spørsmål ang. passord/login script
Hei, har funnet et login script på nettet, som jeg delvis har endret selv. Jeg har tenkt å bruke scriptet på hjemmesiden min.
Scriptet består av følgende filer:
main_login.php:
Klikk for å se/fjerne innholdet nedenfor
<?php
ob_start();
$host="localhost"; // Host name
$username=""; // Mysql username
$password=""; // Mysql password
$db_name=""; // Database name
$tbl_name=""; // Table name
// Connect to server and select databse.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// Define $myusername and $mypassword
$myusername=$_POST['myusername'];
$mypassword=$_POST['mypassword'];
// encrypt password
$encrypted_mypassword=md5($mypassword);
$sql="SELECT * FROM $tbl_name WHERE username='$myusername' and password='$encrypted_mypassword'";
$result=mysql_query($sql);
// To protect MySQL injection (more detail about MySQL injection)
$myusername = stripslashes($myusername);
$mypassword = stripslashes($mypassword);
$myusername = mysql_real_escape_string($myusername);
$mypassword = mysql_real_escape_string($mypassword);
$sql="SELECT * FROM $tbl_name WHERE username='$myusername' and password='$mypassword'";
$login_error = FALSE;
$login_error = "Username and password do not match.";
if($login_error !== FALSE) {
echo $login_error;
// Mysql_num_row is counting table row
$count=mysql_num_rows($result);
// If result matched $myusername and $mypassword, table row must be 1 row
if($count==1){
// Register $myusername, $mypassword and redirect to file "login_success.php"
session_register("myusername");
session_register("mypassword");
header("location:login_success.php");
ob_end_flush();
<table width="300" border="0" align="center" cellpadding="0" cellspacing="1" bgcolor="#CCCCCC">
<tr>
<form name="form1" method="post" action="">
<td>
<table width="100%" border="0" cellpadding="3" cellspacing="1" bgcolor="#FFFFFF">
<tr>
<td colspan="3"><strong>Member Login </strong></td>
</tr>
<tr>
<td width="78">Username</td>
<td width="6">:</td>
<td width="294"><input name="myusername" type="text" id="myusername"></td>
</tr>
<tr>
<td>Password</td>
<td>:</td>
<td><input name="mypassword" type="password" id="mypassword"></td>
</tr>
<tr>
<td> </td>
<td> </td>
<td><input type="submit" name="Submit" value="Login"></td>
</tr>
</table>
</td>
</form>
</tr>
</table>
login_success.php:
session_start();
if(!session_is_registered(myusername)){
header("location:main_login.php");
<html>
<body>
Login Successful <?php echo $myusername ?>
<a href="logout.php">log ut</a>
</body>
</html>
logout.php:
session_start();
session_destroy();
You are now logged out!
Det jeg lurer på er:
1) Hvordan få teksten "Username and password do not match." til kun å vise når brukernavnet/passordet er skrevet inn feil
2) Kan noen hjelpe meg å endre scriptet slik at de som logger på (5stk) ikke kommer til samme siden, men hver sin?
3) Er dette scriptet sikkert, eller er det lett å komme forbi?
Tusen takk for all hjelp :)
EDIT: Har nå klart å finne et svar på spørsmål nr 1 og 2 ;)
Endret av J0nny
main_login.php:
<?php
ob_start();
// encrypt password
echo $login_error;
if($count==1){
ob_end_flush();
<tr>
<td>
<tr>
</tr>
<tr>
</tr>
<tr>
<td>Password</td>
<td>:</td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
</table>
</td>
</form>
</tr>
</table>
login_success.php:
session_start();
<html>
<body>
</body>
</html>
logout.php:
session_start();
session_destroy();
sette en else etter if i login_sucsessful.php
else{
echo "Login Wrong, Please try agian";
nå må jeg si at det var en vanskelig måte å jøre det på da :) men men :p
