Slax Linux ingen diskett
Prøvde nylig å installere Slax Linux på en Usb minnepinne, men støtte på ett problem hvor det poppet opp et vindu som sier:
Windows-Ingen diskett". Feilmeldingen sier:
"Exception Processing Message 0xc0000013 Parameters 0x760F023C 0x83FF59DC 0x760F023C 0x760F023C
Dette løste jeg ved å redigere bootinst.bat
Her er den uredigerte versjonen:
@echo off
cls
set DISK=none
set BOOTFLAG=boot666s.tmp
echo This file is used to determine current drive letter. It should be deleted. >\%BOOTFLAG%
if not exist \%BOOTFLAG% goto readOnly
echo Wait please, searching for current drive letter.
for %%d in ( C D E F G H I J K L M N O P Q R S T U V W X Y Z ) do if exist %%d:\%BOOTFLAG% set DISK=%%d
cls
del \%BOOTFLAG%
if %DISK% == none goto DiskNotFound
echo =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
echo Welcome to Slax boot installer
echo.
echo This installer will setup disk %DISK%: to boot only Slax.
echo.
echo Warning! Master Boot Record (MBR) of the device %DISK%: will be overwritten.
echo If %DISK%: is a partition on the same disk drive like your Windows installation,
echo then your Windows will not boot anymore. Be careful!
echo.
echo Press any key to continue, or kill this window [x] to abort...
pause > nul
cls
echo Setting up boot record for %DISK%:, wait please...
if %OS% == Windows_NT goto setupNT
goto setup95
:setupNT
\boot\syslinux\syslinux.exe -ma -d \boot\syslinux %DISK%:
goto setupDone
:setup95
\boot\syslinux\syslinux.com -ma -d \boot\syslinux %DISK%:
:setupDone
echo Disk %DISK%: should be bootable now. Installation finished.
goto pauseit
:readOnly
echo You're starting Slax installer from a read-only media, this will not work.
goto pauseit
:DiskNotFound
echo Error: can't find out current drive letter
:pauseit
echo.
echo Read the information above and then press any key to exit...
pause > nul
:end
Og her er den redigerte versjonen:
@echo off
cls
set DISK=none
for %%d in (M) do if exist %%d:\%BOOTFLAG% set DISK=%%d
cls
del \%BOOTFLAG%
echo.
echo.
echo.
pause > nul
cls
goto setup95
:setupNT
goto setupDone
:setup95
:setupDone
goto pauseit
:readOnly
goto pauseit
:DiskNotFound
:pauseit
echo.
pause > nul
:end
Som dere ser så har jeg fjernet alle stasjonsbokstavene untatt den som tilhører Usb pluggen.
Det er merket med rødt der hvor jeg har redigert, det er kun stasjons bokstavene som er tatt bort, untatt M som er min stasjons bokstav.
Endret av Dragonlove
