Cisco 877w og ADSL fra telenor
Har store problemer med å komme på nett med min Cisco 877w.
Det som ligger inne nå på den er factory defaults og ADSL wizardens config.
Det blinker i CD lampa i forskjellige hastigheter og jeg får ikke IP-adresse.
Internettleverandøren er Monet på Telenors utstyr.
Current configuration : 3856 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-3217255836
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3217255836
revocation-check none
rsakeypair TP-self-signed-3217255836
crypto pki certificate chain TP-self-signed-3217255836
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33323137 32353538 3336301E 170D3038 30353230 32323430
31355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32313732
35353833 3630819F 300D0609 2A864886 F70D4101 01050003 818D0030 81890281
8100A950 FD0C12F8 8849E3C7 81D05B5E 362FDDE1 A24E023F E5CCC923 9EA04915
766CCE13 D22CAAAF 74E04B18 00C535DA C8943040 8CBC377C B50B9F47 3D212298
B9F6870A 151BF71B 9E09CAFF 51285CBE A5804CC8 7CD5553F 2ECD05CE 7576C33B
0C08E42F 97442569 C0DA91A5 EF3EA10A 5891A1E3 9996DD4F 24BF49D0 51028148
0AC50203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 1414359D 49C94019 652B315E 0B714DF9 245F016D
4C301D06 03551D0E 04160414 14359D49 C9401965 2B315E0B 714DF924 5F016D4C
300D0609 2A864886 F70D0101 04050003 8181007A F924AD44 346F6755 71AA788F
F34ABF39 C96DD9FF E0143A2F 7927B7DC 348552FA 27F5AA78 E32A5152 9548C51C
CB5F0A30 F293AB36 A77EA57F 527A585B 93919A4E E7B32CF7 16DF7B2F 6D9AE43E
178CF092 1D2635F2 202D28BA A9861999 6277EE61 3E94B811 59394BA0 C36F3339
7B62EDF6 60316DEB DD2268EB FC014FB6 DFC8D9
quit
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
ip domain name yourdomain.com
username brukernavn privilege 15 secret 5 $1$1GrC$I6ckdESkUheS29kyyaMc0.
archive
log config
hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address dhcp
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password 7 820946F35687EA
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Interface IP-Address OK? Method Status Protocol
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up up
Dot11Radio0 unassigned YES NVRAM administratively down down
ATM0 unassigned YES NVRAM down down
ATM0.1 unassigned YES unset down down
Vlan1 10.10.10.1 YES NVRAM up up
Dialer0 unassigned YES DHCP up up
NVI0 unassigned NO unset up up
Dialer0 is up (spoofing), line protocol is up (spoofing)
Hardware is Unknown
Internet address will be negotiated using DHCP
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:02:38
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes
0 packets output, 0 bytes
ATM0 is down, line protocol is down
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 4608 Kbit, DLY 80 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 1024 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last clearing of "show interface" counters never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 output buffer failures, 0 output buffers swapped out
ATM0.1 is down, line protocol is down
MTU 4470 bytes, BW 4608 Kbit, DLY 80 usec,
Encapsulation ATM
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
Bruker du PPPoE eller PPPoA?
Ut i fra konfigen setter du opp PPPoE over ATM.
Du må begynne å feilsøke på lag 1,det vil si kabel,modem og dslam fordi linken er helt nede.
Du bruker interface ATM 0.1 og hvis du ikke vet hvilken type dslam Telenor bruker kan du sette kommandoen dsl operating-mode auto for da finner ruteren automatisk ut hvilken dslam merke du bruker.Den står som auto på ATM0 men du har konfigen din på ATM0.1 så sett den til auto der.Mener ATM 0.1 er et subinterface og at du må flytte konfigen til ATM 0
Videre må du sette pvc 8/35 til Telenor sin verdi.Noen på forumet som har telenor vet kanskje verdien?
Dette kan testes først.
Ut i fra konfiguen din mangler du også en statisk default rute,den må være:
ip route 0.0.0.0 0.0.0.0 interface dialer 0
Du må også sette ip adresse dhcp til ip adresse negotiated på interface dialer 0
MTU på dialer 0 kan stå til 1492 mens IP TCP MSS-ADJUST kan stå til 1452 på VLAN1 med PPPoE, men det fungerer sikkert med de innstillingene.
Endret av Knopfix
Endelig et fornuftig svar :p
VPI/VNC verdiene er bekreftet av internettleverandøren (og er også verdien jeg har på modemet mitt som virker).
Har også fått beskjed om å bruke DHCP men negotiated virker like bra..eller dårlig (problemet ligger sannsynligvis noen lag ned som du sier :))
Får ikke satt dsl operating-mode på subinterfacet, kun på ATM 0 så jeg regner med ATM 0.1 bruker verdiene derfra?
Default rute satte ikke wizarden opp når jeg hadde dhcp-tildelt ip på wan :)
Gjorde om til negotiated (Easy IP) i SDM og da satte den opp automatisk.
Ser at du bruker PAP og ikke CHAP på dialer 0.
Det er nok CHAP du skal bruke fordi PAP er gammelt og blir sent i klartekst men CHAP er kryptert.
Slik ditt passord og brukernavn blir sendt til Telenor.
Endret av Knopfix
Eksemler jeg har sett bruker ikke subinterface på ATM interfacet.
Så om du få flyttet det så prøv det.
Da har jeg flyttet verdiene fra subinterfacet.
Ser i grove trekk slik ut nå:
interface ATM0
no ip address
pvc 8/35
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username [email protected] password 0 passord
ip route 0.0.0.0 0.0.0.0 Dialer0
Har enablet chap i tillegg.
Ingen bedring dessverre :(
Edit: Har configen til modemet fra ISPen min her hvis det kan være noe der av interesse?
user.txt
Endret av shakudu
Har denne ruteren innebygd modem?
Og du er sikker på at det er PPPoE du skal sette opp ikke PPPoA.
Du kan teste med Fastethernet interfacet i stedet for ATM 0 også.
Interface Fastethernet 0
no ip address
PPPoE enable
Endret av Knopfix
Routeren har innebyggd ADSL-modem.
Er ganske sikker på at det er PPPoE, sjekk modemkonfigen fra ISPens modem i post #10.
Endret av shakudu
Tror ikke det er lurt og nedgradere.
Hva slags status har du på interfacet?Down\Up ,testet med FE0 i stedet?
Står det down down så indikerer den første "down" et fysisk problem med linjen.
Sjekk at interfacene også er slått på.
Interfacet er slått på, står som down/down.
FE0 er jo en ethernet port, kan jeg koble ADSLen rett i den?
Endret av shakudu
Ja du kan kjøre PPPoE over ATM eller FE.
Så lenge det ikke er et av switch interfacene men eget FE med ruting egenskaper.
Vanlig patchekabel eller satse på at den lille pluggen treffer? :)
Edit: Det er et switch-interface ja, men jeg er ganske sikker på at jeg kan rute mellom interfacene.
Endret av shakudu
Mulig du må ha eget modem med FE interfacet.
Det er jeg ganske sikker på at du må ha da forresten.
Hvis det er et ikke rutet interface så tror jeg det kan bli værre.
I tilfelle må skrive no switchport på interfacet først(og det fungerer nok ikke her).
Endret av Knopfix
