Hvordan fjerne autoupdate på PhotoshopCS3?
Fant denne løsningen hos AppDeploy. Mulig denne løsningen bare er for deployment, men verd et forsøk kanskje. Om jeg ikke husker feil så er application.xml.override en fil du må lage selv med .override som sluttnavn.
Nettsiden appdeploy er en nettside for scriptere og applikasjonspakkere. Genial også for feilsøk generelt.
Utdrag fra løsningen:
3. Preserialization and suppression settings : Thats the name for users not getting prompted for
Serial key, Registration and Updates.
I found that the pdf documentation is adequate (if you are mindful of the issue with the quotes character mentioned earlier). This does not affect the silent install iteslf but is related to post install config.
Put below file "application.xml.override" in the path \payloads\AdobePhotoshop10en_US_volume
<?xml version="1.0" encoding="utf-8"?>
<Configuration>
<Payload>
<Data key="Serial" protected="0">1234serialnumberhere1234</Data>
<Data key="Registration">Suppress</Data>
<Data key="EULA">Suppress</Data>
<Data key="Updates">Suppress</Data>
</Payload>
</Configuration>
Her er en annen løsning:
http://kb.adobe.com/selfservice/viewConten...rnalId=kb402251
Utdrag:
If your computer is connected to the internet, then you can change the Adobe Updater preferences to not check for updates.
To Change the Adobe Updater preferences, do the following:
Start the AdobeUpdater.exe application from ...\Program Files\Common Files\Adobe\Updater 5
When the update screen appears, click the Preferences button
Uncheck the Automatically Check for updates checkbox and click OK
If your computer does not have an internet connection, then you can manually edit the AdobeUpdaterPreferences.dat file.
To manually edit the AdobeUpdaterPreferences.dat file, do the following:
When the Adobe Updater dialog appears stating that there is no Internet connection, click Cancel
Navigate to ...\Documents and Settings\[username]\Local Settings\Application Data\Adobe\Updater5 on Windows XP or ...\[username]\AppData\Local\Adobe\Updater5 on Vista and open AdobeUpdaterPrefs.dat in Notepad.
If the <AutoCheck>1</AutoCheck> tag already exists, then change the value from 1 to 0. Otherwise, add the line <AutoCheck>0</AutoCheck> anywhere between the <AdobeUpdater></AdobeUpdater> tags.
Close and save the AdobeUpdaterPrefs.dat file.
Om noen av disse løsningene fungerer så er det fint med tilbakemelding for andre brukere som sliter med samme "problem".
Endret av Master Chiun
