first occurence of a kernel, not the ## alternative kernel options ## e.g. howmany=all ## howmany=7 # howmany=all ## should update-grub create memtest86 boot option ## e.g. memtest86=true ## memtest86=false # memtest86=true ## should update-grub adjust the value of the default booted system ## can be true or false # updatedefaultentry=false ## should update-grub add savedefault to the default options ## can be true or false # savedefault=false ## ## End Default Options ## title Ubuntu 8.04, kernel 2.6.24-17-rt root (hd0,0) kernel /boot/vmlinuz-2.6.24-17-rt root=UUID=2fd4877f-321a-4f1c-a9ec-71abb4c03cbe ro quiet splash initrd /boot/initrd.img-2.6.24-17-rt quiet title Ubuntu 8.04, kernel 2.6.24-17-rt (recovery mode) root (hd0,0) kernel /boot/vmlinuz-2.6.24-17-rt root=UUID=2fd4877f-321a-4f1c-a9ec-71abb4c03cbe ro single initrd /boot/initrd.img-2.6.24-17-rt title Ubuntu 8.04, memtest86+ root (hd0,0) kernel /boot/memtest86+.bin quiet ### END DEBIAN AUTOMAGIC KERNELS LIST Archs GRUB: # Config file for GRUB - The GNU GRand Unified Bootloader # /boot/grub/menu.lst # DEVICE NAME CONVERSIONS # # Linux Grub # ------------------------- # /dev/fd0 (fd0) # /dev/hda (hd0) # /dev/hdb2 (hd1,1) # /dev/hda3 (hd0,2) # # FRAMEBUFFER RESOLUTION SETTINGS # +-------------------------------------------------+ # | 640x480 800x600 1024x768 1280x1024 # ----+-------------------------------------------- # 256 | 0x301=769 0x303=771 0x305=773 0x307=775 # 32K | 0x310=784 0x313=787 0x316=790 0x319=793 # 64K | 0x311=785 0x314=788 0x317=791 0x31A=794 # 16M | 0x312=786 0x315=789 0x318=792 0x31B=795 # +-------------------------------------------------+ # general configuration: timeout 5 default 0 color light-blue/black light-cyan/blue # boot sections follow # each is implicitly numbered from 0 in the order of appearance below # # TIP: If you want a 1024x768 framebuffer, add "vga=773" to your kernel line. # #-* # (0) Arch Linux title Arch Linux [/boot/vmlinuz26] root (hd0,0) kernel /vmlinuz26 root=/dev/hda3 ro initrd /kernel26.img # (1) Windows #title Windows #rootnoverify (hd0,0) #makeactive #chainloader +1 Lenke til kommentar
rocknrolf77 Skrevet 26. mai 2008 Del Skrevet 26. mai 2008 Skulle da tro at det skulle bli # (0) Arch Linuxtitle Arch Linux [/boot/vmlinuz26] root (hd2,1) kernel /vmlinuz26 root=/dev/hda3 ro initrd /kernel26.img Så kan du jo legge til color light-blue/black light-cyan/blue For some pretty colors Legg bare dette til din eksisterende grub. Bare ikke skyt meg hvis det ikke er riktig Du har ikke installert ny grub enda? Lenke til kommentar
