jornt Skrevet 6. mars 2003 Del Skrevet 6. mars 2003 Hei, lurer på om noen kan hjelpe meg litt, har problemer med dårlig ytelse med et Adaptec 2010 ZCR RAID kort. (Som benytter en Adaptec AIC-7902 onbard dual Ultra320 kontroller) Får max 70-90 MB/sek med denne kontrolleren, mens de fire diskene jeg har burde klare 250-300 MB/sek i RAID 0 (andre jeg har snakket med har fått 270 MB/sek med nøyaktig samme disker, men på en 39320-R kontroller) Resten av posten er på engelsk (har postet på et annet forum også ) I have two servers with this setup: Supermicro SuperServer 6023P-8 (SUPER X5DP8-G2 motherboard) 2 x Xeon 2.66 GHz, 533 MHz FSB 2 x 512 MB Corsair ECC/REG PC2100 DDR RAM 4 x Seagate Cheetah 15K.3 18 GB drives Adaptec 2010S Zero Channel RAID, located in the green slot Windows 2000 Server, service pack 3 The 2010S is located in a 64-bit, 66 MHz slot, 528 MB/sec transfer rate. All drives are using Ultra320 transfer mode, and everything is properly terminated. Performance results, ZD WinBench 99 Version 2.0: http://www.skm.no/temp/raid As you can see, four drives in a RAID 0 array only performs on par with a single drive! Even software RAID in Windows 2000 is outperforming the 2010S with about 50% in most tests I have of course tested the servers in several configurations, but the transfer rate never exceed 80-90 MB/sec I've tested on: - Both of the two equally configured servers - With or without the newest RAID BIOS or NVRAM flashed into the controllers (dated 2003-01-29) - Windows 2000 Server without SP3 - Windows 2000 Server with SP3 - Windows XP - With or without busmastering enabled - With or without hyperthreading enabled - Running Windows from the RAID array - Running Windows from a separate drive - RAID 0, 2 drives - RAID 0, 4 drives - RAID 10, 4 drives - RAID 5, 4 drives - Stripe sizes of 64 kb, 128 kb and 256 kb - With or without caching enabled I now begin to understand that the controller simply isn't able to transfer more than about 80 MB/sec, even if the specs says it should be able to transfer up to 640 MB/sec using both channels (Which is of course theoretical, but with lets say 10 drives in RAID 0 over both channels should make more than 500 MB/sec) I consider "upgrading" to the 2120S, but I see several people complaining about the poor performing Adaptec cards - could anyone post their results on a 2010S, 2120S or 2200S? With for example 4-6 drives in RAID 0.. Does anyone achieve higher results than 80-100 MB/sec with these controllers? What are your experiences with the 29320-R or 39320-R controllers? Last question: is the 29320-R able to run 4 drives in a RAID 10 array? - Jørn Tømmerås, frustrated computer engineer Lenke til kommentar
