Bluescreen, Minidump trenger analysering(Løst)
Har hatt en del problemer med den nye pcen min, men nå trodde jeg jeg hadde fiksa den.:wallbash:
Men så når jeg sitter å spiller HL2 får jeg først 2 crashes til desktop og så tredje gangen får jeg bluescreen. Har debugga MiniDump fila i WinDump her:
1: kd> !analyze -v
*						Bugcheck Analysis									*
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: bfa8d34f, The address that the exception occurred at
Arg3: aa87dc14, Exception Record Address
Arg4: aa87d910, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
nv4_disp+b834f
bfa8d34f 8b7758		  mov	 esi,dword ptr [edi+58h]
EXCEPTION_RECORD:  aa87dc14 -- (.exr 0xffffffffaa87dc14)
ExceptionAddress: bfa8d34f (nv4_disp+0x000b834f)
  ExceptionCode: c0000005 (Access violation)
 ExceptionFlags: 00000000
NumberParameters: 2
  Parameter[0]: 00000000
  Parameter[1]: 00000058
Attempt to read from address 00000058
CONTEXT:  aa87d910 -- (.cxr 0xffffffffaa87d910)
eax=bfad7570 ebx=bfa91b20 ecx=bfad7571 edx=bfad7571 esi=bfe547e0 edi=00000000
eip=bfa8d34f esp=aa87dcdc ebp=bfe54470 iopl=0		 nv up ei ng nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000			 efl=00010286
nv4_disp+0xb834f:
bfa8d34f 8b7758		  mov	 esi,dword ptr [edi+58h] ds:0023:00000058=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  hl2.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
READ_ADDRESS:  00000058
BUGCHECK_STR:  0x7E
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
LAST_CONTROL_TRANSFER:  from 805ce84c to bfa8d34f
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
aa87ddac 805ce84c 88f97c88 00000000 00000000 nv4_disp+0xb834f
aa87dddc 8054532e b9e75350 89493960 00000000 nt!PspSystemThreadStartup+0x34
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
FOLLOWUP_IP:
nv4_disp+b834f
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nv4_disp+b834f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nv4_disp
IMAGE_NAME:  nv4_disp.dll
DEBUG_FLR_IMAGE_TIMESTAMP:  481c0584
STACK_COMMAND:  .cxr 0xffffffffaa87d910; kb
FAILURE_BUCKET_ID:  0x7E_nv4_disp+b834f
Followup: MachineOwner
Har en liten anelse av at dette har med en nv4_disp greie å gjøre, Nvidia Driver kanskje?
Noen som kan analysere for meg? ;)
Skjekka litt rundt å fant at dette hadde med drivere å gjøre mest sansylighvis, men har de aller nyeste nvidia driverene :hm:
Endret av Spinx
Heisann!
Som du ser feiler instruksen mov esi,dword ptr [edi+58h] siden edi registeret er nullet ut og åpenbart fortusatte ikke instruksen dette siden dette vil føre til at den referer til ugyldig minne.
Den kan være flere grunner til dette-enten en feil i selve driveren, korrupte minne-pooler eller maskinvarefeil.
Det første man bør gjøre er å feilsøke så mange minidump filer av samme feilen som mulig-og sammenligne disse for å se om man finner noen fellesnevnere.
Deretter kan man gjøre en grundigere feilsøking for å prøve å finne ut hvorfor edi-registeret er nullet ut. Først og fremst ved å de-assemble instruksjonen nv4_disp+0xb834f og se hva den gjør, deretter undersøke minneområdene til den aktuelle tråden og se etter suspekte verdier.
Lykke til.
Tja vel vi kan ta feilsøkingen etter prioriter.
1.Jeg regner med at feilen har inntruffet flere ganger-og du burde derfor ha flere minidump filer av samme problem. Prøv å åpne disse og se om de er bortimot identiske med den filen du analyserte ovenfor.
2.Forekommer feilen KUN i HL2.exe? Jeg antar dette er et spill isåfall burde det være mulighet for å kunne konfigurere grafikkinnstillinger-forekommer feilen fremdeles om du stiller alle grafiske innstillinger i bunn?
Selve Bluescreen feilen har jeg bare fått 1 gang. Men både crysis og HL2 klikker gjenvt og ofte, sånn ca hvert 15min enten med en windows feilmelding eller uten noen feilmelding i det hele tatt.
Hva tror du dette kan skyldes? Og er det mulig å feilsøke en sånn feilmelding du får i windows når bare et program klikker?
Tja variende feil er jo som regel relatert til maskinvareproblemer, har dette problemet bestandig vært slik eller har det kommet nå i det siste? Prøv isåfall og tenk over hvilke endringer som har blitt gjort på systemet.
Normalt skal Dr.Watson klare å fange slike programfeil og generere en feilrapport som kan feilsøkes med Windbg på samme måte som man feilsøker en blåskjerm. Dog skal det sies at det er overraskende mange feil den ikke greier å fange-men du kan prøve å starte drwtsn32 fra kjør feltet i start menyen og se om det har kommet opp noe på programvarefeil listen.
Gjest Slettet+6132
@Spinx:
Du *må* oppgi hardware i slike og tilsvarende feilsituasjoner.
OS-versjon, driver-versjon(er) er også essensiell info.
Jeg mistenker at du har ett nForce basert hk.
Dette er en "vanlig" feil (krasj/heng/BSOD) for slik hardware.
Om det er hardware-relatert, eller rett og slett dårlig kodet skjermdriver (Nvidia) er vanskelig å si noe om.
Ok skal prøve å gi så mye detaljer som mulig her
Feilen inntraff etter at jeg hadde satt in mine nye deler i pcen
Asus P5K hovedkort
2gb Crucial Ram PC 8500 står på 5-5-5-15 1066MHz 2.2v
Intell Duo 2 E8400
Gainward GeForce 9800GTX 512MB
de gamle delene er:
WD 80gb IDE disk
WD 120gb SATA disk
Thermaltake 460W Purepower
OS er windows XP
Helt nytt Bios og hovedkort drivere
Nyeste nvidia driver 175.16
Temperaturene er helt fine
Idle:
CPU=27grader, kjernene ligger på 40grader
Hovedkort= 42grader
GPU= 52grader
Under full load:
GPU max 65grader
CPU max 52ca
Hovedkortet ca 51.
Skjekker detta i Everest Ultimate Edition
prøvde også å kjøre en stresstest i everest men da skjer dette,
Har kjørt test i 3dmark, gikk helt fint uten noe crash.
Men den crasher på alle mulige spill HL2, Crysis, BF2 og tilogmed i Firefox hvis jeg spiller et 123spill.
Det som skjer er at programmet lukker seg og jeg får en sånn standar windows feilmelding, og en gang fikk jeg bluescreen, men har ikke fått den igjen.
Ok nå har jeg fått testa rammen og den ene går helt fint gjennom alle testene uten feil. Den andre får 10 errors bare 20% inne i testen så tror nokk den ene rammen min er noe galt med :p så sender den tilbake til komplett.
Gjest Slettet+6132
Bra jobba Spinx. :thumbup:
Du kom meg i forkjøpet.
Tenke å poste at du måtte sjekke RAM'en da jeg så du hadde lagt inn doc av hardware.
Crusial brikkene har dessverre en litt vel stor feilrate slik jeg har oppfattet det.
(Har en defekt brikke selv som jeg ikke har somla meg til å RMA'e).
Jepp der var det fiksa ;)
Satt å spilte Crysis i 4 timer på High uten en eneste feilmelding.
Så nå funker nok alt fint. Håper jeg får skaffa meg en ny en innen fredag, så jeg har 2gb til AoC :D
