Jeg har en hel STABEL med LCD-paneler liggende hjemme... De er på 2x20 tegn. Har 14 tilkoblinger. I servicemanualen til kopimaskinene (jeg plukket displayene) fra står det hva alle pinnene er, men ikke hvordan jeg "booter" det..
Har + og -, kontrast, klokke, og to kontrollinganger i tilleg til 8 datainganger. Har scannet siden i databladet, men har ikke noe web-plass å legge det på så send meg en e-mail, så skal jeg sende skjema..
( [email protected] )
Det jeg vil frem til.. er at dersom det er noen som tror de kan hjelpe meg å få "liv" i dette displayet, så kan jeg snail-maile et eksemplar... (har *MANGE*!!!)
Har 2 "chiper" på baksiden:
1 ->Thosiba T7934 0000 Japan 9106HB
2 ->Toshiba T6A41 9050-ES Japan
1 står nærmest tilkoblingen
-DukerX-
Wiring Up The LCD
You should see the pin numbers written on the PCB of the LCD. Take note of them carefully.
Power Supply And Contrast
Firstly, wire up the power supply and contrast (pins 1 to 3) of the LCD. This is to allow us to check whether the LCD is working. Connect points A, B and C on the LCD to the 10K variable resistor respectively. Once that is done, connect the VCC and GND wires for the power supply.
When you connect the 2 power supply lines, CHECK! You wouldn't want to ruin your LCD because of a reverse connection...
Note : If you would like to have maximum contrast at all times, you can do away with the variable resistor and wire pin 3 directly to ground
Control Lines
For the control lines, first short circuit pin 5 to pin 1. Pin 5 is the read/write line. For our purposes, we do not need to read any data from the LCD. Therefore by grounding pin 5 we are setting it permanently in write mode.
Next connect pins 4 & 6 to the cable that would go into the parallel port connector. For my LCD, there is an extra pin 15 for the backlight LED. I connected that to the 5V line.
Data Lines
Lastly, connect up all the 8 data line to your cable.
The last thing to do is to wire up the 25 pin D connector. The pin layout is shown in the picture above. The wiring is pretty straightforward and you can check it from the schematics
Programming the LCD
The piece of code below is the alternative way of controlling the LCD as compared to the first article.
/* Purpose : Prototype C++ Class For LCD Control */
/* Coded by : Choo Tien Weay a.k.a SGStealth */
/* For private use only. It is illegal to use it for commercial purposes. */
/* Copyright 2001 OCMod.COM */
#include
#include
#include
#define BYTE unsigned char
class LCDParallelDriver
public:
LCDParallelDriver();
void Init();
void Clrscr();
void HideCursor();
void HomeCursor();
void Write(char *string);
private:
void SendCmd(BYTE cmd);
void SendData(BYTE data);
int __PORTADDRESS, __DATA, __STATUS, __CONTROL;
LCDParallelDriver::LCDParallelDriver()
__PORTADDRESS = 0x378;
__DATA = __PORTADDRESS + 0;
__STATUS = __PORTADDRESS + 1;
__CONTROL = __PORTADDRESS + 2;
inline void LCDParallelDriver::SendCmd(BYTE cmd)
outport(__CONTROL,0x03);
outport(__DATA,cmd);
outport(__CONTROL,0x02);
outport(__CONTROL,0x01);
delay(10);
inline void LCDParallelDriver::SendData(BYTE data)
outport(__CONTROL, 0x07);
outport(__DATA, data);
outport(__CONTROL, 0x06);
outport(__CONTROL, 0x05);
delay(1);
void LCDParallelDriver::Init()
char init[10];
init[0] = 0x38;
init[1] = 0x38;
init[2] = 0x38;
init[3] = 0x06;
init[4] = 0x0c;
for (int i=0; i<=4; i++)
SendCmd(init);
void LCDParallelDriver::Clrscr()
SendCmd(1);
void LCDParallelDriver::HomeCursor()
SendCmd(2);
void LCDParallelDriver::HideCursor()
SendCmd(12);
void LCDParallelDriver::Write(char *string)
int count;
int len;
len = strlen(string);
for (count = 0; count < len; count++)
SendData(string[count]);
void main()
LCDParallelDriver LCD;
LCD.Init();
LCD.Clrscr();
LCD.HideCursor();
LCD.Write("OCMod LCD Test");
The code above has only been tested on Turbo C/C++.
Du kan ikke legge inn bilder på forumet, du må linke til dem på en ekstern server. Det er dessverre sånn forumet fungerer, og er ikke noe vi kan gjøre noe med...
En hvilken som helst gratis hjemmeside hvor du kan lagre bildene dine fungerer, bare inkluder dem med en html- eller BBcode-link.
Som man kan se er disse displayene fabrikert av et japansk firma ved navnet Optrex. (De er rimelig store på LCD). Typenummer DMC50040. Det du kan gjøre (jeg har forsåvidt allerede gjort dette) er å besøke http://www.optrex.com eller http://www.optrec.co.jp og sjekke deres produktoversikter. Du kan også, dette har jeg også allerede gjort, maile dem og spør dem direkte om hjelp med displayene. Jeg for min del sitter og venter på svar (selv om jeg ikke besitter noen av dem) nåvel... :cool:
Hurra!
Kanskje jeg endelig får vite hvordan disse funker!!
Har hatt dem i nesten et halvt år, uten å få noe "liv" i dem.
Har dyttet "random" data inn på dem, og fått til masse *rot* men ikke noe fornuftig.
Håper det blir en ordning på det!!
  • 2 uker senere...
