hvidsten15 Skrevet 15. mai 2008 Del Skrevet 15. mai 2008 (endret) Kjører Ubuntu 8.04. Finner ikke nettverk på vår bærbare acer 5720zg, står at ufrie proprietære drivere er i bruk men når jeg skal redigere trådløse nettverk dukker det ingen nett opp(heller ikke naboenes nett). Vet at nettet er der da jeg har dualboot med vista. Det er en atheros chip i maskina. Står i "Hardware drivers" at driverne er i bruk. Prøvde også og installere madwifi men finner det ikke igjen etter installering, vet ikke om det har noe for seg uansett. Ser dere liker å få se lspci opplysninger når folk spør om slike ting så her er det: karoline@karoline-laptop:~$ lspci 00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03) 00:01.0 PCI bridge: Intel Corporation Mobile PM965/GM965/GL960 PCI Express Root Port (rev 03) 00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03) 00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03) 00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03) 00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03) 00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03) 00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03) 00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03) 00:1c.3 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 4 (rev 03) 00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3) 00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03) 00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03) 00:1f.2 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 03) 00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03) 01:00.0 VGA compatible controller: nVidia Corporation GeForce 8400M GS (rev a1) 05:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express (rev 02) 06:00.0 Ethernet controller: Atheros Communications Inc. AR242x 802.11abg Wireless PCI Express Adapter (rev 01) 07:00.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05) 07:00.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22) 07:00.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12) 07:00.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12) karoline@karoline-laptop:~$ Noen som har en ide? Endret 15. mai 2008 av .::BaNdiT::. Lenke til kommentar
cobaye Skrevet 15. mai 2008 Del Skrevet 15. mai 2008 Har du prøvd å skru av routeren og modemet i noen minutter, eller koblet ut antenna? Det pleier å funke for meg. Lenke til kommentar
hvidsten15 Skrevet 15. mai 2008 Forfatter Del Skrevet 15. mai 2008 (endret) Har du prøvd å skru av routeren og modemet i noen minutter, eller koblet ut antenna? Det pleier å funke for meg. Booter til vista og der går den rett på nett, men det kan jo ikke skade å restarte modemet(er innebygd router, fiffig sak ) Endret 15. mai 2008 av .::BaNdiT::. Lenke til kommentar
hvidsten15 Skrevet 15. mai 2008 Forfatter Del Skrevet 15. mai 2008 var ikke mye hjelp i det, ved nærmere ettertanke så burde det ikke være en overraskelse da jeg heller ikke ser noen av naboenes nett. Er til enhver tid en ca.7nett som jeg fanger inn, får ikke inn noen nå. Men hvorfor det ikke virker skjønner jeg ikke, ser jo ut som alle drivere er på plass Lenke til kommentar
ole_marius Skrevet 15. mai 2008 Del Skrevet 15. mai 2008 får du opp et lys som tyder på om det er slått på? jeg selv her en hp med broadcom og da jeg for inn på hardware drivers sto det at driveren til kortet var på men den var jo ikke. reinstallerte driveren og nå funker det 100% vet ikke om dette kan vere problemet oss deg Lenke til kommentar
hvidsten15 Skrevet 15. mai 2008 Forfatter Del Skrevet 15. mai 2008 Hva er det du tenker på når du snakker om et lys? Jeg gikk inn på hardware drivers og disabla begge til atherosen, restarta og enabla de igjen, restarta men ikke pokker! Lenke til kommentar
trrunde Skrevet 15. mai 2008 Del Skrevet 15. mai 2008 er en knapp fremme med lydkontankten der du kan disable/enable wlan/blåtann på acer maskiner, prøv den Lenke til kommentar
hvidsten15 Skrevet 15. mai 2008 Forfatter Del Skrevet 15. mai 2008 ok! Det skal testes. Har ikke brukt den når jeg kjører windows, men skal prøve det. Lenke til kommentar
jonnor Skrevet 16. mai 2008 Del Skrevet 16. mai 2008 Det er nok madwifi som bør brukes ja. Usikker på om det er denne som innstaleres når du velger ufrie drivere. Uansett bør du kjøre lsmod for å se hvilken driver som brukes. Ved å kombinere denne kommandoen med grep får du kun tilbake resultater som inneholder ordet som følger. Prøv: lsmod | grep ath lsmod | grep eth lsmod | grep madwifi Hvis ingen av disse returnere noe vettugt så poster du innholdet av lsmod. Lenke til kommentar
hvidsten15 Skrevet 16. mai 2008 Forfatter Del Skrevet 16. mai 2008 er en knapp fremme med lydkontankten der du kan disable/enable wlan/blåtann på acer maskiner, prøv den Skjedde ingenting som jeg tenkte. Disse hurtigknappene er jo noe som brukes med acer sitt eget program som styrer disse hurtigknappene. Har jo ikke det installert under linux. Knappen(e) sitter btw rett under skjermen på 5720zg Lenke til kommentar
Demantios Skrevet 16. mai 2008 Del Skrevet 16. mai 2008 (endret) "System/Administration/Hardware Drivers" - Disable HAL (Hardware Access Layor) Så gå i terminalen wget http://snapshots.madwifi.org/special/madwifi-ng-r2756+ar5007.tar.gz sudo apt-get install build-essential tar xfz madwifi-ng-r2756+ar5007.tar.gz cd madwifi-ng-r2756+ar5007 make sudo make install sudo modprobe ath_pci sudo reboot Endret 16. mai 2008 av PepsiCo Lenke til kommentar
hvidsten15 Skrevet 16. mai 2008 Forfatter Del Skrevet 16. mai 2008 Fantastisk Pepsico! Nå har jeg skrevet inn all koden og restarta. Det som er nytt er att når jeg høyreklikker på nettverksikonet oppe til høyre er det nå kommet ei ny linje der jeg kan slå av og på aktivering av "trådløst nettverk", før var det bare nettverk. Men den scanner fremdeles ikke etter nettverk, skal jeg inn på hardware drivers igjen og aktivere HAL igjen? Finner ikke madwifi i noen av menyene nå heller, er det et grensesnitt til den madwifi eller ligger den bare i bakgrunnen og jobber? Lenke til kommentar
Demantios Skrevet 16. mai 2008 Del Skrevet 16. mai 2008 Hmm, hva om du svartelister den originale driveren echo "blacklist ath_pci" | sudo tee -a /etc/modprobe.d/blacklist For så å restarte igjen Lenke til kommentar
hvidsten15 Skrevet 16. mai 2008 Forfatter Del Skrevet 16. mai 2008 Nå forsvant linja med "trådløst nettverk" Finner ikke nettverk nå heller... Lenke til kommentar
Demantios Skrevet 17. mai 2008 Del Skrevet 17. mai 2008 Da bruker den standarddriveren da, istedenfor madwifi sin O.o HAL er fortsatt deaktivert? Lenke til kommentar
hvidsten15 Skrevet 17. mai 2008 Forfatter Del Skrevet 17. mai 2008 Jeg droppa hele ubuntu og installerte mandriva One 2008 spring. Trådløse nettverket og alt fungerte med en gang Lenke til kommentar
